Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR/fuel rail question
Old 01-13-2017, 10:49 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
I plan on machining the HSR to reduce the overall height. I will be milling down approx. .25 off of the height of the base. Now since I do not have a set of fuel rails yet my question is if I lower the height of the plenum will the fuel rails come into contact with the plenum? I plan on using the Professional Products Powerflow Fuel Rails 10608.
https://www.summitracing.com/parts/pfs-10608
Old 01-13-2017, 10:57 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: HSR/fuel rail question
Here's a thread on using procomp rails. Looks like the challenge is 89-92 to linkage hitting a crossover line elbow.
https://www.thirdgen.org/forums/alte...ve-fuel-3.html
Old 01-13-2017, 11:48 AM
91banditt2's Avatar
Engine: 5.7 HSR
The ones I listed have the cross over in the middle under the plenum. This is one of the reasons I chose these.
Old 01-13-2017, 12:03 PM
91banditt2's Avatar
Engine: 5.7 HSR
Can someone post a picture of the front of the HSR showing the gap between the plenum and the fuel rails? Or the lack of a gap?
Old 01-13-2017, 12:22 PM
91banditt2's Avatar
Engine: 5.7 HSR
So I found this picture on here and it appears that there is approx. .25 between the plenum and the fuel rails.
Attached Thumbnails HSR/fuel rail question-stealthram.jpg
Old 01-13-2017, 03:36 PM
brian p's Avatar
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 700R4 w ProBuilt
Axle/Gears: 9 bolt 4.11
I just went out to the shop and measured. Definitely not 1/4". It's 3/16"(-) from outside edge of the fuel rail to the outside edge of the plenum. That's with the Holley fuel rail that came with the kit which looks to be 7/8" wide. I don't know the width of the PP fuel rail. That might jam things up if its wider.
Brian
Old 01-13-2017, 07:36 PM
91banditt2's Avatar
Engine: 5.7 HSR
Brian
Thanks for the input Brian. I'll look into the diamentions of the PP fuel rails.
Old 01-13-2017, 08:29 PM
91banditt2's Avatar
Engine: 5.7 HSR
Brian
I just sent out an email to PP asking what the diameter of their fuel rails.
Old 01-14-2017, 11:34 AM
brian p's Avatar
Car: 86 IROC
That HSR can be a PITA. Works good but I had to take my strut tower brace off. For icing on the cake I'd bought a used OEM composite/glass hood ( the one from the early cars) to put on the car to get some weight off the nose. And those steel hoods are brutal heavy. Of course that didn't fit either...
Old 01-23-2017, 10:39 AM
91banditt2's Avatar
Engine: 5.7 HSR
Going into this the two things I was well aware of was that there is and issue with hood clearance and and the strut tower brace I have I more than likely won't be able to use. But with the modifications that I'm making to the HSR I'm hoping will cure these problems. But if plan B is my only option ie. cutting the hood, I'm ok with that. With reducing the height of the HSR I'm hoping to give myself more options with clearance and a STB.
