Aftermarket Intakes- is it just MY project?
Getting down to the short strokes of a re-rebuild- really hate these....anyway the engine was poorly put together a few years ago and am redoing the 355 to a 383. The block was zero decked before and now the pistons are slightly proud with a .050 gasket giving me .035 quench- not the issue here, I was using the Edelbrock vortec HiFlo base and had no issues with fitment- now using FIRST and the intake doesn't fit and will have to be milled- the afr's were 'cleaned' up but no major surfacing done. I assumed the shop who does high dollar engines sees allot of these conflicts- they said not really.
Just wondering what the other experience is out there- I'm taking this as another aftermarket product that 'almost' fits.
Car: 1985 Corvette
Engine: 383 Single Plane
Re: Aftermarket Intakes- is it just MY project?
My Procomp Hurricane is in the machine shop now, wont line up with my 383 zero decked block and Edelbrock CNC heads.
And I thought this stuff only happened to me !
So there's two brothers who build, the one I had build me the 383 does street mostly- the other brother does race mostly, the race guy says he does it regularly. Anyway manifold is on.
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Nothings bolt on once you stray from stock
correcting stacking tolerances and somtimes tuning parts up just goes wiht the territory. Be patient and get it good as you can
Honestly a perfect port match isnt THAT important just get it close as you can..better to have the intake a touch undersized than over then run it.
Car: 1985 Corvette
Axle/Gears: 4.11
Only to have a crack smoking line worker do their own re engineering upon assembly LOL
Car: 1985 Corvette
the manifold up against the right head has 0 clearance at the top and .010 at the bottom, on the left head it has .020 at the top and .012 at the bottom (and when i say bottom I mean just before it gets to the china wall)
these measurements are consistent front to rear with a (already crushed) 1205 gasket and hand tight bolts in place.
i ran it with felpro 1205 .060 thick and it was sucking in oil on overun into cylinders 2 and 4, oiling up the plugs,
i put on a mr gasket 102 (1206 port equivalent) .065 thick and it was even worse !
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
-- Joe
Car: 1985 Corvette
I have to move house soon so there is a lot of other stuff to do now, cant go tearing into the engine bay too much, and I am running a hillclimb on 7/11 so just need the engine sorted asap.
This is an aftermarket intake- if it were a GM unit I would agree, and since I haven't measured the intake....but when I port matched to GM vortec plastic gaskets the manifold bolt holes were in question for at least 2 holes. So I have question the machining quality of the manifold.
Car: 1985 Corvette
One issue that was corrected was the gasket surfaces were not completely flat, there was a bow (leaving a gap at the inlet ports) from water port back to water port .
Got the manifold back, sitting on the engine with a few hand tight bolts and 1205 gasket it is now perfect, you can hardly get a .003 feeler in anywhere.
-- Joe
FIRST is an american intake- but still aftermarket, expect anything.
Hurricane is chinese? It would not be unexpected to pay for correction over a similar higher quality domestic intake- and I by no means hold Edelbrock to be THE standard.
If you deck the block, mill the heads, and then add maybe a bad day at the foundry for the intake you could be way out. I've flatened intakes on the belt sander but i'd don't normally change the angle because then the intake is junk if I need to use it on another motor. I guess for a $200 intake who cares, but you wouldn't go doing that to a miniram for example. You would never be able to sell it.
-- Joe
