Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Hurst dual gate from partsplaceinc
Old 07-01-2015, 07:58 PM
modern0utlaw's Avatar
Car: 88 Iroc-Z
Engine: 6.2 LS3
Transmission: 4L70E
Thought I would put a warning out there to anybody thinking about buying a Hurst Dual Gate 2 from partsplaceinc. Their ad says the word "complete" multiple times but there are actually a few pieces missing. Most importantly the transmission control arm for underneath the car. Also its missing hardware like cage nuts and bolts. The mounting bracket for the neutral safety switch is also not quite right, the holes are too big to re-use the old ones and new ones aren't provided. My car is currently sitting un-driveable while I try to find replacement parts. I'll have to either locate a new control arm or try to modify the old one to work with the new cable. Hopefully I'll save a person or two from ripping out their shifter and cable only to find they need more parts, I know it would have saved me some headache.
Attached Thumbnails Hurst dual gate from partsplaceinc-ebay.png   Hurst dual gate from partsplaceinc-207.jpg
Old 07-01-2015, 08:13 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Hurst dual gate from partsplaceinc
That is definitely a bad-day-maker!!
So a person gets the shifter,
excited to put it in and go cruise, ONLY to find out the kit is incomplete!
On top of that, there is NO explanation stating " 'X' parts not included ".
A simple notice on the site would help a customer order needed items.
It is understandable the shifter can be used for other trannys, but at least give a
" Parts You MAY Need To Complete Installation "
Sorry to hear that still happens in the interwebs by a well-known company!!
Hope you're cruising soon!!!
Last edited by t-top havoc; 07-01-2015 at 08:14 PM. Reason: removed some blah blah blah
Old 07-02-2015, 06:50 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Honesty & customer service have never been Joe's (owner of The Parts Place) strong suits.
Old 07-02-2015, 05:05 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Damn,
Old 07-02-2015, 06:26 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
can you contact the BBB?
Old 07-05-2015, 08:18 PM
Car: 88 Iroc-Z
Engine: 6.2 LS3
Transmission: 4L70E
To give an update, I got a chance to work on the car again and I have everything mounted up in car. I went to my local lowes to get some hardware. I got some U-nuts, bolts, and sheet metal screws I needed. I've had to do an obscene amount of drilling, cutting, and bending to get the shifter assembly to fit just right. Right now I am waiting for a new control arm for the transmission to come in. Luckily I was able to find one using an original hurst part number I found online in some original instructions. I attempted to modify the original control arm to work but its a no go, I could never get it to hit all the gears properly. I was either not getting all the way to park or not getting all the way down to 1st. I'll post another update with pics of final installation after I get the part in
Old 07-07-2015, 10:58 PM
Car: 88 Iroc-Z
Engine: 6.2 LS3
Transmission: 4L70E
Attached Thumbnails Hurst dual gate from partsplaceinc-016.jpg   Hurst dual gate from partsplaceinc-011.jpg   Hurst dual gate from partsplaceinc-015.jpg   Hurst dual gate from partsplaceinc-035.jpg
Old 07-09-2015, 06:05 PM
firebirdbroni's Avatar
Car: 89 Formula WS6
How did you remedy the problem with the neutral safety switch?
Old 07-09-2015, 07:14 PM
Car: 88 Iroc-Z
Engine: 6.2 LS3
Transmission: 4L70E
I used some sheet metal screws slightly larger than the stock ones
Old 10-27-2015, 05:28 PM
SUPER CHEVY66's Avatar
Car: 92 camaro, 06 trailblazer ss
Engine: 5.0 tbi, 6.0 ls2
where did you find the control arm for this shifter as ive been unable to find one.
Old 11-08-2015, 09:42 AM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Boy, the arm on that shifter seems awful long
Old 11-08-2015, 04:29 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I have thought of trying to see if an original curved Oldsmobile handle (it seems a bit shorter) or an original straight Pontiac handle would retrofit onto the Dual Gate II and if it would look OK.
I also wonder if the handle in that put together "kit" is the correct part for the Dual Gate II or if it's for a completely different shifter assembly that just looks correct?
I bought one of these over 10 years ago and I'm still on the fence on whether or not to install it.
Old 11-08-2015, 06:23 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I think a LOT of the aftermarket shifters look tall in our cars.
Old 11-11-2015, 06:58 PM
Car: 88 Iroc-Z
Engine: 6.2 LS3
Transmission: 4L70E
The hurst part # is 105 0080. I think I got mine from hurstshiftersonline. Just google the part #
ZEEYAA
04-16-2023 08:29 PM
zman1969
10-01-2015 11:09 AM
Quick Reply: Hurst dual gate from partsplaceinc
