Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR or aftermarket TPI?
Old 04-03-2016, 10:16 PM
Prodigious's Avatar
Car: 92 Z28 Camaro
Engine: 355 TPI
Axle/Gears: 10 Bolt 2.73
I have a 92 Z28 with a cammed 355 TPI mated to a 700R4 with the stock stall and a 10 bolt with 4.10 gears in it. I have to say, the torque from the TPI, the low first, and the 4.10s is astonishing. However unfortunately it also blows away my 245/50/16 tires. I would like to keep the 4.10 rear end gear ratio, but get a higher stall and do some intake modifications. I don't know what would be best for my setup though, keeping TPI and going for wider and stickier tires or simply getting a stealth ram. Either way I plan to go up on the stall speed, but I would like you guys' advice.
Also bear in mind please that I nor the previous owner have any idea what specs the cam the motor is running are. He simply said that it was not the stock cam but he didn't know the specs.
Sorry if this is not in the right category.
Old 04-08-2016, 06:59 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: HSR or aftermarket TPI?
Stealthram
Old 04-09-2016, 12:12 AM
Prodigious's Avatar
Car: 92 Z28 Camaro
Engine: 355 TPI
That's what I figured the best answer would be. Any particular reason you would recommend that?
Old 04-12-2016, 10:04 AM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
I love my HSR. Though i have no idea what to gauge it from other than a carb. The power and response compared to the carb is incredible, much more top end, and throttle response, so you know where my vote is.
Old 04-12-2016, 10:06 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
What carb were you using?
Old 04-12-2016, 10:43 AM
bwmcam's Avatar
Car: 1987 IROC Camaro T-Tops Rule!
Transmission: 700r4 Pro Built / 2600 vigilante tc
What do you use the car for?
Old 04-12-2016, 02:04 PM
Car: 86' IROC
Axle/Gears: 3.45
It was a holley 670 street avenger
Old 04-12-2016, 03:14 PM
SR71BLKBRD's Avatar
Car: 92 Firebird, 91 GTA
Engine: 305 TBI, 350 TPI, * LS1 (Building)
Id say stealthram with simple reasoning. I had a 350 tpi with stock 3.23 gears that I still couldnt launch. first through third I could get it in different directions. The low end torque is what the TPI is for. the long runner makes its low end power and runs out of gas top end. Im building my 383 to change the torque curve and give me a bit more on the top end. If you throw a stealth ram on it the low end with those 4.10s should get the hell out and itll breathe better than the long restrictive runners of the TPI on the top end.
Old 04-21-2016, 10:41 PM
BLWR PWR's Avatar
Car: 89 IROC
Engine: Built 383, Vortech SC
Transmission: Pro-Built 700R4
Axle/Gears: Dana 44, True Trac, 3.54
MT drag radials. With 4.10s, the low 1st gear in a 700r4(3.07?), and a higher stall, say2800 or 3000, youll never get a launch on street tires. Doesn't matter what intake is on there.
Old 04-21-2016, 11:37 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Suspension/tires. Any other answer is ...not the answer.
You're power level should have zero issue maintaining good traction with proper suspension and tires.
Old 04-22-2016, 08:14 PM
Prodigious's Avatar
Car: 92 Z28 Camaro
Engine: 355 TPI
Thanks for all the answers guys, it really helps. Although I have the stock stall and some bfg gforce supercomp 2 245/50/r16 tires on, subframe connectors that I recently had welded in helped my launch TREMENDOUSLY. I also advanced my timing which helped top end. I currently have new Bosch injectors coming in as well as an AFPR to install that I'm sure will help further.
Back to the thread topic though, it seems that the general consensus is that I get an HSR as well as some drag radials to run at the track. Any different/additional suggestions? Maybe aftermarket LCA's?
Anyways I would just like to say with my current tires (however skinny) and my SFC's seems to be putting the power to the ground like a champ with the 4.10's. The car launches ridiculously hard right now compared to before, however it still needs a lot of help in that department. Although I'm positive the top end will benefit greatly from new fuel injectors as well as increased fuel pressure.
Old 04-29-2016, 12:21 PM
irocman7's Avatar
Car: 89' Sunset Metallic Orange Iroc-Z
Engine: Forged 383
Transmission: TR6060
Axle/Gears: 4.11 9 inch
I had an aftermarket TPI (Edelbrock bottom, SLP runners) and it seemed like the more I did to it the more traction problems I had. Especially once I swapped over to a T56. The torque made it felt great, but nothing compares to the way my Stealthram pulls up top. Night and day difference.
For your situation, you really need to match it to your combo. You need to find out the specs on the cam, so you can match the rpm range to your intake.
Old 04-29-2016, 01:12 PM
Prodigious's Avatar
Car: 92 Z28 Camaro
Engine: 355 TPI
Is there a way I can find out the specs to the cam without pulling it out?
Old 04-29-2016, 01:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Hands down stealth ram will out run tpi with those gears and a cammed car. Up the shift points
Old 04-29-2016, 06:11 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
FI Tech EFI.Good to 600 HSP.
Old 04-29-2016, 09:42 PM
irocman7's Avatar
Engine: Forged 383
Most aftermarket cams have grind numbers on the front or the back. If u pull it out you can check the lobes with a caliper.
Orrs right though with what you know now Stealthram will out run any TPI setup. Cost is about the same for both intakes. Also, tuning is going to be as important as the intake in reality.
Old 04-30-2016, 12:21 PM
Prodigious's Avatar
Car: 92 Z28 Camaro
Engine: 355 TPI
So stealth ram and learning how to tune will be the biggest things I should do at the moment?
Old 04-30-2016, 10:21 PM
irocman7's Avatar
Engine: Forged 383
That all depends on your budget, and what your goals are. The part that would help you better plan the combo out is finding the unkowns are. Like what cam is in it.
Tires will probably should be high on the list to help u the most. 411 gears with 700r4 is going to be a challenge to launch period.
I always thought it was good to start tuning before you do a lot of changes, of course I started learning after I did the topend.
Old 05-02-2016, 04:39 PM
Steve Mack's Avatar
Car: 87 Iroc
The FI Tech fuel injection system is self learning .It sells for under $999.They always tell you how easy it is to learn to tune your Camaro on this site.But it never is.
Old 05-02-2016, 04:58 PM
Engine: LB9
Axle/Gears: 3.08
The factory Ecu is self learning and free.
Old 05-02-2016, 06:10 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
255 drag radial will handle that setup at the track. Street, it will help first gear but it wont take all of throttle til higher in rpm band.
I like the 730 ecm. Its not super difficult to learn it. Just need to get your feet wet and ask questions. People will help as long as you make an effort to read as much as you can
Wideband o2 is a must imo. Will make the process easier, and really is the best way to dial in wot. Get it right on the street first before dyno or track tune. And by right i mean get it in the higher 12's to 1 ratio as a baseline. Rich/lean from there.
Old 05-03-2016, 11:24 AM
Steve Mack's Avatar
Car: 87 Iroc
Yea right.Try putting 30# injectors in and see how well it self learns.You'll flood your motor with gas and melt your catalytic converter.
Old 05-03-2016, 11:28 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Theres a way to set up spreadsheets to do ve learns based on some wideband data and copying your datalog output but i dont know of a way to make that on the fly.
Code $59 has a way to do closed loop wideband control but i never attempted it
Old 05-03-2016, 11:30 AM
Engine: LB9
Axle/Gears: 3.08
So you've done that with the computer you're advertising?
That's pretty cool that a computer can read your wot fueling, optimize timing, and adjust injector constant while knowing it needs to do so. Is it made by skynet?
Old 05-03-2016, 11:36 AM
Engine: LB9
Axle/Gears: 3.08
With enough free ram space you could create a 3d LU table in ram FOR VE and write a subroutine to alter it as needed based off wideband Input.
I almost started this on my last ecu hacking project. Instead I concentrated on flexfuel as I lived next to an e85 station.
Old 05-03-2016, 11:58 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
But there isnt enough free space in a 730 8D chip let alone a smaller 6E 165 correct?
Old 05-03-2016, 12:00 PM
Engine: LB9
Axle/Gears: 3.08
You'd have to be able to do the nvram add on for that type of thing.
Old 05-03-2016, 02:26 PM
Steve Mack's Avatar
Car: 87 Iroc
Yep it sure can
Old 05-16-2016, 08:35 AM
big hammer's Avatar
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Everything sucks a it TPI for a performance car except how it looks. They should have just put it in a truck.
i88aGT
04-06-2016 06:53 PM
Onion
03-19-2016 03:08 PM
Tmelons4
Carburetors
03-17-2016 04:05 PM
1988_f-bird
03-15-2016 01:06 AM
armybyrd
03-09-2016 10:11 AM
Quick Reply: HSR or aftermarket TPI?
