RE-Restoring my Iroc wheels
Old 07-19-2013, 12:12 PM
Joe Tag's Avatar
I picked these up fairly cheap and really thought I wanted to go with gold on them. But when they were done, I immediately knew they would not work. The image I had of gold on blue did not work quite as nice in reality. So, even though I swore I would not put myself through that again, I needed to fix it.
wheels as I bought them
After stripping and rough sanding for polish
First painting and polish, came out great if I say so myself
Then the look of them against the car color
I did not like it so..... here we go again. As I apply the stripper, I just keep telling myself "I don't believe I'm doing this!"
Echoing the words I keep telling myself through this whole build, I'm in too deep to turn back now.
Masked and primed Masking takes about 2 hours a wheel. Probably the worst part of the whole job.
Base coat, I went with a dark grey metallic that was the color of my GFX originally.
Cleared
Then, the final product. Excuse the residue from the masking tape. They will be polished to a mirror finish again.
In all, about 12 hours of labor total, stripping, masking, and paint. Still around $300 total in the wheels, even with over $100 in paint materials. Much more satisfied with this look.
Last edited by Joe Tag; 08-03-2013 at 07:08 PM. Reason: Moved images in photobucket
Old 07-19-2013, 02:34 PM
sweetmelissa's Avatar
Car: 1989 Iroc-Z
Engine: TPI 350
Axle/Gears: 3:27's
Re: RE-Restoring my Iroc wheels
What shade of gold is that ???
Old 07-19-2013, 02:53 PM
ghost91's Avatar
Car: 1991 Camaro Z28
Very nice job! They look great!
Old 07-19-2013, 05:36 PM
Joe Tag's Avatar
I'm not sure. Was a paint code from a subaru I believe. I could give you the code if you want.
Old 07-19-2013, 05:38 PM
Joe Tag's Avatar
Thanks alot! Was alot of tedious work, but well worth it in my opinoin.
Old 07-19-2013, 06:11 PM
ghost91's Avatar
Its the tedious work that pays off most tho! Ive been re looming wires for over a month now..but it looks better haha. Wish i could repaint my wheels, but im not that skilled in the paint department
Old 07-19-2013, 06:14 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
I just finished the same thing. I don't think I enjoy this type of work but I would do I again and again!! Totally worth it!
Nice wheels btw. Your a pro!
Old 07-19-2013, 06:19 PM
Joe Tag's Avatar
HA HA, The paint is the easy part. It's the prep that's the killer.
For those interested in doing this, Advance sells an aviation stripper that melts the old finish right off, even powdercoat. Though for PC it takes more than one application.
Old 07-19-2013, 07:22 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
It's 80% patience. If you drink beer. It's a great time to have a few. I finished 2 rims in about 6hrs.
Paint stripper and rinse. Repeat as needed.
Any time you want to dry out the wheels from water place them on your central air conditioner outside. The warm fast air will dry it in a few mins.
Lots of sanding
Lots of tape
Lots of old clean rags
Clear coat
Paint
Primer
Polish
Old 07-19-2013, 08:13 PM
Joe Tag's Avatar
Lots of sanding
Lots of tape
Clear coat
Paint
Primer
Polish
Masking those cross lace wheels would be a breeze, but I imagine the stripping was brutal. Nicely done!
Old 02-03-2023, 05:48 PM
83z28crossfire's Avatar
Car: 1992 Camaro Z28
Engine: LS1 Swap In Progress
What did you use for sanding and stripping
Old 02-03-2023, 11:48 PM
BajaDaze's Avatar
Car: 1989 IROC vert w/1LE brakes
Engine: 1990 ZR1 LT 5
Axle/Gears: 3.7 Borg Warner
Agreed, a lot of labor to get back to the new look, been there done that but only one time. 6 mos after completing I sold and bought Hawks 17x9s the color was never as good..
Old 02-04-2023, 06:46 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Very nice job on the wheels.
BlueIroc-Z
06-09-2019 03:22 AM
kah992
08-19-2015 02:55 PM
mustangman65_79
08-11-2015 03:17 PM
Fronzizzle
08-09-2015 01:15 PM
Quick Reply: RE-Restoring my Iroc wheels
