Slammed Third Gens - Post Pics
#51
1 Post
Car: 1992 Camaro RS
Engine: L98 5.7 350
Re: Slammed Third Gens - Post Pics
Vortex: Thank you for the very detailed explanation, I got it now! I'm most likely gonna go with some moogs and some kyb shocks for the front and rear when I get the funds (after I get my new wheels mounted). Then I'll just chop the springs maybe a full coil, which probably still wouldn't be welcome in this thread LOL.
Mikey: You were right in thinking what I was thinking about bouncy rides. I did mean like..blown shock bouncy haha. Not suspension so stiff that car literally comes off the ground after a small pothole hahaha (over exaggeration).
You guys are probably the wrong people to ask about it, but when I get my 17x9.5/17x11's do you think it'll look funky sitting on stock height? I heard the actual wheel/tire combo itself is acutally 1/4" shorter than the stock wheel/tires combo.
#52
1 Post
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
it wont look terrible but id drop it AFTER you get the wheels if they are said to drop it a little already
#53
1 Post
Car: 1992 Camaro RS
Engine: L98 5.7 350
Guess I'll just have to refrain from hitting any jumps
I was in a foreign town about a year back and found out the hard way how it feels to JUMP my camaro.. Did it while showing up a mustang. After that, NEVER AGAIN will I floor it where I'm unsure if it's safe or not LOL.
#54
1 Post
Engine: 5.7 350 TPI
ugh i did that about a year ago in the trans am..was trying to beat the light and the intersection was like /\ not as steep as that but you get the point..LIFTOFF!! hahah..
#55
1 Post
Car: 1992 Camaro RS
Engine: L98 5.7 350
I bet with your suspension now though, you'll probably never bottom out again haha.
#57
1 Post
Engine: 5.7 350 TPI
yea i dont think it would haha..would hit bumpstops before anything..
huh?
#58
#62
Car: 1991 Camaro RS
Engine: 305 V8 TBI
#64
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
what's the point in this "slammed?" I can see lowering it an inch or 2 to get the gaps closer and maybe handle a bit better, but anything more just looks OFF. plus you won't be able to go over anything more than a deck of cards without creeping up on it. then it's even MORE of a pain to work on underneath than it already is.
#67
1 Post
Engine: 5.7 350 TPI
what springs? thats perfect
the slammed are a breed of there own
how is not practical? i daily drive mine and i track it..patience is a virtue when slammed no doubt.
Year One honeycombs IIRC
#68
Car: 87' IROC
Its ground control weight jacks bottomed out. The fronts are sitting on my strut mounted bump stops and the rears are sitting on the factory rear bump stops. Totally undriveable at this height. I only did this because I was curious to see how low it would go. The factory air dam is about 1" off the ground.
Front:
Rear:
Front:
Rear:
#70
Car: 1984 Camaro Z28
Engine: 406
Transmission: TH400 3K stall
Axle/Gears: DTS 12 bolt 3.73 eaton posi
Heres my 84 in white
#72
1 Post
Engine: 5.7 350 TPI
nice car indeed haha
#73
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
#74
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
For looks, I wouldn't mind if mine was a bit lower in the front...But if it was any lower, I wouldn't trust driving it around (I actually had it lower, but raised it a little...the beauty of coilovers). The k-member is only a few inches off the ground. The rear can't be lowered anymore and still function (with my wheel and tire combo anyway).
#75
I can't say it is SLAMMED,cuz seriously,I drive the car alot in Montreal,and our roads suck,but the Eibachs ride awesome and can avoid damage to front spoiler easily. And hey,gotta represent 3rd gens too,check out Sept 2011 Snap On calendar...first 3rd gen to get in it....our gens rules!!
#76
#77
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
not when you have air ride
#79
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: round ones "3.73"
This is as low as I could go with northern ohio roads.
#80
on Eibach Ground Controls
#82
Car: '91 TA vert
Engine: turboLSx
A lot of these...okay most of these aren't very 'slammed'. Hell, mine is dropped almost three inches and I wouldn't consider it slammed.
What wheels are those?
Edit; Found your build thread. Forgestar F14
#84
Engine: LB9, LB9
Here's mine. Fender height is 25" front and 26" rear. Lowered on Ground Control weight jacks (800/200) and KYB adjustable shocks and struts.
I will be going lower, but I gotta get some more parts first
#86
1 Post
Engine: 5.7 350 TPI
amazing colour ^^ love it! stance is awesome too! what spring setup??
#91
Car: 91 Camaro RS
Engine: TBI
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
#94
Engine: L99 L98
#96
Car: 1992 Chevy Camaro
Engine: 350 TBi in the working
Transmission: 700R4 :(
this is the best i have right now. i would really say shes slammed, but lowered, No iso front or back and about a coil and half out back and a coil cut up front. hopefully i leave michigan and ill take another coil out front and back or swap over to coil overs
#100
