Headlights
Car: 1987 Z28 Convertible
Engine: 383
Axle/Gears: 4.11
Headlights
I am not satisfied with the stock headlights on my '87 Vert and want to make a change. I had an '86 GMC Caballero (El Camino with lock washers) which also used a similar 4 light setup. I went through various headlights ending up with lights that used H4 hi/lo's and H1 hi's, with dual bulb fog/driving lights to fill in long range and cornering lighting. It was good but I was never really satisfied with the setup except when all the lights were on, which was not something you could do except when driving on a deserted road.
So here is my question, what is the best headlight system for driving? By system I mean headlights plus any additional driving/cornering lights needed to make it safe to drive down the road. I am not worried about fabrication or cost requirements within reason, but do not want to end up with a cobbled rallye or off-road look with accessory lights sticking out alll over the place. My goal is to end up with a good driving gentlelman's hot rod on the order of MRIROC's.
Thanks, rj
Thanks, rj
Car: 89 Camaro RS
Engine: 2.8 V6
Transmission: Automatic
Re: Headlights
I do not have any experience with the quad rectangular (4656/4651) headlight systems yet, but this is what I have learned from doing the conversion on dual-headlight (6054) systems in the past.
This is scheduled to be my first upgrade to my Camaro.
#1 Not all E-Code lamps are the same, brand actually does matter. My preference was always to use Cibie, who unfortunately no longer makes the lamps for the quad setup anymore. From what I have read the Bosch system is the best. I have not sourced these lamps yet and have not gotten any further information. Hella also makes these lamps but my opinion on their dual lamp system was that the "beam separation" between low and high was too great; if the low beams were right on then the high beams were too high. There are many cheesy made in China lamps that are nowhere near up to snuff, especially with over-wattage bulbs
#2 Bypass the factory wiring. The OEMs generally skimped on this wiring and it is a long run from power to fuses to headlamp switch to dimmer switch and off to the headlights. In the past I have kept the factory wiring in place but ran a parallel 12 guage cable and new sockets to the lamps. This was connected to a pair of relays (1 for high, 1 for low) and a 10 guage cable to the battery. The difference with the standard halogen lamps was noticable on its own, and with larger bulbs it was huge. I used a "Bosch" type relay originally used for Oldsmobile fog lights, which had dual 87 outputs.
#3 Bulbs. Stick with white light. Blue only appears brighter due to glare and the fact that the human eye responds differently to it. The glare is due to a higher refraction angle (think Pink Floyd / Dark Side of the Moon) and the eye response is best demonstrated by the local police-- the blue lights only have a third of the broightness of the red
Car: 89 Camaro RS
Engine: 2.8 V6
Re: Headlights
I read the E36 retrofit, nice quality of build there. I do a light of night driving as well; just not ready for slicing/dicing the car yet
Engine: 383
Axle/Gears: 4.11
Re: Headlights
Thank you to everyone who replied so far. I'm torn between the E36 and C1500 conversions as both are available with HID projector low beams. I will probably add some cornering lights as I live in a fairly heavily wooded area with (nice) twisty roads. It's nice to have a lot of light to the sides to see deer and other critters, including joggers, that seem to like to tempt death on dark roadways.
rj
rj
Car: 1988 Formula 350 Firebird
Engine: 5.7L 350 TPI
Transmission: 700-R4
Axle/Gears: 3:73
Re: Headlights
I would also like to do a headlight conversion on my 88 firebird. It has the flip-out one piece glass headlights. Is there any option out there that will allow me to place LED bulbs in the proper size glass enclosure? I DO NOT want HID headlights. They look terrible in my opinion. Any help?
Car: 89 Camaro RS
Engine: 2.8 V6
Re: Headlights
IIRC the FBird uses H6054; I used Cibie H4 replacements that I sourced from Daniel Stern Lighting in both my Fiero and Jeep. No complaints about the lighting from them and would gladly recommend.
I have not been impressed with the LED headlamps as of yet
Axle/Gears: 3:73
Re: Headlights
I'd like a look comparable to a Cadillac Escalade's headlamps circa 2004. Those northstar led's. I know that might be unreasonable but that is the exact type of light I am looking for. If anyone can point me in the right direction I'd be much obliged. I might be ok with that Cibie kit if I can get a white light and not a blue or purplish tint.
I did some research and I'm guessing 6000k hid's would be my best bet.
Car: 1986 Firebird
Engine: 5.0L V8
Re: Headlights
i distrust websites like daniel sterns... I googled the Bosch ones he claims to sell and they are non existant on google...
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Headlights
Sylvania SilverStars
Traditional looking high performance bulbs .
http://www.autozone.com/autozone/par...romWhere=Brand
High Beam Headlight Bulb
Part Number:H4651
SilverStar, the brighter and whiter light from the leading supplier of automotive lighting. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
Part Images
Part Number:H4651
Part Images
Engine: TBI,5.0
Re: Headlights
The only reason I posted my SilverStar reply is because I recently drove a 89 Camaro with them to my sisters house. Perfect road to really get a feel for them. OK, my lamps are old and faded but this was something different. Bright and white without being overpowering to on coming traffic. Of course you have to know how to adjust them to get the effect you want.
I think they are perfect for those that want a traditional looking bulb.
Im sorry if it did not fit into your thread.
Car: 1986 Firebird
Engine: 5.0L V8
Re: Headlights
they were in the middle of the ****ing road, and my headlights were too ****ing dim to see them. so kiss my *** ******.
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Re: Headlights
I am using SilverStars and all I can say is they are amazing. Plenty of brightness.
Car: 89 Camaro RS
Engine: 2.8 V6
Re: Headlights
I will be reviewing various brands of the various 4x6 e-code halogens tomorrow from Carello, Cibie, Hella, Marchal and Bosch; all NOS. The Marchals are a little out of my price range at 150 each.
I have already selected Osram (not Philips) Silverstars as the bulbs. Was planning on putting them in tomorrow as well but I get to fix my gf's garage door instead
Car: 89 Camaro RS
Engine: 2.8 V6
Re: Headlights
Did get the Bosch lamps today, and utilized my gf's freshly fixed garage door to get them preliminary set for correct height; they came with bulbs so I didn't get the Silverstar 2.0s at this time; and an extra set of wiring adapters so I can make up new harnesses. Noticeably better lighting pattern but really couldn't try them out due to driving into a tornado warning.
Car: 89 Camaro RS
Engine: 2.8 V6
Re: Headlights
====={ Duplicate }=====
Last edited by Mad Myche; 10-04-2013 at 12:46 AM. Reason: duplicate- please delete
Car: 1986 Firebird
Engine: 5.0L V8
Re: Headlights
Are there part numbers for those ? And are they one solid piece? Or can you take them apart?
Car: 1992 Camaro Z28
Engine: 350ci
Re: Headlights
Something else to consider when upgrading your headlights is the wiring that is powering them. I used a relay to power mine directly off the battery. A full explanation is available here http://www.danielsternlighting.com/t...ys/relays.html
Car: 89 Camaro RS
Engine: 2.8 V6
Re: Headlights
Bosch PN 0301709800-730
Why would you want to take them apart?
If you want to just experiment I would get some cheap ebay or jcwhitney crap with clear glass lenses. You don't want lens based optics if you are going to play with projectors.
Relay based harness is in the works, I have 2 dual-87 relays coming Hella H41510171 and I already have the 12/3 cable made up
Car: 1992 Camaro RS 25th Anniversary
Transmission: WCT5
Axle/Gears: 3.42 posi
