Help with DataMaster/ WinALDL
Car: 1986 IROC Z
Engine: 5.3
Transmission: 4l60e
Alright, so i downloaded DataMaster and the winALDL program and also bought a OBDI 12 pin connector of the ALDL website.
My problem is that i cannot retrieve any data what so ever. All i want to do is simply read codes. The previous owner had REMOVED the service eng light and i recently just noticed that. I just want to see what its throwing out.
Any help would be appreciated thanks!
Car: 1986 IROC Z
Engine: 5.3
Transmission: 4l60e
Re: Help with DataMaster/ WinALDL
Does anyone have a clue on what i should do? Delete program restart? Is there anyway to adjust the COM? It said COM6 is ready, but when i plug the cable into the car it doesnt read anything. Any help would be sweet
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
1) fix your existing check engine light period, its part of the circuit you need to read codes.
2) you will have to find which port is active in your computer to set your port to.
3)Datamaster never liked any adapters other than their own(back in the day)
Your better off going TunerPro or TunerPro RT now.
Car: 1986 IROC Z
Engine: 5.3
Transmission: 4l60e
I did put in a bulb when i noticed it was missing. I read the codes the old way (counting the SES flashes) and figured out its throwing out a code 13, and 34.
Sorry if i'm sounding stupid, but how would i check to see which port is active? Any info is appreciated. Im almost ready to give up on these datalogging programs. I just seem to get them to work. Someone mentioned to me i would need to build a resistor between the A & B terminals in the connector.
Thanks for the reply!
If you haven't put a 10k ohm resister between a to b on the aldl the eco will not start data flow without this being done. DONT DRIVE IN 10K MODE ! Predestination will occur !
The 165 is a picky animal, some are reliable for connecting and staying connected.
Car: 1986 IROC Z
Engine: 5.3
Transmission: 4l60e
I know this sounds stupid, but how do i put in a resistor? Whats all in involved? Thanks.
Car: 1986 IROC Z
Engine: 5.3
Transmission: 4l60e
Thanks for the info!
Wow i must have been ripped off.. All i got was the cable and that was it.. Im going to shoot them an e-mail and see if they can send me one. If not i'll have to just buy one soon. That kinda bugs me a little bit...
Car: 1986 IROC Z
Engine: 5.3
Transmission: 4l60e
Okay problem solved. I didnt know the little piece on the usb part was the resitistor. Read the instuctions given to me with the cable and vwallaaaaahhh! Shes reading everything. Thanks alot!
