Accel header spark plugs
1 Post
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
my experience is as follows... i replaced all eight bad plugs with these accel plugs i saw at the local parts store. Finished the install and started her up only to have a bad miss during idle. I hooked the timing light to each wire to test for spark and found three were bad. Checked my wires next thinking the plugs are new... Wires and cap all good. I went to the store yet again and picked up the acdelco reccommended for my ride. Swapped them all and she purred like a kitten... I'm not sure if you guys have talked about them before but i figured i'd give you guys my experience if it helps... In the future i'm sticking to delcos and ngks
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
Re: Accel header spark plugs
was forced to run the header plugs in my 88 chevy pickup, it ran just fine. had an extra set and threw em in my 73 pontiac lemans, also runs like a dream.
I havent yet to have a good experience with accel. neither wires or plugs. tried thier plugs and have bad miss fires on a brand new msd dis and moroso wires. now i only use the bosch header plugs.
Car: 1986 z28
Engine: 350 hsr
Transmission: probuilt 700r4/edge 2800
Axle/Gears: stock 4th gen 3.23
I also had bad experience with these plugs....car ran way better after switching to rapidfire plugs
1992 Trans Am
05-10-2023 07:19 PM
evilstuie
02-28-2016 03:33 PM
