how do i remove grease from cloth seats?
Old 03-25-2007, 07:47 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
My seats where mint, and I took the back seats out, and i looked at them today, and the back has a few grease stains, and a small rust spot, fro a rusty bolt or something next to it. How can i remove theese stains?
Old 03-25-2007, 07:58 PM
83-ta-5spd's Avatar
Re: how do i remove grease from cloth seats?
try some carpet cleaner, a steam cleaner or if ur lucky u can spray brake clean on a rag and carefully "dab" at it
Old 03-27-2007, 06:58 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Best I've found for grease is lighter flluid and a clean rag. Works good. Shoot some fluid on the stain and wipe off.
Old 03-27-2007, 08:30 PM
dbruening80's Avatar
I would try a mild cleaner like Simple Green first before moving on to harsher chemicals
Old 03-27-2007, 08:37 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I dunno about the rust, but I know that Spray-N-Wash will take out the grease. I used to have a beater Impala and it looked like the previous owner hauled engine blocks in the back seat. I got it looking new again with Spray-N-Wash and a scrub brush. Use a towel and a bucket of water to remove all the suds and keep changing the bucket of water as it gets funky.
Worked for me.
Old 03-27-2007, 11:14 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Try a mild solution like oxy-clean before you go to the industrial cleaners.
Old 03-27-2007, 11:25 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
There is nothing mild about simple green. It rubs paint off your car if you try and use to to degrease your engine bay. Simple Green is a solvent and is very harsh even when diluted.
Old 03-28-2007, 06:10 AM
babsirocz's Avatar
I would do the "spray and wash" or "SHOUT" products for removal, then let it sit a few minutes, and use warm soapy water and "gently" rub out the stains.
Old 03-28-2007, 06:14 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Well, here in Canada I would go down to Canadian Tire and buy some waterless hand cleaner, rub it on to the grease and rust, then steam clean it out after 30 minutes. Would come right off, but if you could find something similiar, it's like an offwhite cream that takes grease off your hands..
Old 03-28-2007, 08:24 PM
charliehaley's Avatar
Car: 87 Camaro Sport Coupe
Engine: 305 CARB
Transmission: th700r
Axle/Gears: stock 2.73 open
I think what your refering to is GOOP.
Old 03-28-2007, 10:32 PM
83-ta-5spd's Avatar
washed a 68 charger with simple green diluted. we use simple green to clean alot of cars, esp when we frist get them and whatnot
Vintageracer
01-10-2020 05:33 PM
colton_carlson
03-08-2019 12:21 PM
lee01
04-09-2016 01:56 PM
AkDrifted
08-17-2015 07:45 PM
3rdgenparts
08-08-2015 07:09 PM
Quick Reply: how do i remove grease from cloth seats?
