TPiS MiniRam Owners, experiences wanted.
#151
1 Post
Car: 88 Trans Am GTA
Axle/Gears: 12 bolt 3.73
Re: TPiS MiniRam Owners, experiences wanted.
12.51, 12.35, 12.36@110. 60's were 1.75, 1.72, 1.73 car weighed 3810 with me in it. Got some data so will see if anything is left in it.
#156
1 Post
It's tuned. Every calculator I have used has me right about there time and mph wise. 118 would put me at 11.47 to 11.5.
#157
1 Post
I am only a 350 with a lt4 hotcam, 1.6 rockers, tf 195 heads, hooker lt, and 4" sinister exhaust. My compression ratio is just a touch under 10.1. Car made 375 rwhp and 350 rwtq.
#159
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Ok! I thought you had a Stroker. 114-115mph range for you at least. Get more air through the intake. What year is the car?
#160
1 Post
Not stroked yet, I do have a nice cranks and rods for that though. The thing that is killing me is lack of compression. Going to try and fab up a ram air setup that I can pop in for the track. Seen where guys have picked up quite a bit doing that. If I get a 1.65 or better 60 then I will be at 12.2 and if the ram air setup works as good as some say I can start flirting with 12.0's.
#163
1 Post
How is the miniram with boost? Are there any known issues with distribution or anything like that?
#164
1 Post
Car: 91 Z-28
Engine: 420 sbc
Axle/Gears: 12 bolt/4.10 gears
I've had a procharger on my minirammed engine for a couple years now and haven't noticed any issues other than the idle distribution. I run it a little rich for piece of mind but no problems at 10 lbs of boost. High boost might be different story.
#165
1 Post
I want to say I seen something about the hsr not being boost friendly. Didn't know how the miniram was.
#166
1 Post
So the local 1/8th mile track has a street tire shootout on friday nights. I have been gone or busy so my buddy has been tracking the car. With street tires and a progressive controller the car is running 99 mph in the 1/8th. I still want to remove the front sway bar, passenger side fog lamp, and cut a hole underneath the filter to get more air and see what it does on motor and bottle at the big track. When I do that I will have the drag tires on.
LT1Formula
20
11-14-2015 12:02 AM
Sanjay
08-12-2015 03:41 PM
