What about these Valve Covers?
Old 01-17-2013, 10:23 AM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I want to purchase these valve covers but I am not sure if my PCV will fit in that hole??and also the reason as to why I wanna replace my covers is not only to look better but also because I kinda f*cked up my stock ones by spray painting them with some cheap no heat resistant paint so now they just look horribly. Every time I try to show off my engine everything looks clean except for those darn covers.
So pretty much I just wanna make sure before I buy these that I wont run into any problems, thanks! Also do you guys recommend those valve cover hold downs?thanks!
heres the link to the cover
http://www.jegs.com/i/Edelbrock/350/4443/10002/-1
Old 01-17-2013, 10:30 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What about these Valve Covers?
*Rubber grommets for the PCV/breather holes included, If they are not the correct size for the breather or pcv you have buy the correct ones.
Old 01-17-2013, 10:31 AM
calgutie's Avatar
Car: 1984 Z28
perfect well then it looks like im buying them....thanks man
Old 01-17-2013, 10:38 AM
Engine: Lb9
Transmission: M20
I believe it comes with a pair of 8094 1 1/4 grommets so you might want to measure your pcv and breather before you order incase you need additional grommets.
Old 01-17-2013, 10:39 AM
calgutie's Avatar
Car: 1984 Z28
I will do...and as for those grommets I can just get em at any part store right?
Old 01-17-2013, 10:43 AM
Engine: Lb9
Transmission: M20
yes most parts stores have them may not be edlelbrock just as long as its a snug fit so oil doest leak.
Old 01-17-2013, 01:47 PM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
You definitely want to install a breather cap and not a sealed cap on one side. If you still have a stock air cleaner you can get a breather cap that has the provision for hose hook up to connect to the breather. Keeps oil mist from creeping out of the cap and settling on your clean rocker covers.
Old 02-02-2013, 10:46 PM
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Not sure if they fit but I really like the proform v/c's.
The part numbers 141-92x through 141-930.
I think since they are a tall v/c they won't fit. I hang them up at my work for display and always loved the finish
Old 02-03-2013, 08:09 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
I approve!
Hotrodboba400
12-10-2019 07:07 PM
db057
04-28-2019 07:45 AM
Nick McCardle
09-10-2015 08:36 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: What about these Valve Covers?
