Turtle Wax Headlight Restoration Kit A++
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
I was simply amazed. 9$ @ Checker.
I decided to use it on the beater Cli-Taurus. After I saw that it worked, I moved to the plastic gauge/cluster sheild in the camaro. AMAZING
I think I'll hit the tail light lenses tomorrow and make them shine as well. Probably good for side markers also. Just brings back the shine to plastic.
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: Turtle Wax Headlight Restoration Kit A++
If your not a processional the 3M headlight resto kit is the best on the market. Other wise sanding, wet sanding, compounding, polishing, and buffing with the correct stuff is the way to go. Cheap fillers, glazes, and liquid products used by hand are a waste of time. For an amateur as long as the do it correctly and spend the time, the 3M kit can make a headlight look brand new from the factory.
Drone358
12-10-2015 08:16 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
