TBI to port fuel (pics)
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Re: TBI to port fuel (pics)
I didn't know you had a c4. Was it crossfire originally?
-- Joe
-- Joe
yes. Crossfire to XRam to Holley projection with 7.4L TB with 75 lbs injs @21 lbs FP. Now port fuel. Car runs so much better. That 2.0 inch bonnet had the inj pods blocking air flow I believe at 5800-6000. Not much room under bonnet. Plus the fuel control may have been compromised being TBI. Port fuel solved a few issues with drivability. EBL Flash is ECU. Prior hardware 4 sale in classifieds.
How does it idle wit the 224 cam? How much manifold vac? I know it would have a bit of a lope in a 350...
I get about 14-15 inHg with my 212 cam in my 350, and it idles pretty dang smooth, so that'd be my reference point.
Also, how much are you putting down with it?
Idle was Ok with the TBI BUT that was OL with VE cells flat around the map/rpm it idled at. That was 775-800(wander) with a manual trans. Idle spark locked at 20.
Now I am CL idle at 825 with a stock LT4 tune. Does not wander and cells are not flattened. Sa locked 20. I only put 25 miles on car since the induction changed. So the cam is not too radical. 114 LSA helps but I should have used a 112. When the cubes get upped next year or two I will use a 112 LSA with more duration.
I think the fuel distribution is 10X better with port fuel vs TBI.
I am idling at 48 MAP. With prior manifold I was at 44. I lost vac. Might be the larger intake 1000cfm TB vs 600 on prior.
Fast355
12-02-2016 06:33 PM
92camaroJoe
08-13-2015 06:07 AM
