MSD Dist. Cap Screws
MSD Dist. Cap screws are junk. I was changing my cap and rotor and when I put the new MSD cap on I was turning the screws slow and one of the damn screws broke. So I took the cap back off and the screw was broke off in the Dist metal plate. I tried everything to get it out. I even drilled on it. I thought I was going to have to pull the Dist. so i took it down to chevy and drilled it out and taped the hole. Cost me 30 bucks. So to anyone that is going to put a MSD cap on, I would use the factory screws.
Car: 2001 Camaro SS
Engine: Almighty LS1
isn;t that what they recommend? using the originals?
were you trying the teflon screws? or the normal-ish ones
Hotrodboba400
12-10-2019 07:07 PM
