Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Don Davis race cars subframe and tower brace
Old 04-15-2010, 08:53 PM
mackjar66's Avatar
Car: 1989 GTA
Engine: pending install 383 tpi
My ride is now at Don Davis race cars in El Paso TX. He will be building my subframe connectors and a 3 point strut tower brace as custom one off pieces. With the subframe connectors he is also setting my pinion angle and deleting my torque arm so the rear end will be set in place at all times. If anyone would be interested in a group purchase I will be posting pics as soon as they come available and prices will be posted also. Each piece will be made off of my 91 formula. just subscribe to this thread for updates and pics then after seeing the work let me know if you want one made for your car also. If there is enough interest he will start to market his items for the thirdgen world. I would expect the finished product within a month and a half
Old 04-15-2010, 09:10 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: Don Davis race cars subframe and tower brace
so he's making it completely rigid in the rear? or putting some sort of ladder bar setup?
Old 04-15-2010, 09:32 PM
mackjar66's Avatar
Car: 1989 GTA
it will be similiar to ladder bar setup ill have to get some pics up of the impala he is working on now to give you an idea
Old 04-15-2010, 09:33 PM
mackjar66's Avatar
Car: 1989 GTA
but that car is four linked
Old 04-15-2010, 09:37 PM
mackjar66's Avatar
Car: 1989 GTA
hey my bad no ladder bar solid state fixed but we will be working on being able to adjust pinion angle
Old 04-15-2010, 09:40 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Why would you mount the axle solid in the car? You mean you will have no suspension in the rear at all?
Old 04-15-2010, 09:42 PM
mackjar66's Avatar
Car: 1989 GTA
ever seen a ford 8:8 rear end with upper control arms better yet imagine an adjustable independent rear mount, which will get into adjustable control arms also, right no my car is the guinea pig car, ill try to get a picture up of what was done to the impala but that piece was made for a set angle here is a link to his site
http://dondavisracecars.com/eight%20world.htm
Old 04-16-2010, 11:30 AM
built91Z28's Avatar
So the pinion angle will be set solid, not the rear axle? Your previous post made it sound like the axle itself will not move in the car. The equivalent of a hard tail bike. No suspension at all.
I'd defiently need pics to understand whats going on.
Old 04-16-2010, 09:28 PM
mackjar66's Avatar
Car: 1989 GTA
uh no tomorrow we take out the stock fuel lines and the BBK fuel pump to install my new lines and pump. I haven't found a good pic online of what is going on. but maybe this will explain it better. Delete torque are and install a bracket next to the rear end to set pinion angle, will still have rear suspension
Old 04-17-2010, 07:58 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Is it like the HTH truckarm setup?
Old 04-17-2010, 01:25 PM
mackjar66's Avatar
Car: 1989 GTA
no but that doesnt look bad I should be able to get pics of it today but just an example not on my car yet and I should be able to get pics of my new interior up as well in my other post
Old 04-24-2010, 02:10 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
You should have some pictures by now. The way you try to explain things is very confusing. We understand that the torque arm is getting deleted but what kind of suspension are you going to have? 4 link, 3 link, ladder bar, truck arm, etc?
Old 04-25-2010, 09:18 AM
mackjar66's Avatar
Car: 1989 GTA
ok the rear suspension will not change but the bracket for the rear end will change. no pictures yet as the framing for the impalas IRS is being powder coated. Also I can only make it out to the shop on the week ends bc the Army has me to busy during the week I'll post pics when I get them. As I said before this project is going to take a minute
Old 04-25-2010, 02:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
so it sounds like he is making the torque arm adjustable for pinion angle. Hope he is not going through all that hassle on a stock flimsy torque arm.
Old 04-25-2010, 03:21 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
this is a South Side Machine set up. (long out of biss after 15+ years)
the lower bars, pivet on a subframe cross member, up front (about 43" inchs forward) of the gears,I think this is a type of a set up, that hes talking about, or close.
(this is so you Guy get it)..lol
Forgive the rust and Dust, its been sitting for the last 8 years
SSM Hands down the Best SFC Ever made!!
and no torque arm. cant see it in this photo. but it's GONE, ya dont need it with this set up.
Old 04-25-2010, 03:28 PM
mackjar66's Avatar
Car: 1989 GTA
close just the pinion brace will be adjustable up top that will be connected to the subframe brace there will be no torque arm
Old 04-25-2010, 07:29 PM
//<86TA>\\'s Avatar
really going to have to see a pic of that
Old 04-25-2010, 07:48 PM
mackjar66's Avatar
Car: 1989 GTA
when it is done I will post pics right now I am still running my new fuel line and when that is done on to rebuilding my 350
Old 05-01-2010, 07:46 PM
sabien's Avatar
Car: 91 Camaro
Engine: 355 Carb
Transmission: 5 speed
Axle/Gears: 342 Posi
Looks like what Rolls Royce has been doing for years
Old 05-07-2010, 10:30 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
looks like a bad idea to me...
why would you do that. a torque arm is perfectly suitable to a car running slower than 9 sec in the 1/4
and it allows you to turn as well.
Old 05-07-2010, 10:35 PM
torque arms are not the best for drag racing
or every body would have them on there car
and mine drives just fine on the street,and it's fantastic for drifting fun also!
alot better the the old Goofy thing GM placed in the car..stock!
Old 05-07-2010, 10:43 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Ban without pics
1992 Trans Am
05-10-2023 07:19 PM
Terrell351
06-13-2021 01:13 PM
Nervous2
LSX and LTX Parts
03-10-2016 09:49 PM
IROCZ1989
01-24-2016 03:55 PM
NBrehm
08-05-2015 07:57 PM
Quick Reply: Don Davis race cars subframe and tower brace
