Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
400 combo's
Old 12-24-2002, 09:30 PM
ohyeahjay's Avatar
400 combo's
seems like a lot more people are starting to build 400's so i was just wondering everyone's combo and if they have 1/4 mile times with there combo's and any problems with anything during the build and after.
Here's my combo
400 bored 0.030 406
crane gold 1.6 roller rockers
balanced and blueprinted
carter fuel pump
pro topline 220 heads
comp cams XE 284 H
victor jr. intake
milodon windage tray
650 holly V.S
6" sir eagle I beam rods
all arp hardware
head studs/main studs
fel pro gaskets
Keith black dished pistons
soon to come: complete msd ignition, Holley or speed demon 750 V.S. Hooker 1 3/4 long tubes, custom dual exhaust, complete interior redo and a stall converter and sticky tires.
Old 12-25-2002, 03:52 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
see sig
ill have to find my build sheet to list everything in it though.
Old 12-25-2002, 08:34 AM
1fastz28's Avatar
400 bored .030 over, stock crank and rods, speed pro forged pistons, 10.2:1 comp with 67 cc chambers, Brodix cnc'd track 1's, Holley stealth ram (will be running mini ram soon), comp solid roller cam, 30lbs holley injectors, all msd ignition, tpis custom stage 6 chip, just got dynoed at 486 hp at 5700 rpm and 515 lb of torque at 3900!! will be installing in car soon, will have time slips when summer finally rolls around! Just waiting to borrow digital camera from a buddy to snap some pics!
Old 12-26-2002, 07:29 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Just curious...what cam are you guys using with your setups?
Old 12-26-2002, 08:38 PM
1fastz28's Avatar
I am running a comp cams XR274R solid roller, the specs are 236* intake, 242* exhaust, .564" intake, .570"exhaust with 1.52 rockers, and ground on a 110* lsa. I will be switching to 1.6 rockers to see if I can make any more gains. I am still playing with the timing and the fuel pressure and trying to squeze alittle more out of the motor, it is running very rich!
Old 12-27-2002, 12:01 AM
ohyeahjay's Avatar
I running a comp cams extreme energy 284 H, can't remember the specs. 1fastz28 are you running yours on the street or strip
Old 12-27-2002, 10:48 AM
1fastz28's Avatar
I'll be planning on using it for cruising and the strip. It won't be a daily driver by anymeans! i don't think the choppy 1100 rpm idle would be very comfortable driving to work every day! But it will be very streetable and runs on pump gas. But it is alout tamer then you'd think, although I think the fuel injection helps a bunch with that!
Old 12-27-2002, 04:54 PM
ohyeahjay's Avatar
its not the streetability i was questioning it was the fact that solid roller's aren't made for daily driving. My friend drove about 300 miles on his and it chewed the lobes and roller lifters. It was a very expensive setup even though it was a ford setup i hated to see it self destruct like that. I think its a great setup but I would look into this unless you know it will survive. Comp cams will tell you the same thing.
Old 12-27-2002, 07:44 PM
Parrydise7's Avatar
Car: 1985 Camaro
Engine: .040" over 350
Axle/Gears: 9-bolt with 3.45s
I was wondering about a 400 block with Fast Burn heads and a HOT cam. Instead of a Fast Burn 385, it would be a Fast Burn 400. Can you imagine the torque from that monster?
Old 12-28-2002, 06:33 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Unfortunately my 383 broke a rod so I'm in the process of replacing it with a 406. The plan is to use the stock crank,
6" steel rods and forged flat top pistons.
I will be reusing the cam from the 383. It's a Comp XE solid roller
248/248@.050, .614/.614 lift with 1.6 rockers and ground on a 112 lsa 4 degs advance. Believe it or not, this cam had an outstanding idle with a very strong mid range and pulled solidly up to 6500. Prior to using this cam in the 383, I had another Comp XE solid 236/242@.050, .603/.608 112 lsa 4 degs adv.
The split duration cam although smaller,idled rougher and made peak HP at 7000 vs. the larger single pattern that made peak HP at 6500.
www.geocities.com/dzperf
Old 12-28-2002, 01:26 PM
1fastz28's Avatar
I don't think I will have any reliability issues with the solid roller. Comp advised me that as long as I keep a close I on making sure the lash is always adjusted properly I should have no more problems then I hydraulic setup. I guess time will tell! But I won't be planning on any big trips with it, so I'm not concerned!
Linson
09-25-2021 07:55 PM
InfernalVortex
04-20-2021 11:31 AM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
88SS6SPEED
11-11-2015 07:05 AM
roysatikas
09-22-2015 08:15 PM
Quick Reply: 400 combo's
