Anybody ever use Posi-lock connectors? - Third Generation F-Body Message Boards
Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Thread Tools Search this Thread
Old 03-10-2004, 10:12 PM   #1
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
I did a search and it came up with nothing.. In new summit catalog it has a product to replace butt-connectors...It LOOKS like good product but I dont wanna waste my money..
Dan
metalhead212121 is offline vBGarage Page   Reply With Quote
Old 03-14-2004, 11:52 PM   #2
anyone???
Old 03-15-2004, 08:40 AM   #3
Car: '94 Corvette
'metalhead212121' they work very well. I'm serious, I have a bunch in my tool chest. There pretty damn strong, and your likely to brake the wire before your able to pull them out of the posi-locks.
For permate stuff, I usually solder and shrink tube everything.
Make sure you get all sizes because there very size dependant, meaning your not going to be able to ram a 12ga wire in a 18ga posilock.
Ron
ronterry is offline vBGarage Page   Reply With Quote
Old 03-15-2004, 09:03 PM   #4
thanks for the info Ron.... Can you disconnect and reconnect those Posi-lock connectors? Or is it you connect them...and they are connected together for "the long run..."
Thanks again..
Dan
Old 03-15-2004, 09:55 PM   #5
Car: '94 Corvette
No problem..
You can re/disconnect them easy. The ends are threaded, and provide an absolute positive connection. The only con to them is there a little bulky. (Actualy the bigger sized ones are bulky ie. 12ga, but the smaller 18ga are not to bad.)
Ron
Old 03-15-2004, 09:55 PM   #6
Car: '94 Corvette
Old 03-15-2004, 09:57 PM   #7
Car: '94 Corvette
BTW: I bought mine over at Checker Auto, so there avilable at many local parts store.
Old 03-20-2004, 07:53 PM   #8
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
looks like a fuse link. my buddy used those when hooking up his system. i think they are real ugly but if they work and they are hidden then i guess they are worth the investment
Kontrax is offline vBGarage Page   Reply With Quote
Old 03-21-2004, 08:37 PM   #9
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
so where can i get some....
Charged350 is offline vBGarage Page   Reply With Quote
Old 03-21-2004, 08:59 PM   #10
Car: 86 Camaro
summit or jegs. local speed shop can order them if you dont have them. i think autozone or someplace like that will have them too
Old 03-22-2004, 09:52 AM   #11
I was just at Home Depot a few days ago and inquired into connectors for wiring. They had some nice insulated connectors that were much smaller and cleaner looking that that. I will probably use those when I get around to doing my 4th gen dash swap.
Bandit5 is offline vBGarage Page   Reply With Quote
Old 03-22-2004, 07:51 PM   #12
Car: '94 Corvette
Be aware that the one I photo'ed is for giant 10ga wire, so everybody can see what makes them tick.
The 18 or so gauge posi-locks are much much smaller.
Here, I attached a photo to show.
Ron
Old 03-25-2004, 11:36 PM   #13
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
I love these because they will get you out of a jam. If you don't have the exact connectors you want to use, or don't have wire crimps on hand these are great for a temporary set up. If you're trying to figure out a wiring set up and don't want to waste permanent connectors these work. I keep some in the car for emergencies. The kind of thing you will need when you don't have it.
91DropTopTA is offline vBGarage Page   Reply With Quote
Old 07-09-2004, 10:23 AM   #14
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
how well do these hold up to underhood temps? i'm having bear of a time soldering wire extensions to the wires that connect to the back of the heads for grounding, and it would be sweet if i could just screw the 2 wires together instead of trying to solder them.
N8MAN1068 is offline vBGarage Page   Reply With Quote
Old 07-09-2004, 05:56 PM   #15
Car: '94 Corvette
It's made of a hard plasic, and can easily handle underhood temps. Wire insulation would melt long before these would.
Ron
Thread Thread Starter Forum Replies Last Post
Any bolt on aftermarket dual exhaust? 91 SrS Exhaust 5 10-07-2015 05:32 PM
Cable-X Speedometer Signal Converter TMZIrocZ350 Engine/Drivetrain/Suspension Parts for Sale 1 10-07-2015 01:09 PM
[MI] 2000 Camaro SS M6 meeklay812 Camaros for Sale 1 10-01-2015 04:46 PM
t56 crossmember that works with sw subframe connectors? tmork454 Transmissions and Drivetrain 0 09-29-2015 07:33 PM
2 Mystery Wires Gordonr1973 Electronics 0 09-29-2015 12:59 PM
Go Back   Third Generation F-Body Message Boards >
Tags
2003, connector, connectors, depot, disconnect, electrical, home, lock, picture, posi, posilock, review, reviews, silverado, tap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
