Should I black out my head lights?
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
I've been thinking about painting my headlight buckets for a while but I cant decide. These are pictures from before it got the new rims.
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
Re: Should I black out my head lights?
i say do it. makes it look so much better
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
Engine: 5.0 L03 V8
I think its safe, I have HID headlights and they're pretty bright.
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
I like the look with the buckets blacked out also.
COTM Editor
Your correct if speaking of "tinting" the actual headlight lenses
OP - Make them black!!!!
1 Post
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
The car looks killer as is, but I do like the blacked out buckets. Maybe use Plasti Dip first to make sure you like the look, if so peel it off and use real paint.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I like it with the buckets blacked out.
I had a white 92 RS, looked just like that. Love the white with red interior combo.
Car: 83Z28 HO
Transmission: G Force 5 speed
Paint them...especially on a white car.
Car: 1987 camaro sc
Engine: lg4 305
paint the pockets black. the all white body looks a little to plain
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
I agree. Leave them white. I think it keeps the white, crisp & clean looking. But as 2007x150 suggested, this is a place where using plast-dip makes sense. If you like it you can make it permanent, if you don't, peel it off.
Normally I'd say go for it, but your car is so clean it doesnt really need it. Just a really, really nice car.
But if you want to, you can always plastidip them so it's not permanent. You can see how you like it and it really looks good enough to leave alone as is if you mask it well.
Three caveats:
1. Be very meticulous in your masking
2. The more coats, the easier the stuff is to remove later. Aim for 4 coats.
3. If you let it dry before removing the masking tape, it will pull the plastidip off. You must remove masking tape IMMEDIATELY after last coat, and try to get as many coats in as quickly as possible. The wetter the stuff is when you pull the tape, the better.
It's a balance between giving enough time for each coat to cure properly before a new coat (The stuff is VERY forgiving, though), getting enough coats on it to make it easily removable, and getting done fast enough to pull the masking tape without stretching/pulling the plastidip thats partially cured. 3 coats is around full coverage, so just give it one more nice coat after that and you should be good to go to go ahead and yank off your masking.
Here is how mine turned out:
Notice it doesn't clash too badly with my bowtie grille, which was the main concern I had. It's nowhere near an exact match for the factory semi-gloss, but its not too far away, either.
Three caveats:
I like them body color .. it's an RS
~DaVe
~DaVe
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
The more I look at the photos the more I like the white buckets. If you had a little more black on the car like black racing stripes/etc. the black would be appropriate. What do your new wheels look like ?
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I've never liked body color headlight buckets. I say go black. Like stated before, you should try Plastidip so you can peel it off if you don't like it. You could try using glossifier too so it'll have more of a gloss look.
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
white1991rs , I am in the same boat as you. I have a pretty clean car aswell with body colored buckets, I don't know what I want to do. Everyone says paint them black, however to me black buckets look a little dated, I like to have a clean, up to date/restomod look.
I will plasti dip them and see how I like it though.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Black buckets on a white car does look killer
Car: 13 Charger, 91 RS 5 speed, 02 1500
Engine: Cast Iron 6.2
I like the clean look of white buckets on your car.
I agree with plasti dip if you want to try it out first
Engine: 5.0 L03 V8
Here are a couple photo's of them on the car.
https://www.thirdgen.org/forums/afte...you-think.html
Engine: 5.0 L03 V8
Three caveats:
Three caveats:
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
When I had my car painted they had forgotten to paint the buckets. So I did it myself and it came out great, and wow what a difference it makes on a white car. After the buckets were painted black it seemed to give the front end more depth and just an overall better look, however to each his own.
Car: 1989 Red IROC Z28 Convertible
Engine: 5.0 L TPI LB9 V8
Transmission: A4 Automatic
You know what they say. Once you go black you'll never go back. I say paint them black.
Car: '18 Jeep Wrangler, '19 Honda Accord
Engine: 2.0T in both
Transmission: 8 speed auto, 10 speed auto.
