Need HSR Injector help
1 Post
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
Looking to set my Holley stealth ram up with e85 but cant figure out what injectors will work with my setup. i know i need about 42lb to run e85 with my setup. (355 65cc afr heads, xfi280 cam and ported stealth ram, 10:1 comp) looking to maybe get a 60lb so i can add boost or n2o down the road. anyone have similar setup that had good luck with injectors that work with the stealth ram? thanks
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Re: Need HSR Injector help
I'm confused at what you are asking? The Green top 42s or Deka 60s all work fine.
-- Joe
1 Post
Car: 1992 Camaro
Transmission: t-5
Just trying to figure out options and whats worked well for others. Plus all the ones i look at dont seem to be e85 capable.
1 Post
Car: 1992 Camaro
Transmission: t-5
Yes capable. Referring to my op as some injectors are not meant for e85
