Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Drivers side injectors
Old 07-05-2015, 03:43 PM
soarestransam's Avatar
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
Ok so i did the hsr set up and now im not getting the drivers side injectors to spray fuel (drivers side header isnt hot) i can hold it after it starting and running for 2 minutes) what causes this i also have switched over to speed density using the ebl flash p4 kit i havent actually hooked up a laptop to it yet to see what is going on in the ecm maybe a wiring a problem thats what i would guess
Old 07-05-2015, 10:09 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: Drivers side injectors
You have 2 separate fuses supplying power to the left and right bank injectors. Seeing how the whole bank is dead, probably the fuse for that bank. HTH!
Old 07-06-2015, 07:29 AM
Well i really think its the pin relocate for the ebl flash system since im not using the ebl flash system ecm yet i think this is the reason why the drivers side bank isnt getting power
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
kyleb24
08-15-2015 08:24 AM
Street Lethal
08-14-2015 08:25 PM
timonator
08-11-2015 09:56 PM
wruiz
08-11-2015 02:59 PM
Quick Reply: Drivers side injectors
