BMR crossmember ?
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
BMR crossmember ?
I ordered a BMR TH350 crossmember.
Can I route 3" exhaust under it, or does it hang down too low?
Couldn't find any threads on it.
-- Joe
-- Joe
Re: BMR crossmember ?
I have a single 3" off the turbo. If I try to route t in the factory location I need to change the subframe connector. Ugg.
-- Joe
Have you thought about going with oval piping? It costs a pretty penny but it might be what you need, Rather then changing the subframe connector which I'm sure will be a big PITA! Or another way to go would be to just fab one up by cutting up a stock crossmember and weld it up to where you need it.
-- Joe
I'm not going to cut it up and try to fix it, but it's kinda silly how far it hangs down vs stock. Unless the idea was if you hit something the crossmember will take the impact instead of the exhaust.... I dunno.
-- Joe
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
kammi10
11-09-2015 08:28 PM
tmork454
09-29-2015 06:33 PM
