Herculiner any info would help
Old 10-05-2003, 08:48 PM
91GunmetalRS's Avatar
I've been watching TV alot lately, and i keep seeing adds for Herculiner and that it is supposed to be great bedliner. I was thinking i could use it as an undercoat for my Firebird, because it is in decent condition underneath, bu the winters in illinois pack a punch on metal. If anyone knows about this stuff, it would be helpful, or if they have any alternatives to my idea, anything but Por15(i don't really trust that stuff)
Old 10-05-2003, 08:56 PM
BIGJsTA's Avatar
heh...I'm in illinois (chicago) plowwing through the salt piles and grey slush every winter, i like por-15
You could use ANY sort of bedliner though, "rhino-liner" and a bunch others, all the same....Also, even like a rust-mate epoxy type product would probably work well with a few coats, or a rubberized paint which is kinda like bedliner..Check pep-boys out, just give it lots of good coats and if you really wanna be sure i like to double up on products
Old 10-11-2003, 08:58 PM
found out I was using Por15 wrong anyways, so i will probably settle with that. then some bed liner on top of it to seal it up good.
Old 10-12-2003, 01:56 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i did the entire engine bay with a 1 gallon can of gloss black rustoleum and it is thick. i took a screwdriver just to test it and it scratched but it was hard to do so. i think i will stick with a 20$ gallon of that rather than 35$ a pint of por-15
Old 10-12-2003, 12:26 PM
Ruddigger's Avatar
That bedliner shtuff is really strong, it'll hold up nicely. Just be really careful when you're applying it. You dont want to end up like this guy...http://www.explorerforum.com/forums/...0&pagenumber=1
Old 10-12-2003, 01:09 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Ha ha...... Hootus
Old 04-01-2010, 03:17 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Herculiner any info would help
this is a classic..
Fanatic1074
10-03-2022 05:57 AM
3rdgenparts
05-21-2016 11:50 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
bjpotter
10-04-2015 07:48 PM
Linson
10-01-2015 09:50 PM
Quick Reply: Herculiner any info would help
