Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Lifter question
Old 07-26-2015, 10:10 PM
Rob's 92 gta's Avatar
Car: 92 firebird gta
Engine: L98 with minor mods.
Lifter question
I have a comp xfi 280 cam and was wondering if the Chevy performance roller lifter for 305/350 and Ls1,Ls2 and Ls7 will work for what I have. Thanks for the help. I posted this on the engine forum. I wasn't sure where I needed to post the question.
Old 07-28-2015, 01:42 AM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Re: Lifter question
Lots of guys use the ls7 lifters. That's what I'm using with my 224-240 .570s lift xfi cam and 195 AFR comp ported heads...I'm dong the swap now.
Old 08-24-2015, 07:02 PM
Abubaca's Avatar
Car: 1988 Iroc
Engine: L98 350
Axle/Gears: Hawks 8.8 - 3.73
Re: Lifter question
You need longer pushrods though, right? ...I suppose you should always measure though.
Old 08-24-2015, 11:15 PM
Car: 92 1500p\u 2wd
Re: Lifter question
Just changed my lifters cam and head and looks like my pushrods are going to work so far....same ones I was running before
Old 08-25-2015, 08:47 AM
86redIROC's Avatar
Car: 1986 Iroc Z 28
Engine: 383
Transmission: 4L60
Re: Lifter question
Why such a large split in duration?
Old 08-25-2015, 04:26 PM
Car: 92 1500p\u 2wd
Re: Lifter question
Sorry 224-230
beastin91rs
10-09-2015 07:38 AM
Mickeyruder
09-02-2015 02:45 PM
SLNTSCPE
08-22-2015 09:15 PM
Cameeeero
08-20-2015 03:06 AM
redmaroz
08-16-2015 11:40 PM
Quick Reply: Lifter question
