Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
torque converter???????
Old 05-16-2008, 12:55 PM
jimpfaffy's Avatar
Car: 1989 camaro rs
Engine: gmpp 350 ho
Axle/Gears: posi w/3.73
i am looking into buying a new torque converter im thinking precision or hughes or has anyone had any experience with acc converters? tell me what you know, all info is appreciated. thanks.
Old 05-16-2008, 01:32 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: torque converter???????
Im fond of Edge and Vigilante as ProBuilt Automatics is building my 700R4 and they offer these two brands to go in.
http://www.700r4l60e.com
Old 05-18-2008, 08:36 AM
JohnyP's Avatar
Car: 92 Camaro RS
Engine: 383
Transmission: t-56
Axle/Gears: 4.11
ive got a little shop in IL by my town this guy builds nothing but torque converters there the best ive seen specifically for what you need i can get the number if you'd like.....i know firsthand all of the ppl i know around that town and alot of ppl at the track we know use his.....probably cheaper too...pm me if you want
Old 05-21-2008, 02:31 PM
CHRISMAN2000's Avatar
Car: 1991 Camaro Z28
Engine: 350 L98
I just threw in an ACC boss hog stage 2 in my car.
Its not running yet. Hopefully next week.
I will let you know how its working.
Old 05-21-2008, 02:33 PM
dark_daku89's Avatar
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
x2 i have an acc boss hog behind a th350, should stall around 2800 rpm. Haven't ran the car either. lol
Old 05-21-2008, 02:47 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
love my edge. you get what you pay for when it comes to Torque Converters.
Old 05-21-2008, 08:15 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
I just bought a Vigilante converter from Dana a few weeks ago. Should be going in the car soon
Old 05-21-2008, 11:23 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Be sure to let us know the feeling...what stall? Lockup?
Also as I havent asked but what would the multi-disk 3-clutch for their TC's be for? It says for those wanting to have a full throttle lockup, would this mean, no matter the stall, when at full throttle the TC will lock up anyway? They dont describe it to much on their site as to the pros and cons of it...as I should mention my camaro will be a daily driver.
This is what I am trying to understand...haha.
A lockup torque converter of an automatic transmission for an automotive vehicle consists of an impeller connected to an engine, a turbine connected to the automatic transmission, and a lockup clutch disposed between first and second pressure chambers formed in a housing of said lockup torque converter for locking and releasing the lockup torque converter. A control unit supplies a hydraulic pressure into the first pressure chamber and withdraw a hydraulic pressure chamber from the second pressure chamber or reversely so as to actuate the lockup clutch to lock or unlock the lockup torque converter, respectively. A pressure regulating unit develops a pressure difference between the first and second pressure chambers when the shifting of the automatic transmission is detected, thereby causing the lockup clutch to allow the lockup torque converter to slip in accordance with certain conditions.
Old 05-22-2008, 03:54 PM
jimpfaffy's Avatar
Car: 1989 camaro rs
Engine: gmpp 350 ho
i was also wondering about the lock up feature on the vigilante....anyone got any experience with that? i think im either buying the edge 9.5 or the vigilante. and the boss hog converters are very nice now from what i heard the guy who bought the company used to be a jet mechanic and totally revamped the old crappy version so they should be much better by now. has anyone had any experience with the art carr 9.5 converters that brand seems really nice to. thanks for the advice so far guys
Old 05-22-2008, 04:05 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
PTC converters thay wont steer you wrong. I just picked up .15 in et with a converter swap I went from 10.20s to 10.05 in the 1/4 and did not loose any MPH. very happy. And thay have good prices also.
Old 05-22-2008, 04:08 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
Can someone tell me what a Torque Converter is really? Simplified for a car noob?
Old 05-23-2008, 10:00 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
A torque converter is a type of fluid coupling, which allows the engine to spin somewhat independently of the transmission. If the engine is turning slowly, such as when the car is idling at a stoplight, the amount of torque passed through the torque converter is very small, so keeping the car still requires only a light pressure on the brake pedal. If you were to step on the gas pedal while the car is stopped, you would have to press harder on the brake to keep the car from moving. This is because when you step on the gas, the engine speeds up and pumps more fluid into the torque converter, causing more torque to be transmitted to the wheels.
Old 05-23-2008, 12:59 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
So a torque converter gives makes more torque?
So if I have 200lbs tq, that converter might make me 210lbs tq?
Old 05-23-2008, 02:11 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Think of it as a manual trans for now.
You have to apply slight gas while letting out the clutch to allow it to move forward without stalling.
Well with a torque converter it works similar, you have to give slight gas before it can move forward or grab (except without the stalling possibility).
Now when purchasing a new TC and they ask you for Stall. Which is what you want the TC to GRAB COMPLETELY at.
So if I have a 2800rpm stall, my TC wont completely lockup until I reach this RPM
So if you have a 4500RPM stall your car will rev until a good 4,000rpm before it starts to move (grab) because the stall is higher thus making it not grab until higher RPMs.
Did that help.
Old 05-23-2008, 04:34 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
What's the purpose of a high stall over a low stall? Why even have a stall at all?
Old 05-23-2008, 05:29 PM
92 Formula's Avatar
Location: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
I've used Vigilantes on 3 of my F-bodies, all different stalls and would highly reccommend them.
You want your stall for your power band, btw, and that will depend on the car, the engine make up, etc...
Old 05-23-2008, 06:47 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
I have the ACC Boss Hog in my 92 Form 350. Works great.
Old 05-24-2008, 11:48 AM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
My car has a 2400 stall. If I upgraded to a 2800 I would be able to launch my car at a higher rpm and get better et's.
Old 05-25-2008, 11:28 AM
jimpfaffy's Avatar
Car: 1989 camaro rs
Engine: gmpp 350 ho
has anyone had any experience with the patc raptor parts? they look very nice and price is about equal. if no one has used them before then i may be the guinea pig for our forum. let me know what you guys think.
Old 05-28-2008, 10:22 AM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
i bought my stall and tranny from them and i am very happy with my combo
Old 05-29-2008, 11:26 AM
It's a 2800 stall with lockup. I haven't gotten around to installing the new motor and the new converter. Still waiting for my headers to come in and still have to finish painting the engine bay.
I replied to your PM, but I don't know enough to fully answer that question.
seiplentz
08-19-2019 06:02 PM
88rscamar0
09-23-2015 09:08 PM
Ragtop Man
09-12-2015 12:23 AM
Nick McCardle
09-10-2015 08:36 PM
Quick Reply: torque converter???????
