engine code 43?
Old 10-01-2002, 01:17 PM
92 z28's Avatar
engine code 43?
my 305 tbi.......hey, i noticed my "service engine soon" light pop on today. so i tested the ecm, and i got code 43, the pamphlet i got from autozone does not have the definition of code 43 in the book. does anybody have the definition of this code? let me know. thanks.
Dozer80464@aol.com
Old 10-01-2002, 01:55 PM
92 z28's Avatar
it says its the Electronic Spark Timing (EST) Circuit - low voltage detected ... what the hell is that?
Old 10-01-2002, 04:54 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
92z28,
Usually these fault codes are caused by a wiring problem.One quick one to try is the wire leading form the knock sensor.As this is on the side og the block it could easily have become burnt or damaged.Make sure it is good condition and away from any other leads such as spark plug leads
hope this helps
PM
Old 10-01-2002, 04:56 PM
92 z28's Avatar
where can i find the knock sensor? any pics would be awsome.
Old 10-01-2002, 05:11 PM
powermite's Avatar
Car: Transam
The knock sensor is usually on the passenger side of the block,just above where the sump(oil pan) is bolted on.The ESC is usually found under the engine bay next to the brake servo
PM
Old 10-01-2002, 05:23 PM
92 z28's Avatar
hey, do i have to get under the car to get to it? any pics? i need to know what it looks like. wheres the brake servo ??
Spyder_TheGamer
12-25-2015 05:07 PM
bradleydeanuhl
08-12-2015 11:48 AM
mizz0313
08-12-2015 06:45 AM
Quick Reply: engine code 43?
