Spohn 3.8 V-6 K frame motor mount holes compatible with 2.8 v-6?
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
Hello All
I have a 87 RS Camaro 2.8 V-6 and want to put a Spohn K Frame under the car.
Spohn list a 3.8 V-6 compatability for motor mounting.
Is the 2.8 motor mounts the same location as the 3.8?
I don't get very far with Spohn folks on the phone.
I'm going through the entire under carriage of the car starting in the front... Coilovers, A-arms, etc. then heading towards the rear of the car.
I have a fab guy that can make me an adapter plate if it's not a mess.
Any help here is really appreciated!
Dennis
Dennis
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Spohn 3.8 V-6 K frame motor mount holes compatible with 2.8 v-6?
AFAIk, the 3.8 uses a different pattern from the SBC or the 60 degree v6 these cars typically have. you will need to make an adapter of sorts.
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
You can use the one with the SBC pads, some very simple brackets is all you need to adapt to the V6 mounts.
I have the SBC one but i made solid mounts to go to my FWD 3.5 block.
Car: 87 RS Camaro
Engine: LS6
Thank You Sirs!
I'm on it!
Dennis
I'm on it!
Dennis
ambainb
04-25-2016 09:21 PM
NBrehm
08-05-2015 07:57 PM
