Project Back in Black complete...NOT!
Car: 1991 Z-28
Engine: 383 TPI
Re: Project Back in Black complete...NOT!
nice job. I like the matte finish and the wheels. whats the motor details?
Built DART SHP 406ci with T76 turbo all forged internals
Eagle forged crank
Scat H-beam 6" rods
AFR 195 Eliminator heads
280xfi cam
1.6 roller rockers
Cloyes double roller timing chain
LS style lifter retainer(allows you to change cam without removing the intake)
Accel Superrram modded
Edelbrock TPI highflow intake ported
BBK 58mm TB
Turbo setup is pieced together and custom piping
3.5" SS downpipe
All stainless steel headers(driver side SLP header and passenger side is a modded BBS style turbo header)
Exhaust is put together with vband clamps. I can disassemble the entire exhaust in less than 10 min.
Also entire fuel system is custom made with braided lines and TPI rail has been fitted with -8an fittings
Dual Walbro intank pump setup with the second pump coming on at 5psi via Hobbs switch
Thanks yall, I have an SS hood that will eventually make its way on the car. I'm leaving it off for now while tuning so I can see the engine catch fire sooner to put it out lol
Looks good. Great job!
Car: 1986 Camaro IROC Z
Engine: 1995 LT1
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
i normally hate flat black third gens but good lord this car is stunning,i want it bad
Engine: 4++,350 & 305 CIs
Awesome!
May want to take the fresh air line from t-body to pass valvecover and route it to the turbo inlet so it doesn't put psi in the crankcase. Then block off the t-body port.
hey what was the exact name of the hood you eventually got because i can only find similar ones but they do not have the little vents on the sides? was it custom made?
Fast355
12-02-2016 06:33 PM
