I have pink tail lights.................
okay heres a little problem of mine. i have pink tail lights this happened because i took my tail lights off to make them clear outs buy removing the red and orange colored glass on the inside. but when you do that the lights are all white so i take some advise from the board to use a sharpie marker to color the bulbs i do and end up with pink tail lights so my question is can anybody suggest somthing to color my light bulbs with.
the ink will burn off anyway, either get some massive bulb condoms or just get some colored glass (not painted glass) bulbs. www.street-beat.com has them
Keep it all clear in the housing. Go to street beat .com and order a set of red LED lights. They glow a bright dark red just like if you had the red plate still in there.
1991 Camaro Z28 305 TPI: Dual K&N Filterchargers, flowmaster 3" cat-back exhaust with 4" chrome tips, Kenny Brown Strut Tower Brace, 17x9.5 Chrome ZR1 style rims, 275/40ZR17 Kumho tires, Eibach Pro-Kit Springs, SLP Headers and Y-Pipe, MSD 8.5mm Super Conductor Wires, Bosch Platnium +4 Spark Plugs, Throttle-Body-Bypass, KYB shocks-struts, Comp Cams Airfoil, HYPERTECH Superchip and 160 degree Thermostat, Rebuilt Tranny with Corvette Gears, Servo, and 2000 RPM stall converter, Custom Super White Sidemarkers, and SYLVANIA Cool Blue Headlights,$2000 Competition Stereo
id like to see some pics of your taillights if they are white out...
Arthur-
1985 IROC Restoration In Progress
http://www.thirdgenfbody.com/projiroc/
Member # 98 of The Las Vegas F-Body Association
www.lvfbody.com
Arthur-
www.lvfbody.com
Car: 92 RS Camaro T-Top
Engine: 305 V8
Transmission: 5 speed manual
Axle/Gears: stock
Re: I have pink tail lights.................
How did you get the red/orange off? As far as I know, the lenses themselves are red/orange. They are not painted at all.
Engine: 305 V8
Axle/Gears: stock
That's true lol. I bought a set of junked up tail lights so I could see if I could remove the red/orange. I have not had any success lol.
Axle/Gears: 9-bolt/3.45
85-90 TA taillights have a removable red lens(within the housing) behind the clear outer lens(which has the grid on the inner side), but no orange/amber lens. So I'd guess he's talking about 91-92 TA taillights which also have an amber lens. Open the housings and remove the inner colored lenses and it's a gridded-clear lens in front of chrome reflectors for use with red bulbs.
