Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR oil baffle
Old 01-23-2017, 12:21 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
HSR oil baffle
I've added an oil baffle to the bottom side of my HSR intake and I'm not to sure that I trust this hardware. Drilled and taped 10-32 into the 4 bosses on the under side of the intake. The holes are approx. 1/4" to 3/16" deep. My question is would you trust lock washers and Loctite to keep the screws from backing out? Other than welding the baffle in place would you suggest any other form of hardware to mount this?
Old 01-23-2017, 01:29 PM
Drew's Avatar
Received 1,052 Likes on 748 Posts
Re: HSR oil baffle
Yikes. If those come loose you're going to have three pieces of debris per fastener blowing around inside your engine.
Auto manufacturers use drive rivets to anchor various shields inside engines. I'd look into that as a tried and true solution.
Screws are probably fine, but I don't think I'd trust Walmart hardware aisle spec stove bolts. Personally I'd look into a screw you can actually torque, either a hex head, socket head, Torx, etc. I'd definitely skip the washers and lock washers, opting instead for the most permanent thread lock I could find. Might even consider staking the hardware, or fabricating a sheet metal locking tab to keep the hardware from backing out.
Old 01-23-2017, 03:26 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: HSR oil baffle
If I was going to do that I would ditch the flat heads for something hex then I would use red loctite and nothing weaker. After red loctite you will need hex heads to remove them because that **** is so strong. I might also consider safety wiring them in after.
Another idea would be to put studs in with red locite then you can use lock nuts and stake and loctite them so they don't move.
Old 01-23-2017, 06:41 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: HSR oil baffle
First off make sure that big flat plate isnt gonna resonate and tear itself up.
i would then weld it (assuming it's aluminum) to the intake.
if you must bolt I would recommend safety wire
Old 01-24-2017, 07:35 AM
91banditt2's Avatar
Engine: 5.7 HSR
Re: HSR oil baffle
How would check to see if the baffle won't resonate?
Old 01-24-2017, 09:34 AM
midias's Avatar
Re: HSR oil baffle
Can you bolt it in the middle anywhere?
Old 01-24-2017, 10:16 AM
91banditt2's Avatar
Engine: 5.7 HSR
Re: HSR oil baffle
I'll take a look at it after I get it back from our machinist.
