Climate controls light found alternate bulb replacement
Car: 1988 Firebird Formula 350
Engine: L98 383 cubes Multipoint FI
Axle/Gears: Ford 9 inch with 3.70 gears
Got a Firebird with the overhead climate controls light burnt out? I bet you discovered that part# 10045837 is impossible to get new and used ones are hard to find.
I discovered miniature LED license plate bolts are nearly dimensional the same.
https://www.superbrightleds.com/more...Specifications
These should be easy to retrofit into your dash no need to cut any plastic just need 2 washers to hold it in place and solder on the pigtail.
I'm going to order one I'm curious how much brighter / dimmer it will be over that tiny stock incandescent bulb.
Re: Climate controls light found alternate bulb replacement
Still waiting for some gauges to come in before I put the rest of dash together. Though the new LED light can't be dimmed its either on or off. I knew that ahead of time but I noticed I didn't mention it above.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You should be able to use a dimming module for that purpose. It flashes the LED on and off so quickly it isn't seen by the eye, I bought one for the LED's in my dash and it works very well, I bought it from SBL
Ghettobird52
12-29-2023 08:23 AM
