TPIS Minirams are finally selling (cheap?) on ebay
#101
1 Post
Car: 1992 B4C 1LE
Re: TPIS Minirams are finally selling (cheap?) on ebay
new miniram
http://www.ebay.com/itm/ws/eBayISAPI...m=230751833952
this one comes with FAST efi and injectors
#102
Getting ready to post up mine. It is a Miniram II (closely matches a 1205 port), BBK 58mm throttle body, fuel rails, 30lb SVO injectors, new Aeromotive FPR, brackets, all new sensors (excpet the IAC...that is still the original), the custom chip from a 1990 speed density (This is Traxion's old setup).
I am looking for $1100 for everything. I also have the roller cam (Custom Joe O cam) that this system was tuned around if someone wants to make a package deal. Car went 11.60@117 with this setup and AFR 190 heads.
#103
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
I might have copies of several of his BIN files...let me look on my computer at work on Monday. If I can find them, I would email them to you...free of charge. If you want the chip, we could work something out there too.
#104
I'm looking at this setup closely. I have a fully forged 383 with canfiled 215 heads and a procharger and really debating hard whether to do a "Blowthrough" or a system like this one for sale.
You guys are the gurus on this.
.A couple of concerns..
1).I'm guessing from the pics this is a Fast Classic. I read FAST does not work on them if there's a problem, but I'm hoping someone out there can. Also are the interfaces like datalogger still available...also the 2 bar map (I plan to run ~10-12lbs of boost)
2) Do you think this is a miniram or miniramII.. My 215 heads are 1206 gasket. so I'm a little concerned about port match up.
I've asked the guy for model numbers...but no response...
What do you guys think..
Here's the car I would put this in... I had listed it for sale a while back..so never mind the For sale part...
http://www.ls1tech.com/forums/vehicl...ger-fs-ft.html
#105
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Getting ready to install a Miniram and could use a good base tune to start with
#106
1 Post
Car: 1992 B4C 1LE
#107
1 Post
Car: 1992 B4C 1LE
Worst ebay ad ever! Its a miniram with goodies, new'ish, read the description
http://www.ebay.com/itm/ws/eBayISAPI...em=26106520617
#108
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Gone.
#109
1 Post
Car: 1992 B4C 1LE
#110
1 Post
Car: 1992 B4C 1LE
#111
1 Post
Car: 1992 B4C 1LE
not a miniram but..
http://cgi.ebay.com/ws/eBayISAPI.dll...m=120989747081
#113
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Well I got lucky. I traded my 13 year old Super Ram for a Miniram straight across the board.
#114
1 Post
Car: 1992 B4C 1LE
Speaking of super rams
http://www.ebay.com/itm/-/2611032620...m=261103262091
How about a gen 6 ECM with an 1985 TPI 870 ECM adapter harness
http://www.ebay.com/itm/Accel-DFI-Ge...-/261103202865
and cable to go with it?
http://www.ebay.com/itm/Accel-DFI-Ge...-/261103207912
#115
1 Post
Car: 1992 B4C 1LE
Another Super Ram
http://www.ebay.com/itm/ws/eBayISAPI...m=221147370444
#116
Is there such a thing as a Corvette lower? A g for the manifold only too, I paid that for a running HSR set up with two Commander 950's and a MSD Pro Billet w coil and a back up cap. I want one to be able to compare. Not for a 1000 samolians though.
#117
1 Post
Car: 1992 B4C 1LE
A miniram at a good deal. $1k with a billet accel/lingenfelter throttle body, injectors, and rails.
This is the exact thing I was talking about in my op. There haven't been as many lately, but I think we will continue to see them and then they will end up in the hands of collectors/serious thirdgen guys and just dry up.
http://www.ebay.com/itm/321024924025
#119
1 Post
Car: 1992 B4C 1LE
Miniram!
http://www.ebay.com/itm/140891677248
#120
1 Post
Car: 1992 B4C 1LE
Miniram!
he responded: "1204"
#122
1 Post
Car: 1992 B4C 1LE
Because anyone interested in paying $1000 for an intake like this should know that it is only port sized for a set of stock heads.
Not for a set of $1300 race heads.
Not for a set of $895 aluminum street performance heads.
Not even for a set of even Edelbrock performers.
But you definitely could always port match them if you get them cheap enough.
I noticed the seller was afraid to add our question/answer to the ebay ad as is customary.
#123
On Nov-28-12 at 08:50:04 PST, seller added the following information:
Gasket 1204 standard l98 port size
#124
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
-- Joe
#125
1 Post
Car: 1992 B4C 1LE
Thanks for adding that Joe. I didn't know.
#126
1 Post
Car: 1992 B4C 1LE
Super ram
http://www.ebay.com/itm/190764031800
#129
1 Post
Car: 1992 B4C 1LE
Another accel
http://www.ebay.com/itm/251234435140
#130
Now that there are 23 degree heads big enough to feed 427 SBCs (header and valvetrain fitment issues always turned me off of the exotic heads like SB2.2, 15,18*) I wonder if the Miniram would be up to the task?
I see in the beginning of this thread someone mentioned it was confirmed to handle 500rwhp, wonder if that could be pushed a bit. If not I wonder if there is a SBC EFI intake that IS up to it in something like a 4.125" x 4.00" 427 w/AFR 245s and a solid roller in the 25x/25x range with .700 to .750" lift?
#131
1 Post
Car: 1992 B4C 1LE
For the most part in more exotic or large sized engines it comes down to its usage. Are you going to build a big grunty mild 427 that will not rev high? Or are you going with an expensive piece and spin the wee out of it?
What about a power adder? Blower? Turbo? Nitrous?
How about engine packaging? Many guys with vettes run a miniram on all manner of engines due to the hoodline clearance. With us thirdgen guys we have affordable cowl hoods to give us more space.
With the increased space we might use to run a huge carb style manifold that has been modified, converted, and plumbed for port EFI. Sure a miniram is comparable to a few singleplanes, but not all of them.
What would you give up between a miniram and a say a brodix singleplane? A few hp, lets just call it anywhere from low single digit to mid double digit horsepower.
So in closing it always comes down to, what you are going to do with it, what you have considered in packaging, and which power adder if any you are planning.
#132
A solid roller cam in the range I was talking about would probably want to spin to 7000-7200, just wonder where the newer, bigger port 23 degree heads like to be. Nothing crazy RPM wise, just enough to hit 600-650 at the crank naturally aspirated and have enough street manners to drive occasionally. I would put in an "exotic" valvetrain though just for insurance. Titanium retainers, Jesels shaft mount rocker arms, belt drive, etc. I hate cowl hoods, just don't like the look even though I know they have their place on the track. The almost factory look/fit are plusses for the miniram in my book, I just always figured it would hold back a set of big heads.
#133
1 Post
Car: 1992 B4C 1LE
A solid roller cam in the range I was talking about would probably want to spin to 7000-7200, just wonder where the newer, bigger port 23 degree heads like to be. Nothing crazy RPM wise, just enough to hit 600-650 at the crank naturally aspirated and have enough street manners to drive occasionally. I would put in an "exotic" valvetrain though just for insurance though. Titanium retainers, Jesels shaft mount rocker arms, belt drive, etc. I hate cowl hoods too, just don't like the look even though I know they have their place on the track.
http://www.eecis.udel.edu/~davis/z28...no/dyno051125/
https://www.thirdgen.org/forums/alte...am-intake.html
#135
1 Post
Car: 1992 B4C 1LE
Another Super ram
http://www.ebay.com/itm/321107082782
#136
1 Post
Car: 1992 B4C 1LE
ASR base and SLP siamesed runners
http://www.ebay.com/itm/221215322741
#137
1 Post
Car: 1992 B4C 1LE
another ASR
http://www.ebay.com/itm/121130471918
#138
1 Post
Car: 1992 B4C 1LE
miniram, not cheap.
http://www.ebay.com/itm/321150339873
I asked him if he knows what gasket size it is. Response pending.
I would like to mention to any of you actually considering buying one of these that if you think the price is too high, you should still watch it so that when it gets relisted over and over you can watch the price fall each time. Eventually you might like the price.
#139
Car: 92 T/A 'vert
He have to re-list it a lot to pique my interest.
#140
1 Post
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
$1700 for a new miniram?
Wow. I wonder how much for a used miniram with powdercoat and polish that looks and works as good as new?
That said,
I kind of like my miniram. It looks really cool at the car shows.
That said,
#141
1 Post
Car: 1992 B4C 1LE
He responded, and 1256 was that gasket size. That is stock.
Yeah I think he is being unrealistic about his price considering the ones I have been seeing sold in the $675-$850 range.
#142
1 Post
Car: 1992 B4C 1LE
Accel super ram
http://www.ebay.com/itm/161065233598
TPIS miniram
http://www.ebay.com/itm/121142696497
TPIS miniram
#143
Car: 92 T/A 'vert
They're both crazy.
#145
Car: 1986 z28
Axle/Gears: 3:73
im crazy too! im selling my mini ram II 1205 port size with rails, lines, rgulator and 24# injectors comes with holly 58mm tb
$1300
iv never had a problem tuning it with the megasquirt
$1300
#146
Absolutely ridiculous. Good luck with that pipe dream. You could buy a new HSR or single plane with new injectors and throttle body for less. Even more ridiculous is that you could buy a used LS engine for less than what you are asking. The purpose of this thread is to educate others that mini rams are NOT worth that much and if you pay that you are wasting your money. Much better options for the same or less. And of course that is tunable.
#147
Car: 1986 z28
Axle/Gears: 3:73
#148
The mini-ram is a joke. It's things like that, that make me want to put a carb on my new motor! Almost $900 for an aluminum casting, and almost $400 for fuel rails?! Eff that!
#149
Car: 92 T/A 'vert
If you want to stay MPFI based, an HSR is much cheaper with very similar performance results. But, I'm holding out for a 1204 Miniram as I don't want to ditch my BMR 3 pt. STB. Patience, grasshopper!
