Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
This is what im thinking of buying
Old 11-05-2007, 02:16 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Hi everyone. Im thinking of buying these things from SummitRacing :
EDL-3891 : Intake Manifold, High-Flo TPI, Aluminum, Natural, Multi-Port, Chevy/Pontiac, Camaro/Firebird, 5.0/5.7L, Kit $737.95
Link : http://store.summitracing.com/partde...?part=EDL-3891
EDL-68723 : Headers, Shorty, Steel, Ti-Tech Ceramic Coated, Chevy/Pontiac, Camaro/Firebird, 5.0/5.7L, Kit $449.95
Link : http://store.summitracing.com/partde...part=EDL-68723
FEL-35062 : Gasket, Composite, Water Outlet, Chevy/Pontiac, L6/V8, Each : $1.69
Link : dosent really need and link Smile
FEL-MS930351 : Gaskets, Manifold, Intake, Stock Port, Chevy, TPI, 5.0/5.7L, Set $35.99
Link : http://store.summitracing.com/partde...t=FEL-MS930351
This will make som extra HK right ? it will be noticable right ?
I really like the Edelbrock intake and the headers..
Is it good stuff ? dosent really know if I posted in the right section but if its wrong please feel free to move it
Old 11-05-2007, 03:38 PM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Re: This is what im thinking of buying
Go with hooker 2055hkr headers instead they have a 3" collector vs edelbrocks 2.5"
Old 11-05-2007, 03:50 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I agree... I'd go with a better set of headers than the Edelbrocks.
Old 11-05-2007, 03:52 PM
Theking's Avatar
Car: 1989 IROC-Z
they have AIR , coated and the Ypipe ?
summit is going slow today maybe someone could get me and direct link ?
how does it work with the AC and alternator ?
Do i need to build a custom bracket for the AC and alternator ?
I heard that the car can shake if you remove the brackets for the AC pump when you install headers ? right or wrong ?
Old 11-05-2007, 03:58 PM
http://www.jegs.com/webapp/wcs/store...59623_-1_10605
I didn't have any shaking issues with my car.
Old 11-05-2007, 04:29 PM
Theking's Avatar
Car: 1989 IROC-Z
but these cost over 800dollars with coating..
Old 11-05-2007, 06:04 PM
4playta's Avatar
Car: 1984 Trans Am
Get what ya pay for
Old 11-05-2007, 06:08 PM
Theking's Avatar
Car: 1989 IROC-Z
yeah but it will be really expensive to get it to sweden, because we have 25 Tax on that price and 6% customsfee so it will be very very expensive maybe $1082 (if you got the same taxes as I got in sweden)
So its not cheap getting things to sweden...
Old 11-05-2007, 06:29 PM
4playta's Avatar
Car: 1984 Trans Am
You have a few other options, you can buy the 2055's that are not coated, you can buy the 2055's and have someone coat them for you like jet hot, you can buy some cheap already coated headers and modify them and make a 3" collector. Anyway you look at it though you want a 3" collector so you can gain the benefits of a 3" exhaust...you dont want a bottle neck in there. If you have an exhaust shop by you the edelbrocks might be your best bet then just have the exhaust shop modify them.
Old 11-05-2007, 06:44 PM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
time to move to the good ol U.S.A
Old 11-05-2007, 06:52 PM
4playta's Avatar
Car: 1984 Trans Am
Or Buy a SAAB...ROFLMAO!!!
Old 11-05-2007, 11:59 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
i love my 2055's mainly because there is no collector gasket. it uses a ball and socket connection which makes a good seal. if you do alot of wrenching these headers will save ya alot in gaskets plus they install like a champ and all clearances are excellent.
Old 11-06-2007, 02:54 AM
Theking's Avatar
Car: 1989 IROC-Z
Do you have any pictures of the hookers 2055 ??
Summitracing dosent have any pictures of it.
Yeah, I hate all the f*cking taxes over here....
Old 11-06-2007, 03:16 AM
Theking's Avatar
Car: 1989 IROC-Z
how about this ones ?
SLE-30001C : SLP Performance 4-into-1 Stainless Steel Headers $634,50
Link : http://store.summitracing.com/partde...5&autoview=sku
HOK-2055HKR : Hooker Super Competition Headers 2055 $439,95
Its a shame that this ones isnt coated... Getting them coated will cost some extra $$$$ its not cheap to do it in sweden...
Old 11-07-2007, 07:51 AM
I went with Hedman's... they have A.I.R. hookups and 3" collector.
They don't have them listed but I know either Jeg's or Summit offers them in ceramic coating. http://www.jegs.com/webapp/wcs/store...47456_-1_10605
I'm not saying they are better or worse than the Hooker's, I'm just offering a cheaper alternative.
Hope this helps!
Old 11-07-2007, 12:43 PM
Theking's Avatar
Car: 1989 IROC-Z
But didnt seem like summit had them with Y-pipe, AIR and coating.. :/ I didnt find them thou..
Old 11-07-2007, 12:49 PM
You may have to call them... I talked to a rep at either Summit or Jegs a while back and they said they had the coated ones available.
Summit = 1-800-230-3030
Jegs = 1-800-345-4545
Old 11-07-2007, 02:03 PM
JustA305's Avatar
Car: 92 Convertible 25th Anniversary z28
Engine: Tune Port Injected 305
Transmission: 700R4 with 2200 stall
Axle/Gears: 3:42 with new posi unit
I have hooker super comp long tubes on my z28. They loved to eat up plug wires for a while but I got some header plugs to keep the boots off the headers and now its fine. I love them.
Old 11-07-2007, 02:06 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
unless youre building a show car coating isnt overly important, nice to have and its expensive to get done anywhere, not just in europe.
both the hooker and hedman shorties are the exact same design, the hookers have a slightly thicker flange which helps reduce warping but shuoldnt really be a big deal
and i wouldnt worry about ordering a Y pipe with it. I find youre better off just going to an exhaust shop and have them custom build your downtube and y-pipe. Only difference i see is in sweden exhaust shops probably dont have 3" stainless tubing on hand, prolly have to order it in.
also reccomend you drop the 50 bucks for some copper exhaust gaskets, makes for a much nicer seal and cant be blown out like the ones thatll come with the headers. Just note its a crush type gasket so the header bolts will all need to be tightened again after a few days of driving
not sure why ur worried about your accessory brackets? the headers install from underneath the engine bay, you dont need to remove any of that stuff just leave it as is.
haha and someone made a crack about saabs, my family owned a 92 saab 9000 turbo and as much as it looked like a little old mans car, that thing ran dead on with stock foxbodies
Old 11-07-2007, 03:42 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
when i got my 2055s i just hit them up with some high temp paint, still looking pretty good almost 2 years later!
kept all the rust away for 10 bucks, haha.
Old 11-07-2007, 04:52 PM
The_rabbit1's Avatar
Car: '87 Iroc
Engine: 350 .060 over
Axle/Gears: 3.70 9bolt
I'll sell you my used Edelbrock High flow tpi, same as the one you are looking at, pm me an offer.
midge54
01-29-2017 07:00 PM
Wylecoyote08
11-06-2015 03:46 PM
porkenstein
Convertibles
08-31-2015 12:54 PM
86White_T/A305
08-17-2015 12:16 AM
Dquickshift
08-12-2015 06:21 PM
Quick Reply: This is what im thinking of buying
