Aftermarket Vendor Review Provide questions and comments about aftermarket part vendors for the Third Gen F-Body.
MSD
Old 12-29-2014, 12:43 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
MSD
Called msd today about a tach. problem an two words THEY SUCK cant get a straight answer from no one I called numerous times!!!!!!!!!!!!!!!!!!
Old 12-29-2014, 01:11 PM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Axle/Gears: 10 bolt 3.73 posi
Re: MSD
I love MSD's product range, but I do agree their tech service could use some work.
Old 12-29-2014, 02:46 PM
mr z28's Avatar
Re: MSD
That's for sure my tach doesn't work an told me buy 64$ 8920 tach adpter an now im stick with it an tach still doesn't work .
Old 12-29-2014, 07:27 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: MSD
and your sure your tach works (just asking)
what make is it? (the tach)
Old 12-29-2014, 07:43 PM
mr z28's Avatar
Re: MSD
Yes it works I had 2 an they both worked now im using a msd6al box an pro bill. dist an coil it doesn't work even with the wire direct from the cluster to the box msd said a 8920 adapter for 64$ still nothing. wire is white from tach. any suggestions please.
Old 12-29-2014, 08:01 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: MSD
Not sure what your setup is exactly but here is how I wired my 6A and billet distributor on my 84 TA. I am using the 8910 vs the 8920. I also found a 10K resistor inline with the tach wire had the tach working about 90%.
Old 12-29-2014, 08:44 PM
Re: MSD
like above.. look for what the closest wire set up to what your running.
it's simple..just need to work it out..
check grnd
check power
most of the time its the small things that get ya..
Fanatic1074
10-03-2022 05:57 AM
RedLeader289
05-28-2019 01:47 PM
sreZ28
10-22-2015 08:21 AM
meeklay812
10-01-2015 03:46 PM
86CamaroDan
09-29-2015 10:08 PM
Quick Reply: MSD
