Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Holley Stealth Ram
Old 04-25-2007, 09:42 PM
WhiskeyChick's Avatar
Car: 1987 Trans Am GTA
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
Holley Stealth Ram
Hey,
I own a 87 GTA, low KMS, now I have heard that the holley stealth ram sometimes fits and sometimes doesnt.
I was wondering if someone who either has one or knows, could tell me the exact measurements. The height from the Base to the highest point at the front and back of the ram. Also the widths.
Im not willing to cut my hood at all, so I dont want to spend the money if there is a chance that it wont fit. Thanks for any info.
Chels
Old 04-25-2007, 10:08 PM
TransAM Joe's Avatar
Re: Holley Stealth Ram
Trans AM or Firebird with stock hood will NOT clear the Steath Ram, you must cut the under support so the plenum does not hit. Camaros will clear with the stock hood.
Old 04-25-2007, 11:10 PM
1989formula355's Avatar
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
firebirds with new polyurethane motor mounts will hit the cut out hood as well
Old 04-26-2007, 12:01 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Yup, what they said. Not sure what the big deal is with trimming the hood bracing, but those are the facts.
Old 04-27-2007, 01:41 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I'm a bit surprised that no one has mentioned this yet, but StealthRam.com should be able to answer most of the questions you may have...
Old 04-28-2007, 07:47 PM
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
Yea i have been there, checked there FAQ's n such, I just wanted actual dementions.
And as for the hood bracing, I dont want to cut it as they stuck it there for a reason lol. Just like people welding up the crumple zone gap.... crazy as far as im concerned, i want the hood to function as it was made to. (even if it is a minor brace)
Old 04-28-2007, 08:15 PM
well, then a stealth ram isn't for you. too bad mines for sale!
Old 04-28-2007, 09:14 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yep won't fit then. you can check out the corvette boards on the hsr some guys have made new upper boxes that fit however you would have to see if they would even build one for you
Old 04-28-2007, 09:30 PM
the amount of bracing needed to be removed really is pretty small, don't go saying it will compromise the integrity of the car like modifying crumple zones. pull down the under-hood insulation and take a look for yourself.
as far as modifying the plenum like the vette guys do goes: vette doghouses are expensive, 5 minutes with a whiz-wheel and some spray paint on a 'bird hood isn't.
Old 04-28-2007, 09:35 PM
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
i cut the hood bracing on my 87 GTA, it made absolutely no difference. the hood is just as strong as it was before. and now i have an intake that'll actually pull to redline on the tach.
Old 04-29-2007, 10:31 AM
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
I dont know how much bracing to cut because I dont know the dementions.
Thats what im asking for!!!!
I want to know is like 1mm or like 2 inches.
What are the dementions of the stealth ram?
I dont need anyone else telling me it wont fit with out cutting, blah blah blah.
I want exact dementions so I can go and check for myself.
Old 04-29-2007, 04:05 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
i can go measure mine in a couple of days, but lets say i gave you the dimensions, how exactly are you going to check it yourself if its going to hit the hood or not, are you going to lay on the engine and shut the hood on yourself with a tape measure?
Old 04-29-2007, 04:29 PM
FiXX90GTA's Avatar
Car: 1990 Trans-am GTA
Engine: 383 Stroker HSR
You said it yourself, If it involves cutting the under bracing of the hood, "i'm not interested".
Everyone here has given you the details to whats involved in installing the HSR. I personally installed it and only had to cut a small portion of the bracing right above the throttle body. You want measurements, 2 centimeters!!
Like said before, cutting is a small price to pay for an intake that will blow the doors off TPI. And yet not jeopardizing the hoods intergrity.
Old 04-29-2007, 05:31 PM
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
Thank you for the measurements, if you could that would be awesome.
And no, no measuring tape, there is a compund you can use its kinda like clay in the sence I can roughly shape it and put it under the hood to determine how bad it hits.
FiXX90GTA - those arn't measurements I can use but thanks. And actually no one has yet to give me what I asked, and just cause I wont cut my hood doesnt mean that other people wont. Also the stealth ram is only 1 direction im thinking of going so if I dont think it will work well for what im willing to do, Ill just go with something else.
Old 05-16-2007, 11:05 AM
CashMunson's Avatar
Engine: 408 LS
all you really need to do is shut your hood some and see where it's hitting the TB. once you see that spot, mark it with something and then cut out the area wider then the TB. I personally cut a large section out of my bracing, i cut out all the middle bracing, basically the entire area that the hsr takes up. i know i didn't need to, but i did it anyways.
Old 05-24-2007, 03:14 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
You won't have to cut your hood if you buy an aftermarket cowl
Old 05-24-2007, 08:09 AM
Shagwell's Avatar
Car: projects.......
cowls look like azz on birds - The ram air is sweet though...
- It's slightly different from car to car due to mount sag, hood alignement, etc. - Basically the TB on the HSR comes straight out, as where the TPI plenum angles it down slightly. Since it comes out square it runs into a section of the hood bracing, thus requiring trimming of the brace for a section about the size of the TB. - I have never heard of any one having any structural issues afterwards, as the factory has always a been a bit overkill. They have to build vehicles for the comon user, not someone who's actually going to take care of their car.
If you decide to trim the brace, just be sure you check clearnance for the linkage, the last thing anyone wants is to have the throttle stick.
Old 05-24-2007, 08:43 AM
GTA_IN_T.O's Avatar
anyone have any pictures we can see of where and how much was cut??
Old 05-24-2007, 09:19 AM
25thannivZ28's Avatar
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
Go with a Mini-Ram It has plenty of clearance & it gave me a definite seat of the pants difference in performance! Before, I would run out of motor @ about 5300, now it pulls hard to 6600 before I feel it necessary to shift before I blow the motor. My .02
Old 05-24-2007, 01:08 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
I bought a cowl hood.
Old 05-24-2007, 01:16 PM
Engine: 355 chevy
I took some pictures for you. This is with a BBK 58mm throttle body and poly motor mounts.
Old 05-24-2007, 01:20 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
I had a 89 GTA. I had a HSR. I milled 5/16 off the top of the base where the box bolts down.
It fit just fine then.
No I no longer have pics, I got rid of the car last year.
Old 05-24-2007, 02:47 PM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 4:11 posi
eXesiv|83ta where did you get that intake piping setup? It looks like it can handle ALOT of air flow.
Old 05-24-2007, 03:35 PM
Engine: 355 chevy
lol yes it can. I got the rubber elbow from http://intakehoses.com/. Good prices and fast shipping.
I got the 4in 90 I believe http://intakehoses.com/Merchant2/mer...gory_Code=9DEH.
As for the pipe I made that and I bought a K&N Filter for the end.
Old 07-23-2007, 02:51 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
That CAI looks great!
Old 02-08-2008, 11:11 PM
SovereignDragon's Avatar
Car: 1990 Trans Am
Engine: 305 TPI (for now)
Transmission: 700-R4 (for now)
Axle/Gears: 2.73 10 bolt (for now)
will this intake clear the edelbrock tpi strut tower bar. from the looks of it i'd say no.
Old 02-08-2008, 11:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
no it wont clear
hectre13
Car Audio
26
03-03-2022 05:38 PM
Linson
09-25-2021 07:55 PM
Royal_Z
09-30-2015 08:45 PM
dusterbd
09-29-2015 08:40 AM
mfp189
09-27-2015 09:25 AM
Quick Reply: Holley Stealth Ram
