Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
The so called "Turtle Ram" interest list.
Old 11-18-2008, 04:16 AM
  #151
convas's Avatar
Re: The so called "Turtle Ram" interest list.
Originally Posted by Ward
The HSR doesn't clear a firebird hood without modification. I'd be willing to bet it doesn't clear a C4 vette hood either, I know the TPI plenum is really close to the hood on those too.
This version fits.
https://usmracer.3dcartstores.com/In...19229-1-0.html
convas is offline
Old 11-18-2008, 07:13 AM
  #152
sol_searcher's Avatar
Originally Posted by TA
I spoke to BBK, and they said that the manifold is out for tooling. This particular manifold takes more time than most because of it's complexity of angles and multiple parts, so it should be ready in mid December.
TA
Did they say what year that December would be in?
sol_searcher is offline
Old 11-18-2008, 09:14 AM
  #153
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
For some odd reason it reminds me of a giant spider sitting on top of the engine. Power coat it black!
Z2EIGHT is offline
Old 11-18-2008, 01:21 PM
  #154
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
nope doesn't clear the c4 hood without modifying it.
89RsPower! is offline
Old 11-30-2008, 01:12 PM
  #155
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
so being bored i checked the site and realized they have it listed as a new product and the price says ZERO.
Im in, ship one to my house lol
BluFBdy is offline
Old 12-06-2008, 10:51 AM
  #156
MFaust89's Avatar
Car: 88 IROC-Z / 92 z28
Engine: LB9 / sbc of a station wagon
Transmission: 700R4 / t5.6
Axle/Gears: i have 2 now!!
Originally Posted by doc
I like my idea that I proposed here one or two years ago. An LS1/LS6 type intake for our L98s. Someone had posted that it would not work, but I still say BS to that. I'd be glad to help a company design it, I know how to do it.
not only L98s.. but LB9s too! its impossible to adapt one, but u can always use the LSx intake concept. i already drafted a TPI intake with LSx concept. i did a crappy draft during a boring class of design and tec. i will make a clear one in A3 paper on my christmas break and post here.
MFaust89 is offline
Old 12-06-2008, 11:08 AM
  #157
86 Money Pit's Avatar
Car: Blue 86 IROC-Z
Engine: 305 TPI, Soon a 355 TPI
Transmission: Auto, Soon a WCT-5
Axle/Gears: Nine Bolt, 3.42 posi
Summitt Racing already has this posted on their site for delivery starting in late December, price is $750 (far cry from the $400 target posted years ago but, probably in line with other TPI options).
http://store.summitracing.com/partde...5&autoview=sku
I actually like the look of this unit but would like to see someone build an engine (besides a stock L-98) to see where it runs out of gas. I really wish one of the magazines would put this in a smal block 383.
At that price you start to have other options that are well proven for making power.
86 Money Pit is offline
Old 12-06-2008, 02:51 PM
  #158
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
well, i smell a new camaro performers article in the mix lol if its got the performance that BBK is known for than id take one, the 750 is a hit to the wallet but if it holds true to their name im down
BluFBdy is offline
Old 12-06-2008, 03:08 PM
  #159
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Isn't this supposed to be the time of the introduction of the "turtle ram"?
The way I see it the LS1 style manifold is nothing more than an updated version of the TPI. They both have runners shaped like a question mark. I think the key is to shorten the TPI runners to the total length of around 13.5" like on the LS1. Also get the proper cross sectional area and taper then you would still retain the looks of the TPI but have an intake that functions like a LSx style. Hmmmm, I think someone has already made one up.
1989GTATransAm is offline
Old 12-06-2008, 03:11 PM
  #160
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
its all good in theory but will it work is the question, and will it out perform the existing intakes
BluFBdy is offline
Old 12-06-2008, 05:59 PM
  #161
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
Can't you just switch the ls1 intake and such to a l98?
robster66 is offline
Old 12-06-2008, 06:57 PM
  #162
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
sure ---in your dreams you can do anyting! :P
Gen3 is not compatible with gen1
avro206 is offline
Old 12-06-2008, 07:30 PM
  #163
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
750 is not bad compared to other TPI intakes. I think Im going to stick with my SuperRam for now. Id like to see further testing on modified engines. Hopefully the magazines pick up on it like GM high tech performance and do some testing on it and maybe a full build with it.
Fast92RS is offline
Old 12-06-2008, 08:41 PM
  #164
MFaust89's Avatar
do u know the inside of the LSx intake concept? here is a pic to give u a clue.. from what we know, in the LSx intakes, the first piston from the left side will be sucking air from the right side (second pic). the path of air (those chaped tube u see from the outside) will be on the top and the air going to the rest of the other pistons will be running under these paths(second pic). Adpting these concept to a small block, those paths will be going to the oposite side of the pistons in pairs. why? u dont have space between the two pairs of ports. the pics i did in Paint will help to understand.
Attached Thumbnails The so called "Turtle Ram" interest list.-lsx-intale.jpg   The so called "Turtle Ram" interest list.-lsx_cutaway_small.jpg
MFaust89 is offline
Old 12-06-2008, 08:44 PM
  #165
MFaust89's Avatar
here u have a quick "draft" in paint..
Attached Thumbnails The so called "Turtle Ram" interest list.-my-lsx-intake.jpg   The so called "Turtle Ram" interest list.-my-lsx-intake2.jpg   The so called "Turtle Ram" interest list.-my-lsx-intake3.jpg
MFaust89 is offline
Old 12-07-2008, 12:44 PM
  #166
Car: 1989 GTA
Engine: 369 TPI
I understand perfectly. I will say again each "individual runner" coming out of the plenum is shaped somewhat like a question mark in both systems. The difference is the runners are under the plenum with TPI and they are on top of the plenum with the LSx style intake.
Old 12-07-2008, 01:10 PM
  #167
MFaust89's Avatar
The LSx consept is pretty understoodable. The runners are larger at the beggining and then they straigh a little to match the ports size. At the same time, its a way of conpressing air. correct me if i am wrong
MFaust89 is offline
Old 12-07-2008, 05:05 PM
  #168
Car: 1989 GTA
Engine: 369 TPI
That is correct and it is called "taper". I think what we have here is a failure to communicate. All I'm saying is the TPI and LSx intake systems are the same basic concept. The LSx intake system is a modern and refined version of the old TPI system.
With work (make that a lot of work ) you can make the TPI intake system mimic an LSx intake system. In fact and easier to do is make a SuperRam mimic an LSx intake system.
Old 12-07-2008, 06:06 PM
  #169
MFaust89's Avatar
, but u would have to delete those runners on the botton and make them cross on the top..
MFaust89 is offline
Old 12-07-2008, 10:10 PM
  #170
86 IROC's Avatar
Car: 1991 Z28 - 2000 Z28
Engine: L98 - LS4
Transmission: 700R4 - 4L60E
Axle/Gears: 3.23's - 3.73's
I spoke to Richard Galley in person last week. I mentioned this intake to him and he wouldn't really say too much. Just the same I let him know I wanted one and would be willing to do some dyno testing with my bolt on car. They are building a new 44K SQFT DC about 20 minutes from where I live. I was a bit dissapointed to say the least when he wouldn't comment on the release date.
86 IROC is offline
Old 12-09-2008, 04:47 PM
  #171
TA
TA's Avatar
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
The unofficial Official word from BBK is that it will be releases in the first quarter of '09. The base will be specific for this intake, you cannot buy the upper and runners and bolt onto something else.
TA
TA is offline
Old 12-04-2011, 08:01 PM
  #172
???'s Avatar
did this thing ever happen?
??? is offline
Old 12-04-2011, 08:55 PM
  #173
Car: 1989 GTA
Engine: 369 TPI
No, but time sure flies. Hard to believe this discussion was going on three years ago.
Old 12-04-2011, 08:57 PM
  #174
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Nope, I got tired of waiting and got a good deal on a super-ram.
spurgeon76 is offline
Old 12-04-2011, 09:44 PM
  #175
???'s Avatar
yep, wow time flys.
i doubt i'd ever buy one, just wondering if it ever got released.
??? is offline
Old 12-04-2011, 10:22 PM
  #176
92droptopws6's Avatar
Car: 90 RS
Engine: 5.0 TBI
Transmission: Slushbox
OK lets look at this in another way it has been a VERY long time in the making, R&D does not occur quickly at all however if anyone who had wanted one of these intakes would have saved 5.00 dollars
per day since the original announcement of the making of this intake you could have an Lt1or an Ls1,2 or 3 by now,granted some DO NOT wish to do a drivetrain swap but really now look at the Capitol gains......PLEASE don't get me wrong I Love the L98 my friends and I were some of the first to get these cars to beat up the mustangs back in the day I am 42 now.Superram,miniram and the Stealthram are the best routes to take........ I realize some have to deal withthe EGR deal but fabricate a set up and use them suckers if in Comifornia well superram is your way besides the aftermarket runner and hogged out Plenum deal..., Real shame cause I had high hopes for this intake
92droptopws6 is offline
Old 12-04-2011, 11:12 PM
  #177
psy4s's Avatar
This was completed and can now be bought for small block fords. We were not in the mix. If you are still excited by the limitations of TPI the king Vic Edelbrock has the answer with his complete bolt on Edelbrock EFI LS throttle body based intake. Super sweet in black powder coat option. It comes complete, and is easy to program. Forget the turtle! Turtles are for FORDS. The Pro Flo is the future. At least for now.
psy4s is offline
Old 12-05-2011, 05:56 AM
  #178
TGO Supporter/Moderator
anesthes's Avatar
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Since the BBK intake is dead, I'm closing this thread.
-- Joe
anesthes is offline
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-22-2015 08:28 PM
3.8TransAM
09-17-2015 02:16 PM
blackandblue02
09-10-2015 08:19 PM
84 TA NV
09-06-2015 08:02 PM
rsrookie
09-05-2015 07:08 PM
Quick Reply: The so called "Turtle Ram" interest list.
