trim peices on fender
Car: 1991 RS
Engine: 305 TBI
Transmission: auto
I jave a couple of fenders I'm sanding on and was curios how the trim moulding is fastened on. Is it glued, I can't seem to find any nuts where it might be bolted.
Thanks Scoty
Thanks Scoty
Car: 1991 Z28
Originally posted by 3gc
The later style ones are held on with double sided tape.
1 Post
Car: Z28
Well it's not like double sided scotch tape or anything. It's strong stuff. And you can peal it off, but you will be left with the tape still there, you'll have to get that off somehow. Also if your car has ever had a repaint it's most likely that those peices weren't removed and the paint under it will be lower and it won't look too good.
Car: 1991 RS
Engine: 305 TBI
Transmission: auto
Thanks guys. I was kinda thinkin it might be tape but wasn't sure and didn't want to tear anything up
Scoty
Scoty
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
yep, its some double sided stuff.... one of mine fell off a while back, and i just used this rubber sealant stuff to glue a new one on (the front drivers side fender). still going strong at 8 months....
I'm a little surprised that no one has mentioned the rubber erase wheel. Hook it up to a drill and there you have it. I'd rather use that than some sort of chemical. (I'm really scared of messing up my paint)
1 Post
Car: Z28
For stickers I use a heat gun and 3m adhesive remover. And now that i think about the door moldings more, my 89 was held on my double sided tape and my 87 had a very gooey glue type of thing holding them on, i used adhesive remover to get that off once the molding was off.
Car: 1991 RS
Engine: 305 TBI
Transmission: auto
for my puposes I need the moulding removed to sand and paint the fenders, so I'm not that concerned about the paint
Scoty
Scoty
