PLASTIC REPAIR GLUE ???
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
I was wondering if anyone could recommend a good repair/glue . several of my under hood plastics have small cracks from mounting/bolt & screw holes to edge of plastic . function not affected , it just looks tacky . items I plan to repair , upper radiator support , hood latch filler panel , etc. . I do plan on painting after repair . any/all comments welcome , thanks ........
Engine: 4++,350 & 305 CIs
Re: PLASTIC REPAIR GLUE ???
I would say it would be easier to locate a undamaged part and paint that than worry about it breaking after paint?
I have a Camaro filler panel that was installed but never driven and is in excellent shape forsale if interested.
The choice for adhesives for use on "plastics" depends on the type of plastic you want to repair.
It would be much easier to find an undamaged part.
not a soul has tried to repair these plastics ??? I find that hard to believe .
Axle/Gears: 10 Bolt 2.73 Open
I don't know if this will help, but I was just reading about it today.
http://kk.org/cooltools/archives/23798
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
i used this when the tail light broke out of my truck (the mounting holes and clips broke off) and it has held for years
http://ecx.images-amazon.com/images/...500_AA300_.jpg
Car: 1988 Camaro
JB weld.... The fix anything epoxy.. http://www.jbweld.com/product/j-b-weld/
Works on steel, iron, alum, plastic, ceramic, etc. Can be sanded, filed, drilled, tapped for threads, etc once cured.
Resistant to water, gas, oil. Can handle up to 500* F,
Epoxy X2 best thing on car plastics, a little on the mating edges and a big gob on the back unseen side to reinforce where it cracked.
There re a lot of good products for what you want to do; it's just research to figure out which one is right / best.
I use 3M scotchweld stuff that's intended for plastic-to-steel. The competing product from Loctite/Henkel isn't cost effective because it's either tiny amounts with activator or huge specific gun applied tubes. The 3M is two tubes that last me years. Reach out to 3M with more detail and they'll direct you appropriately. The one I use is tough to find, but it's always available from industrial suppliers somewhere.
Since you're painting, your best bet might be a plastic welder also.
Car: Silver 1985 IROC-Z
Transmission: 700-R4
Permatex plastic weld, have had good luck with it repairing abs plastic. Kind of a creme color 2 part epoxy.
I've fixed plenty in my interior. I used Loctites super glue labeled for plastics. Some will say 'bonds plastic' but I specifically bought the one labeled for plastics. Very lightly sand and then use a super glue ACTUATOR which promotes adhesion. You can lightly sand again after the glue has cured and then follow up with paint (SEM, Duplicolor etc).
Car: 1988 Firebird Formula 350
Engine: L98 383 cubes Multipoint FI
Axle/Gears: Ford 9 inch with 3.70 gears
My best luck has been with JB Weld Plasticweld. It sands well and takes paint well. You have to clean the plastic first with Ethyl Alcohol (DO NOT use ISOPROPYL Alcohol!!!) The only thing I've but it on that it hasn't work so far is Delrin which none of the parts you mentioned are made of that.
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
The ABSOLUTE best plastic repair stuff I've ever used is urathane windshield sealant. A bit costly but if it's worth it to you...
plastic weld it... grab your solder iron and play around with it... if you can find a similar type plastic, you can use it for filler. when it cools, sand, dremel, dial it in. I have a bunch of different tips for my solder gun that ive made to help.
Uncle Tom, I have fixed so many plastic things this way. you will know right away if it is a plastic that can be welded. Some flows and sticks back together really well, as some other types dont so well. Some types will be durable and tough, and some will be for looks only.
There are some good suggestions here so far. GL
-Dan
-Dan
Car: 89GTA Black, Black cloth
Engine: LB9 26,000 miles
Axle/Gears: 3.45 Australian 9 bolt
get harborfreight plastic weld kit
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
There are different types of plastic compounds. You have to find the right kit for your type plastic
