Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
how beneficial are underdrive pulleys!
Old 02-25-2003, 05:58 PM
killerIROC's Avatar
i have a 1988 IROC 5.7 L98 and was curious how beneficial underdrive pulleys would be on my car and any application. I heard the eat belts quick! Any advice!!
Old 02-25-2003, 07:23 PM
Dzaw's Avatar
Underdrive eh?
Well, first, you're right, they'll chew belts, but then again, any belt system does that at some rate or another.
Next though, you have to understand the tradeoff. You can gain HP (5-15% more HP) by underdriving certain things, but IMHO, you're better off spending your money on something else. With an underdrive kit, your accessories are not turning at the rate they are meant to. Your lights are going to dim, especially at idle, your heat/AC won't blow as hard, and your ignition is going to lose some umph. You can FORGET about a high po sound system, your alternator just won't put out enough juice anymore, and you're just going to eat batteries.
Even worse are the systems that underdrive water pumps, heat is enough of a problem for our cars, let's not get rediculous!
Old 02-25-2003, 07:28 PM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...rdrive+pulleys
i ran a search for you..
Old 02-25-2003, 09:01 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I've got the March 2 pc. pulley. I've had it going on 8 months with no problem in over heating, or battery charging. The down side is ......I didn't feel any more power like I would an exhaust or intake upgrade. I'm sure more hp is there on a dyno.
Old 02-25-2003, 09:19 PM
killerIROC's Avatar
re. underdrive pulleys
well a buddy of my has a 2-piece he was gonna sell me for $40 from Mac Performance, but the altenator pulleys is the same size as the Mac pulleys, i would only gain from the crank, which is about 2-21/2 times smaller! But maybe i wont! Thanks!
Old 02-25-2003, 09:56 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
underdrive pulleys will also burn up the bearings in alternators and waterpumps and so on a lot faster. they spin the bearings at such a faster rate of speed that they dont last nearly as long as they were intended to. ive heard this is crap from some people, and ive heard its true from others, if you think about it, it would make sense. IMO, i wouldnt run them.
Old 02-28-2003, 10:36 PM
RICHRAD's Avatar
I would think the bearings would be less stressed...They are underdriven....right? Would the other pulleys be spining slower because the crank pulley is smaller...I'm new at this ..so someone step in please
Old 02-28-2003, 11:07 PM
vjo90RS8's Avatar
Car: 2002 Z28
Yeah, they should be rotating slower since that is the whole purpose of a underdrive pulley set.
I installed an ASP crank pulley and noticed alittle more top end, i have no regrets.
Old 03-01-2003, 12:29 AM
25THRSS's Avatar
Get the march power and amp series pulleys and you wont have any problems with charging. Underdrive pulleys arent smaller, they are bigger which means they rotate less, with smaller pulleys they rotate more so they wouldnt be underdriven they would be overdriven. Some cars actually run cooler with underdrive pulleys because the water stays in the radiator longer letting it do its job. The slower an accesory turns the more power and less wear although you dont want to go to slow or else things wont function right. Its really a trade off that depends on the car. Just a little info for you guys
Old 03-01-2003, 12:54 AM
vjo90RS8's Avatar
Car: 2002 Z28
ok, lets get underdrive pulleys understood. If the crank is rotating at 1000RPMs, then the crank pulley is rotating at the same rate because it is attached to the crank. The small ther crank pulley, the small the crank is going to drive the accessories. BUT, yes, the accessory pulleys are bigger so they rotate less, but the crank pulley is smaller.
Old 03-01-2003, 12:58 AM
25THRSS's Avatar
wrong, the crank pulley is bigger, smaller would turn faster. Think of it this way....take ure car and put some 20 inch rims with matching tires, now put some 15 inch rims on it and ure gonna turn more rpm with the smaller tires because they turn more times every second than a bigger tire. same principle with underdrive pulleys. ure right about it turning the same rpm as the engine, but the belt will turn less times with a bigger pully vs a smaller one
Old 03-01-2003, 01:08 AM
vjo90RS8's Avatar
Car: 2002 Z28
think about it man, the crank is connected to the crank pulley, they have to turn at the same rate right. Its common sense, the smaller the crank pulley, the smaller it drives the other accessories.
Old 03-01-2003, 01:10 AM
vjo90RS8's Avatar
Car: 2002 Z28
same rotational velocity, but a smaller tangental velocity (smaller radias), thus, underdriving the accessories, if you dont agree with me on this one, i dont know what to say.
Old 03-01-2003, 01:12 AM
25THRSS's Avatar
yes ure right it is connected to the crank pulley, but ure thinking is wrong. the bigger the pulley the less times it rotates per minute. if you were to take a 3 inch pulley and put it on and put a mark on it you would see the mark fly around more times than if you put a 3 foot pulley on it. Its just hypathetical. I know a three foot pulley is impossible, i was just tryng to make a point
Old 03-01-2003, 01:14 AM
vjo90RS8's Avatar
Car: 2002 Z28
ok, if the crank rotates once, then the crank pulley rotates once, RIGHT?!?!?!?!?!, whether it is 1000000" or 1", you are thinking the wrong way. its physics man, and ive take enough to understand this basic concept.
Old 03-01-2003, 01:23 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
For the drive pulley, the larger the pulley, the faster the accessory will spin. For a driven pulley, the larger the pulley the slower that accessory will spin. Underdrive crank pulleys (the drive pulley) are smaller then stock. Because they are smaller, they move less belt per rpm, which in turn slows down how fast the accessories spin.
Old 03-01-2003, 01:25 AM
25THRSS's Avatar
yes ure right, i am corrected, i was thinking the other way around. thanks for setting me straight
Old 03-01-2003, 01:29 AM
vjo90RS8's Avatar
Car: 2002 Z28
Its all good man, we are here to learn, and you just learned something
If i read my old post, i think i was the dumbest car person alive, now i like to think that i am alot more knowledge, but i still have alot to learn, like most of us on the boards.
Old 03-01-2003, 01:36 AM
BaLleRz68's Avatar
I remember when u didn't know how to change oil.
Old 03-01-2003, 01:40 AM
25THRSS's Avatar
lol, that was a while ago for me. I consider myself very knowledgable about cars considering i did my first engine rebuild when i was less than 10 years old with the help of my dad. Every once in a while i will earn something like the difference between drive and driven gears which to me now seems pretty obvious, lol. Sometimes my brain doesnt like to function. This board is very helpful when it comes to my third gen and any car really. I learn something new all the time. Thanks guys
Old 03-01-2003, 01:52 AM
gabebandit's Avatar
I have the March 3 piece aluminum set on my 90 Formula. I can feel a difference with them, it deffinately freed up some power. They have been on for 2 years now and have never thrown a belt. I have no cooling or charging problems. The pulleys slow down you accessories to create power. Also the aluminum is lighter and easier for the motor to turn. If you get any get these or the 3 pc Power pulley set from March.:rockon:
Old 03-01-2003, 02:07 AM
25THRSS's Avatar
were they the power and amp and are you auto or manual?
Old 03-01-2003, 02:09 AM
vjo90RS8's Avatar
Car: 2002 Z28
i think, unless you are going for the nice polished look of the 3 piece March set, just get an ASP crank pulley, i think i paid like 60 for mine. I hear the water pump pulley on the March set is the same size as the stock one, and the alternator pulley doesnt even make much of a difference.
Old 03-01-2003, 05:15 AM
gabebandit's Avatar
They were the regular set. They work great to me. It's an auto car.
Old 03-01-2003, 10:13 AM
RICHRAD's Avatar
Well, here's what I think. Not sure of what sizes these pulleys are compared to the stock set-up. But if the crank turns one turn, the crank pulley turns one turn. No matter how big. In the machinist trade, we call the spinning at the diameters,"surface feet per minute". Larger the crank pulley,the more feet per minute it is gonna move the belts in one revolution. So the idea of a larger crank pulley seems to defeat the purpose I guess unless the alt. pulley is way smaller than stock. The deal with excessive belt useage/throwing belts ....wouldn't that be more of belt sizes or belt alignment problems?......
Old 03-01-2003, 04:10 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
true the belt moves at a slower speed and there for it moves your waterpump, alternator, power steering, etc.. at a slower rate. march pulleys makes too sets. the regular set has a alternator and a crank pulley. the power and amp set hasa smaller crank and a much smaller alternator pulley so you don't put any drain on your battery tan the oem pulleys would.- but you a/c, power steering, and water pump will suffer
my .02
Old 03-01-2003, 11:43 PM
jd13's Avatar
Have had underdrive pullies on my IROC for 10 years or so now. Times are in my sig. I think they are a good benefit.
Yes, my lights dim slightly at stoplights. Yes, I have a system. Yes, I ran through some altenators, but have had this current one for 3 years now. The only cooling problems I have had was from a leaky radiator hose.
I think that's crap. ;p I'm still on my stock waterpump after 10 years of underdrive pullies. If you have a well taken care of car, and continue to care for it, you will not see any problems with pullies imo.
Old 03-02-2003, 12:07 AM
Engine: peanut LB9
hey jd13 ur right that state ment is totally wrong. under drive pulleys REDUCE the speed of your water pump and alternator. if they are doing anything, they are saving them!!! but your sufering from loses in coolant flow(get a high flow waterpump), and the alternator, just put a smaller pulley (on the alternator)that they give you that will retain the stock turning ratio of the oem pulleys.
btw y lights dime wit out the pulleys, so whats a loulsy, 2% of power 5amps, come on get a 140amp alternator and you'll neva have anypoblems with pulleys.
my .02
Old 03-02-2003, 05:42 PM
91 z28 350's Avatar
Car: 91 Z28
Jd13 what kind of underdrive pullies do you have ?
Old 03-13-2003, 12:22 PM
RedGTAta1's Avatar
im trying to understand this as well. Hmm. Im thinking of a bike right now, like a 10 speed. First gear big sprocket easy to turn and move faster at low rpm but spins alot more fast at higher rpm because of higher amount of peddaling, where as 5 gear is a "mid-range" like a stock pulley, and 10th gear being a little harder to get moving but at higher engine rpm and higher speed it would benifit from less stress, like not spinning you feet as hard to work for the same rpm? Let me know if I have this right, thanks
Derek
Old 03-13-2003, 02:34 PM
Engine: peanut LB9
RedGTAta1 u kinda got it.
stock pulleys are meant to turn the accesorys at right speeds.
when you install a underdrive pulley(they come with the crank pulley and most come with an alternator pulley. some also come with an waterpump pulley too. by installing a smaller crank pulley this will REDUCE the belt speed. thus reducing the rpm of everything else. now the alternator pulley that the kit gives you is alsoo smaller, to bring the speed of the alternator back or close to the stock rpm. and the kits that include the wter pump are usally the billet alumium ones. they give you that pulley so it looks good. it isn't any beter than the stock one. it just gives you that custom look.
the pros-
1- slower turning of the waterpump, power steering, and a/c (if u have it) thus making them turn slower lets your engine make more power do to the strain.
2- less wear on your belt/s.
3-more power
the cons-
1- cooling problem due to less coolant flow
2-a little harder to steer cause of a slow power steering pump
3- ur a/c won't blow as hard when its on compared to the stock pulleys
4- if u buy the wrong kit, your electrical system will not have enough juice. (or if u don't install it at all)
your gonna have to look at your case and decide if they are for you.
inmy case- i got a high flow water pump and a 100amp alternator, so i'm not affected.
Old 03-13-2003, 04:06 PM
vwdave's Avatar
If you are that worried about overheating your car, get a performance waterpump that outflows stock to compensate for the pulleys.
I dont know about you guys, but I have smoked 3 batterys and 3 alternators, so I cant imagine killing them faster.
Old 03-13-2003, 09:09 PM
Engine: peanut LB9
Originally posted by vwdave
I
what pulleys do u have and did u install the alternator pulley,
one problem here two possible ideas
1- wrong pulleys or installed incorrectly
2- a problem somewhere else
Old 03-13-2003, 09:11 PM
vwdave's Avatar
When I get time......
Old 03-13-2003, 09:37 PM
Engine: peanut LB9
didu install them correctly(installed the alternator pulley too), or did u buy the wrong ones, which ones did u buy
or if u have a large stereo tht could be it too.
Old 03-13-2003, 09:39 PM
vjo90RS8's Avatar
Car: 2002 Z28
i installed an ASP crank pulley and have not noticed any changes in cooling and no significate changes in alternator voltage, at idle the meter does drop, but only to around 12 volts.
Old 03-14-2003, 12:23 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
Maybe somebody said it and I missed it, but do you have to run a special belt then? What size belt do you run. I looked at the two piece steel March set for about $70 compared to the 3 piece March aluminum set for about $170. Big difference for just show. I guess the aluminum would be a hair lighter but still,,,,
Old 03-15-2003, 11:57 AM
vwdave's Avatar
Maybe call summit or march and ask them?
Old 03-16-2003, 01:34 AM
Engine: peanut LB9
you do need a new belt, i dunno the size
Old 03-18-2003, 11:15 PM
bubafett's Avatar
I have actual experience!
It works! Car had more torque. would spin tires going into 3rd with T5. would not do so before. Car felt more responsive.
I have had an underdrive pully since 1991.
Broke first belt in 1999.
Car never over heated.
Power steering felt beeter due to more effort.
I bought it from, I forget, but I only replaced the drive pulley. The one on the crank.
No need to replace any other pulleys.
These are the facts Jack
grngryoutmyway
10-18-2016 05:48 PM
bigjay89gta
10-15-2015 08:04 AM
jaridjohn
10-05-2015 07:01 AM
anesthes
09-30-2015 07:48 AM
JSDaddy189
09-26-2015 03:50 PM
Quick Reply: how beneficial are underdrive pulleys!
