Engine bay ideas
Car: 1989 Formula 350
Engine: 383ci, +150hp N20
Transmission: Built 700R4
Axle/Gears: Moser 9", 3.73 Detroit locker
Engine bay ideas
I'm nearly ready to fire her up. I need some ideas/thoughts about what else can be hidden or re-routed. (dont pay attention to the dirt, going to pull the motor and paint it)
suggestions?
suggestions?
COTM Editor
Re: Engine bay ideas
First things I see from the pics is the orange power? wire on the drivers side hanging all around. I think I would try and run the spark plugs *WIRES* under the headers or get a nice loom to run at the vc rail. I would remove the OE stickers from the fan shroud... not much OE going on with that engine now.
I like the color of the throttle body btw
First things I see from the pics is the orange power? wire on the drivers side hanging all around. I think I would try and run the spark plugs under the headers or get a nice loom to run at the vc rail. I would remove the OE stickers from the fan shroud... not much OE going on with that engine now.
The orange wires you spoke of have been loomed and hidden and I ordered plug wire looms from billet specialities. The fan shroud is getting an aluminum cover as well. Oh, and it is the original L98 (block) you are looking at. LOL
Thanks, I love the look of that TB myself.
COTM Editor
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
With perimeter bolt covers I'm using a set from Moroso. The rear has a holder for 4 (Vertical, running top to bottom) and then the lower two wires would split off and there is a holder (horizontal) to guide two wires going down to the back two cylinders. The front holder then holds the next two wires (vertical) and then another horizontal holder to guide them to the front two cylinders. It also has 2 holders for 4 wires to keep them neat in the back going to the distributor.
I don't care for the 4-3-2-1 style looms as they don't line up right with SBC heads with headers. They are more geared for BBC motors.
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
I'm sorry but I couldn't tell from the pic if you had one or not...but what about using a correct a cap ???
Updated...
Still need to figure out where to put the coil and what I'm going to do about a CAI.....but she's running. Went off to the exhaust shop yesterday, Dyno Friday.
the correct a cap...is a distributor cap..that lets the 4 wires on each side of the block go to that side of cap...so when you bring the wires to the cap you dont have to go to the opposite side of cap...jegs or summit have them ...maybe $50....
Thanks. I have virtually no knowledge when it comes to the mechanics....forgive my missunderstanding.
No problem buddy...I think that's why we are all hear ..to learn and help from each other...
NinjaNife
08-23-2015 11:49 AM
AkDrifted
08-17-2015 07:45 PM
