Gas Tank Recall...Read if you have a 1991 Camaro RS.....
Old 03-19-2009, 12:22 AM
  #101
Blud_Shot_Eyez's Avatar
Car: A few camaros
Engine: V6, 305 TBI, 350 TPI
Axle/Gears: 2.77
Re: Gas Tank Recall...Read if you have a 1991 Camaro RS.....
Originally Posted by bgmoss
There's more than just one year that have this problem(based on my own personal example).
I have a 1989 formula 350 tpi built in Van Nuys and I my VIN does not qualify for the recall, but I *did* have pinhole leaks around the filler neck where it attaches to the tank.
I fixed it by forcing marine expoy into the holes and followed up with a liberal apllication on top of that. The fix has lasted for more than 10 yrs now.
I also put some rubber around the filler neck out near the boddy to keep it from flexing as I fill up with gas and hit bumps.
My 1989 z28 failed a test only smog because of a leaky filler neck. Cost over $700 to fix
Old 04-17-2009, 07:50 AM
  #102
tibbitt23451's Avatar
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
I just called dealership and gave the service manager the last 8 of my vin. He said it DOES have an OPEN recall on the filler neck. 1991 camaro rs
Old 04-17-2009, 09:38 PM
  #103
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
Indeed it is an open recall.....problem is dealerships no longer have detailed description of recall on file so they don't know the proper procedure for determining if theres a problem or not. When they run your vin all it says is open recall for "crack at filler neck" and thats it. No details on the recall. Keep us updated.
Old 04-18-2009, 05:01 AM
  #104
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
I will keep everyone updated, hope to take it in next week. I hope they replace my sending unit also, my gas gauge stopped working.
Old 04-18-2009, 11:30 AM
  #105
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
hey tell them to replace the whole tank not your fault they dont know lol
Old 04-18-2009, 01:02 PM
  #106
Chezoom's Avatar
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
im gonna give them a call later and see how it goes, my filler neck does leak
Old 04-27-2009, 04:17 PM
  #107
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
I went to dealership today about the recall. They had to order a aftermarket tank, it should be here in 2 days. I had to wait all day for GM corp to ok the aftermarket tank, GM does not make the tank any more. I tried to get a loaner but GM would not give me one.
Should I be worried about the panel I cut out to replace a bad fuel pump? It is sealed up, but i cut the fuel lines & repaired them with hose. I don't want them to say they can't fix it because of the repaired fuel lines, what do you think?
Old 04-27-2009, 05:06 PM
  #108
83 Crossfire TA's Avatar
to be quite honest with you I'm totally surprised that they agreed to do recall work on an 18y/o car.
that being said, the recall is on the filler neck, not on the fuel lines, and also not on the sender, so they should just replace the tank and drop your existing sender/lines in it. If you want it replaced you better tell them and pay for it.
Old 04-29-2009, 09:07 AM
  #109
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
yes this is true but they have to remove the lines to drop the tank and if i was them i wouldnt touch that at all if they do you are lucky but they wont give any kind of warranty on there work but i wouldnt touch it at all and im a technician maybe they can just give you the tank who knows let us know
Old 05-09-2009, 11:08 AM
  #110
jamieschott's Avatar
Mine started leaking this past week after filling tank up. Called dealer to see if I had an open recall and they said no after i gave them my VIN. I asked if there was anything else i could do since i was having the problem the recall stated. They gave me the number to GM corp and said to call them. I called them and they started to tell me the same thing, that i had no open recall. But then the lady said something about she remembered there was a recall for the problem and put me on hold so she could do some "research". She came back in about a minute saying there was a recall for this problem But get this. She told me " My car wasnt affected by the recall, so rest assured that i should feel safe nothing would happen to my car" WTF...
I then told the lady that the problem HAS HAPPENED to my car. She then repeated the same to me...I about flipped on her. But held my cool and said to her " Ma' am, the problem has happened to my car," and went on to read the recall summary and consequences to her.
She then told me that i should take my car to a dealer and have them diagnose the problem and if they found it to be cracked they would replace it for free, I said thanks and then she said she would call me in a few days to see how things turned out.
I then called the dealer back and told them what was said. and then set up a time for me to bring my car in for them to look at it.
They called me back after they verified the problem and said they were waiting on GM Corp to approve an aftermarket tank to be installed. Good thing is one of the local dealers has one. So once GM says OK, they ll get the tank and replace it.
I also have a fuel pump access door cut with compression fittings on the lines i cut. And the service manager said nothing about not doing it because of that reason, after I told them I done it that way.
Sorry for the long winded post. But wanted to tell my story.
Old 05-20-2009, 06:48 PM
  #111
After a week and a half of arguing with gm's district customer service support and them "TRYING TO find a stock tank SOMEWHERE out there" they finally agreed to get me an aftermarket tank and will be getting mine replaced this friday.
Old 06-11-2009, 04:47 PM
  #112
iroc_zz's Avatar
Car: 1985 IROC-Z
Engine: 305 H.O.
Transmission: 5 Speed
Axle/Gears: 7.5" 10 bolt, 4.10, torsen posi
anyone have a pic of the pin holes or cracks, I have a used tank being shipped to me from a 91' Camaro and I would like to know what to look for before I put it in and find out the hard way that it leaks.
Old 06-16-2009, 10:14 PM
  #113
Torque22's Avatar
Re: Gas Tank Recall
I didn't read entirely, but does it cover 91 Firebird's?
cuz mine sure stinks like gas, and the neck is loose.
Old 06-28-2009, 11:40 AM
  #114
wilkesr's Avatar
Car: 91 RS Convertible
We wouldn't be having to wait 18 years to get our tanks fixed if the dealers would have fixed them. I've had my Camaro for several years, driving with gas pouring out the back (especially when I try to fill it up). It's a convertible, so I rarely drive it. It's sitting in my garage as we speak. I finally spent around $400 for a new aftermarket tank, fuel pump, straps and what not to get this thing working properly. This blog has me recharged to try and see if I can find a Chevrolet dealer that will fix it. MAYBE after all these years, one or two service dudes will 'remember' fixing one of these and will fix it under the recall. My parts will arrive to Advance Auto parts this next week. MAYBE I can get some sort of commitment from Chevrolet. When I had taken it to the dealer last time, they recognized the recall but they were dumbfounded how to get paid by GM. That was their primary concern - if they fixed it, they MIGHT NOT get paid from GM; wierd. Seems like GM ought to buy up some 'aftermarket tanks' and just get these things fixed. I don't know if anyone has left a number to contact GM, but I think it's 1-800-630-2438.
Old 07-10-2009, 11:31 PM
  #115
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
I have a 90 Formula and read about a recall on the fuel return hose and don't know how to check it. Can someone help me out here?
Old 08-21-2009, 12:57 AM
  #116
805camaro805's Avatar
Car: 91 Rs Camaro
Engine: 305 tbi
Transmission: 700 r4
My car has 3/4 recalls on it lol and since they got that new law the recalls on my camaro is my problem not gms...
Old 10-08-2009, 05:29 PM
  #117
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
If it helps any body-my 91 firebird parts car had the cracked tank filler neck.
I had to remove it to put it in another car and I could hear it clunk when I moved it up and down.
It was no big deal for me as I was removing it anyways. (tank)
I took it to a local radiator repair shop and he re soldered it for $20.
It would still be a big pain to pull the tank just for the leak but they can be fixed. HTH
Old 10-08-2009, 06:37 PM
  #118
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
This is just a good excuse for a 4th gen tank swap.
Old 10-08-2009, 11:30 PM
  #119
Mr Froman's Avatar
is there a thread on this anywhere?
Old 11-24-2009, 10:55 PM
  #120
iluvmy91camaro's Avatar
Car: 1991 Chevy Camaro RS w/t-tops
Engine: BBC 396 .090 over (414)
Transmission: LS1 T-56
Axle/Gears: Shortened Ford 9, 3.25, discs, posi
Is this recall still in effect? My gas tank has some surface rust. Will they give me a new gas tank at the dealership? Because I'm going to need a new one soon... Thanks!
Old 05-16-2010, 03:57 PM
  #121
RjjR454's Avatar
Car: 1991 Camaro RS
Engine: 3.1 "for now"
i just bought a 91 camaro rs about a week ago none of the gauges worked (NONE!) the guy said he thought it was a short, and not bad fuse? anyway it was the FUSE they all work fine now EXCEPT FUEL GAUGE! and when i get gas it constantley stops like the tank is full even when I know its damn near empty. the other day i just kept pupmping by letting go of the trigger and starting again about 20 times than about 3 gallons of gas starting pooring out under the car somewhere nar where the filler neck would attach to the tank. IS THIS BECAUSE OF THE RECALL PROBLEM YOU GUYS ARE TALKING ABOUT???? I hope so because it takes me about ten minutes to pump $5 worth of gas and i wont even try filling my tank because im worried it will start pooring out when i hit that certain point wherever it is
Old 05-17-2010, 08:42 PM
  #122
Gibson's Avatar
Car: 1989 Camaro IROC-Z
Engine: LB9
Axle/Gears: 3.08 G80
does any one know for sure if they replace the pump and sending unit when they do this?
Old 06-04-2010, 08:30 PM
  #123
MT91Camaro's Avatar
Car: 1991 Camaro RS
Engine: ewww...the 3.1L
Transmission: Not sure. It shifts quite hard.
Axle/Gears: 3.23 8.75" 10 bolt
Not sure...I am having the same thing done with my car. I don't get how you guys are getting ran in circles by your local dealership. I took mine in, gave them the part of the vin they needed. They told me it had not been fixed and ordered the dye goop crap that they use to check it. Its only the second time I have taken something to them (first time was to replace a starter on a 74 C-10 w/ 454) and even then I didn't get hassled and they were up front on everything.
Maybe it's because I talked with the service manager to begin with.
Old 07-07-2010, 11:55 PM
  #124
topgun91's Avatar
Car: 1991 z28
Engine: lt1 swap in process
Axle/Gears: posi 3.23
i have a 91 rs aswell and i have the same problem sometimes i can fill it up and sometimes i cant pump five dollars without spending 10 mins there i hope i can still get that takin care of
Old 07-08-2010, 12:31 AM
  #125
MT91Camaro's Avatar
Car: 1991 Camaro RS
go to your local dealership. the recall is a safety one so it does not expire. the person you talk to will have to do some searching but it does exist. they will need the last 4 of your vin to see if it has been fixed or has been looked at previously. dont let them mess with you.
luckily, mine was ok.
Old 07-08-2010, 01:03 AM
  #126
jordanandrewkay's Avatar
Car: 1991 T/A GTA H/T
Axle/Gears: 3.23 Posi
CAMPAIGN: FUEL FILTER NECK TANK SOLDIER JOINT # 92C36
JUNE, 1994
PRODUCT SAFETY CAMPAIGN 92C36 - FUEL FILLER NECK TO FUEL TANK SOLDER JOINT 1991-92 CHEVROLET CAMARO PONTIAC FIREBIRD
TO: ALL DEALERS
THE NATIONAL TRAFFIC AND MOTOR VEHICLE SAFETY ACT, AS AMENDED, PROVIDE THAT EACH VEHICLE WHICH IS SUBJECT TO A RECALL CAMPAIGN OF THIS TYPE MUST BE ADEQUATELY REPAIRED WITHIN A REASONABLE TIME AFTER THE OWNER HAS TENDERED IT FOR REPAIR. A FAILURE TO REPAIR WITHIN SIXTY (60) DAY AFTER TENDER OF A VEHICLE IS PRIMA FACIE EVIDENCE OF FAILURE TO REPAIR WITHIN A REASONABLE TIME.
IF THE CONDITION IS NOT ADEQUATELY REPAIRED WITHIN A REASONABLE TIME, THE OWNER MAY BE ENTITLED TO AN IDENTICAL OR REASONABLY EQUIVALENT VEHICLE AT NO CHARGE OR TO A REFUND OF THE PURCHASE PRICE LESS A REASONABLE Allowance FOR DEPRECIATION.
TO AVOID HAVING TO PROVIDE THESE BURDENSOME SOLUTIONS, EVERY EFFORT MUST BE MADE TO PROMPTLY SCHEDULE AN APPOINTMENT WITH EACH OWNER AND TO REPAIR THEIR VEHICLE AS SOON AS POSSIBLE. AS YOU WILL SEE IN READING THE COPY OF THE LETTER SHOWN THAT IS BEING SENT TO OWNERS, THE OWNERS ARE BEING INSTRUCTED TO CONTACT THE CHEVROLET CUSTOMER ASSISTANCE CENTER IF THEIR DEALER DOES NOT REMEDY THE CONDITION WITHIN FIVE (5) DAYS OF THE MUTUALLY AGREED UPON SERVICE DATE. IF THE CONDITION IS NOT REMEDIED WITHIN A REASONABLE TIME, THEY ARE INSTRUCTED ON HOW TO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION.
DEFECT INVOLVED
GENERAL MOTORS HAS DETERMINED THAT CERTAIN 1991 - 92 CHEVROLET CAMARO MODEL VEHICLES FAIL TO CONFORM TO THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD (FMVSS) 301, "FUEL SYSTEM INTEGRITY". THESE VEHICLES COULD EXHIBIT CRACKS OR "PIN HOLES" AT THE FUEL FILLER NECK SOLDER JOINT. THIS COULD RESULT IN FUEL ODOR OR FUEL LEAKAGE. IF AN IGNITION SOURCE WAS PRESENT, FUEL LEAKAGE RESULTING FROM THIS CONDITION COULD RESULT IN A VEHICLE FIRE.
TO CORRECT THIS CONDITION, DEALERS ARE TO INSPECT THE FUEL TANKS OF INVOLVED VEHICLES AND REPLACE THOSE TANKS THAT EXHIBIT THE CRACK OR "PIN HOLE" CONDITION.
IN ADDITION, FOR VEHICLE'S WHICH REQUIRE FUEL TANK REPLACEMENT, OWNER'S ARE BEING INFORMED THAT AN ALTERNATE MEANS OF TRANSPORTATION WILL BE PROVIDED FREE OF CHARGE UNTIL THE FUEL TANK REPLACEMENT IS COMPLETED.
VEHICLES INVOLVED
INVOLVED ARE CERTAIN 1991-92 CHEVROLET CAMARO MODEL VEHICLES BUILT WITHIN THE FOLLOWING VIN BREAKPOINTS:
YEAR MODEL PLANT CODE FROM THROUGH
1991 F-CAR VAN NUYS L ML100001 ML200843 CHEVROLET 1992 F-CAR VAN NUYS L NL100001 NL170008 CHEVROLET 1991 F-CAR VAN NUYS L ML200001 ML250250 PONTIAC 1992 F-CAR VAN NUYS L NL200001 NL227568 PONTIAC.
INVOLVED VEHICLES HAVE BEEN IDENTIFIED BY VEHICLE IDENTIFICATION NUMBER COMPUTER LISTINGS. COMPUTER LISTINGS CONTAIN THE COMPLETE VEHICLE IDENTIFICATION NUMBER, OWNER NAME AND ADDRESS DATA, AND ARE FURNISHED TO INVOLVED DEALERS WITH THE CAMPAIGN BULLETIN. OWNER NAME AND ADDRESS DATA FURNISHED WILL ENABLE DEALERS TO FOLLOW-UP WITH OWNERS INVOLVED IN THIS CAMPAIGN.
THESE LISTINGS MAY CONTAIN OWNER NAMES AND ADDRESSES OBTAINED FROM STATE MOTOR VEHICLE REGISTRATION RECORDS. THE USE OF SUCH MOTOR VEHICLE REGISTRATION DATA FOR ANY OTHER PURPOSE IS A VIOLATION OF LAW IN SEVERAL STATES. ACCORDINGLY, YOU ARE URGED TO LIMIT THE USE OF THIS LISTING TO THE FOLLOW-UP NECESSARY TO COMPLETE THIS CAMPAIGN. ANY DEALER NOT RECEIVING A COMPUTER LISTING WITH THE CAMPAIGN BULLETIN HAS NO INVOLVED VEHICLES CURRENTLY ASSIGNED.
PARTS INFORMATION
IT IS ANTICIPATED THAT LESS THAN 3% OF SUSPECT FUEL TANKS ASSEMBLIES WILL REQUIRE REPLACEMENT. PLACE ORDERS ACCORDINGLY.
PARTS REQUIRED TO COMPLETE THIS CAMPAIGN ARE TO BE OBTAINED FROM GENERAL MOTORS SERVICE PARTS OPERATIONS (GMSPO). TO ENSURE THESE PARTS WILL BE OBTAINED AS SOON AS POSSIBLE, THEY SHOULD BE ORDERED FROM GMSPO ON A V.I.P ORDER WITH NO SPECIAL INSTRUCTION CODE, BUT ON AN ADVISE CODE (1).
PART NUMBER / DESCRIPTION / QUANTITY / VEHICLE
10269091 FUEL TANK UNLEADED 1 - IF REQUIRED 10269092 FUEL TANK (EXPORT ONLY) 1 - IF REQUIRED 22515965 SENDING UNIT SEAL 1 - IF REQUIRED) 10113029 FUEL TANK INSULATOR 2 - IF REQUIRED.
OWNER NOTIFICATION
OWNERS WILL BE NOTIFIED OF THIS CAMPAIGN ON THEIR VEHICLES BY CHEVROLET MOTOR DIVISION (SEE COPY OF OWNER LETTER AS SHOWN).
DEALER CAMPAIGN RESPONSIBILITY
ALL UNSOLD NEW VEHICLES IN DEALERS' POSSESSION AND SUBJECT TO THIS CAMPAIGN MUST BE HELD AND INSPECTED/REPAIRED PER THE SERVICE PROCEDURE OF THIS CAMPAIGN BULLETIN BEFORE OWNERS TAKE POSSESSION OF THESE VEHICLES.
DEALERS ARE TO SERVICE ALL VEHICLES SUBJECT TO THIS CAMPAIGN AT NO CHARGE TO OWNERS, REGARDLESS OF MILEAGE, AGE OF VEHICLE, OR OWNERSHIP, FROM THIS TIME FORWARD.
OWNERS OF VEHICLES RECENTLY SOLD FROM YOUR NEW VEHICLE INVENTORY WITH NO OWNER INFORMATION INDICATED ON THE DEALER LISTING, ARE TO BE CONTACTED BY THE DEALER, AND ARRANGEMENTS MADE TO MAKE THE REQUIRED CORRECTION ACCORDING TO THE INSTRUCTIONS CONTAINED IN THIS BULLETIN. THIS COULD BE DONE BY MAILING TO SUCH OWNERS A COPY OF THE OWNERS LETTER ACCOMPANYING THIS BULLETIN. CAMPAIGN FOLLOW-UP CARDS SHOULD NOT BE USED FOR THIS PURPOSE, SINCE THE OWNER MAY NOT AS YET HAVE RECEIVED THE NOTIFICATION LETTER.
IN SUMMARY, WHENEVER A VEHICLE SUBJECT TO THIS CAMPAIGN ENTERS YOUR VEHICLE INVENTORY, OR IS IN YOUR DEALERSHIP FOR SERVICE IN THE FUTURE, PLEASE TAKE THE STEPS NECESSARY TO BE SURE THE CAMPAIGN CORRECTION HAS BEEN MADE BEFORE SELLING OR RELEASING THE VEHICLE.
THIS BULLETIN IS NOTICE TO YOU THAT THE NEW MOTOR VEHICLES INCLUDED IN THIS CAMPAIGN MAY NOT COMPLY WITH THE STANDARD IDENTIFIED ABOVE. UNDER SECTION 108 OF THE NATIONAL TRAFFIC AND MOTOR VEHICLE SAFETY ACT IT IS ILLEGAL FOR A DEALER TO SELL A NEW MOTOR VEHICLE WHICH THE DEALER KNOWS DOES NOT COMPLY WITH AN APPLICABLE FEDERAL MOTOR VEHICLE SAFETY STANDARD. AS A CONSEQUENCE, IF YOU SELL ANY OF THESE MOTOR VEHICLES WITHOUT FIRST PERFORMING THE CAMPAIGN CORRECTION, YOUR DEALERSHIP MAY BE SUBJECT TO A CIVIL PENALTY UP TO $1,000 FOR EACH SUCH SALE.
LIQUID LEAK DETECTOR
EACH DEALER WILL BE SHIPPED A BOTTLE OF SNOOP LIQUID LEAK DETECTOR, J-41365, FOR USE IN THIS CAMPAIGN DURING THE WEEK OF MAY 23, 1994 ADDITIONAL BOTTLES, IF REQUIRED, MAY BE PURCHASED BY CONTACTING KENT-MOORE TOOL COMPANY AT 1-800-345-2233. LIQUID LEAK DETECTOR MAY ALSO BE PURCHASED
LOCALLY IF THE DEALER PREFERS BUT ONLY "SNOOP" BRAND LIQUID LEAK DETECTOR IS TO RE USED IN THE PERFORMANCE OF THIS CAMPAIGN.
EACH BOTTLE CONTAINS ENOUGH LIQUID LEAK DETECTOR TO INSPECT APPROXIMATELY 16 VEHICLES (8 OZ BOTTLE - APPROX. 1/2 OZ. PER VEHICLE).
CAMPAIGN IDENTIFICATION LABEL
EACH VEHICLE CORRECTED IN ACCORDANCE WITH THE INSTRUCTIONS OUTLINED IN THIS PRODUCT CAMPAIGN BULLETIN WILL REQUIRE A "CAMPAIGN IDENTIFICATION LABEL". EACH LABEL PROVIDES A SPACE TO INCLUDE THE CAMPAIGN NUMBER AND THE FIVE (5) DIGIT DEALER CODE OF THE DEALER PERFORMING THE CAMPAIGN SERVICE. THIS INFORMATION MAY BE INSERTED WITH A TYPEWRITER OR A BALL POINT PEN.
EACH "CAMPAIGN IDENTIFICATION LABEL" IS TO BE LOCATED ON THE RADIATOR CORE SUPPORT IN AN AREA WHICH WILL VISIBLE WHEN THE VEHICLE IS BROUGHT IN FOR PERIODIC SERVICING BY THE OWNER. ADDITIONAL "CAMPAIGN IDENTIFICATION LABELS" CAN BE OBTAINED FROM DAC.
APPLY "CAMPAIGN IDENTIFICATION LABEL" ONLY ON A CLEAN, DRY SURFACE.
CLAIM INFORMATION
SUBMIT A PRODUCT CAMPAIGN CLAIM WITH THE INFORMATION INDICATED BELOW:
* PARTS LABOR LABOR OTHER NET REPAIR PERFORMED PC ALLOW OP HOURS
HOURS AMOUNT
INSPECT FUEL TANK 4 **V8940 0.3 0.1 *** FILLER NECK FOR LEAKS - NOT NECESSARY TO DRAIN FUEL FROM TANK - NO LEAKS PRESENT, NO REPAIR REQUIRED
INSPECT FUEL TANK - **V8941 0.4 0.1 FILLER NECK FOR LEAKS - FUEL DRAINED FROM TANK NO LEAKS PRESENT, NO REPAIR REQUIRED.
INSPECT FUEL TANK 4**V8942 2.2 0.1***FILLER NECK FOR LEAKS - NOT NECESSARY TO DRAIN FUEL FROM TANK - LEAKS FOUND, FUEL TANK REPLACED.
INSPECT FUEL TANK 4 ** V8943 2.3 0.1***FILLER NECK FOR LEAKS - FUEL DRAINED FROM TANK - LEAKS FOUND, FUEL TANK REPLACED.
NOTE: CHEVROLET FAILURE CODE SK-00 PONTIAC FAILURE CODE 96
sorry so long guys but here you go thats the work order dealerships received....in red are documented statements so hopefully that will help....there is more but this letter goes in the most detail the owner letter is very vague.
Old 11-03-2010, 08:10 AM
  #127
davemel3nzc's Avatar
Re: Gas Tank Recall (fixed)
I have an 1986 IROC that I was putting a 91 RS tank in. After getting the tank in I found that I had little to no fuel pressure. Then after taking the tank back out and trying to dump the gas out, I see that the neck tank connection was wet. The next day I found this post and did not want to put the tank back in. Since it was going in a 1986 the recall would not be available to me. I was scared a hell, but I drained the tank and rinsed it out with soap and water. Then I put the tank on its edge and filled it with soap and water with the filler neck straight up. With a soldering iron, I resoldered the connection. Worked very well, but as I said I was scared as hell doing it.
Old 11-06-2010, 11:44 AM
  #128
steve87ta's Avatar
Engine: 461,305TB
Well it sounds like you did the right thing. I had a 91 bird tank that I pulled out and put in a 86 T/A. Mine had been completely empty for months so I had a radiator repair guy solder mine.
In my project car, I am using a 305 TB and the complete harness from the base FB so I put a new pump for a 91 tb 305 car and installed it before I put the tank in. Car is running now.
The only point I would like to make;
The filler neck does not determine fuel pressure- my parts car ran fine fuel wise even though it leaked at the filler neck.
Just be sure to use the correct pump for the engine being used. Throttle bodies run on 12 regulated psi. TPI's like my wifes gta run at much higher psi. (45)
I hope this can help you.
Old 11-12-2010, 09:01 AM
  #129
kd5bwp's Avatar
Wondering if anyone has recently had their tank replaced under warranty. My filler neck is cracked and my vin falls within the range for the recall. Most people especially dealerships don't understand that recalls are good for the life of the vehicle. Part that people get confused is about the 10 year limit. That 10 year limit is only if you car or truck was older than 10 years when the recall came out. Seeing mine is a 1991 and the recall came out in 1994 it is good for the life of the car no matter age, mileage, or ownership. Only thing that can void the recall is if my car has a salvage title or has been in a wreck that would have damaged the filler neck, none of which have happen. I hope I cleared up that part about that recalls don't expire what so ever. Only time that a manufacture can say that they expired is that the car was older than 10 years when the recall came out; and the age is then determined by when it was first sold (first owner sold to or what shows up on the title) not the year or date of manufacture.
Old 11-12-2010, 09:08 AM
  #130
kd5bwp's Avatar
Re: Limitations on remedy of defects...
Recall doesn't expire as some people say. It is good for the life of the car. Recall came out when the car was only 3 years old. Only time the 10 year comes into effect is if the car was older than 10 years when the recall came out.
Old 11-12-2010, 09:30 AM
  #131
kd5bwp's Avatar
Here is the link for the recall.
http://www-odi.nhtsa.dot.gov/acms/do...-94V077-NN.PDF
Old 11-12-2010, 12:04 PM
  #132
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
I know that in general you are 100% right about this but I am curious if it is still a good recall after they filed bankruptcy. This did get GM out from under alot of things like this due to the age of the vehicles. As far as I could tell they had (due to the bankruptcy) 10yrs back and newer to be held liable. They still have to make parts available for the 10yrs even for Pontiac's but it seemed that the wording exempted them from any earlier recalls etc.
Did I understand the bankruptcy wrong? I hope so I have a 91 Firebird.
Maybe someone on here knows more about this???
Old 11-12-2010, 12:09 PM
  #133
kd5bwp's Avatar
From what I understand is that recalls no matter if the company goes belly up have to be taken care of by them. Seeing they did go belly up and then get bailed out by the gov and then became Government Motors warranties were still honored and since they are still in business the recalls still stand under federal law.
Old 11-14-2010, 12:49 PM
  #134
so finally was able to take mine down to wiesner which was a pontiac/buick/gmc dealer until it disappeared...but they told me they could not even get my vin # info from their system. and so they would not be able to do any work to my car. any suggestions??
Old 11-14-2010, 12:59 PM
  #135
kd5bwp's Avatar
There is another form name gas tank recall and there was a person not too long ago that was was able to get their car fix even tho it didn't show up in the gm system. Besides gm went to a new system for the gin info and they didn't put cars that were 15 years or older in there. Even tho its law they have to keep record of even car sold. Also does your vin follow in the break points?
Old 11-14-2010, 01:03 PM
  #136
kd5bwp's Avatar
Also did you bring them the gm info that was in the link I provided? They should be able to pull this campaign number in their system 92C36. It will have the info that was in the link and is the only info about this recall in their system.
Old 11-14-2010, 01:05 PM
  #137
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
I've tried for the last few months to get this applied to mine. I removed the tank and physically saw cracks at the filler next. Also failed the soapy water test. After multiple attempts contacting GM corporate and various dealers in my area, I've decided to purchase one myself.
Old 11-14-2010, 01:11 PM
  #138
kd5bwp's Avatar
Mine is in the shop and they said it was under the recall but can't get the parts so gm has sent a regional manger to look at my car.
Old 11-14-2010, 01:13 PM
  #139
well i have not looked at that link yet. will do rite after i post this. and yeah my vin is 1G2FW2380ML240938
well my computer wont open that link.
Old 11-14-2010, 01:21 PM
  #140
kd5bwp's Avatar
The vin breaks for a 1991 is ml100001 to ml200843
1992 ml100001 to ml170008
Old 11-14-2010, 01:22 PM
  #141
kd5bwp's Avatar
l is the plan code for van nuys had to be made their to be under the recall and within the break points.
Old 11-14-2010, 10:44 PM
  #142
the code breaks your talking about are for chevy there are differant code breaks for pontiac and mine falls under ML 200001- ML250250. and my car was made at the van nuys plant and shipped to katy texas where the lady i bought it from bought it brand new. plus my dealer invoice confirms this. you should read the post (post 126) i made about the recall and it covers this.
Old 11-14-2010, 10:53 PM
  #143
kd5bwp's Avatar
I was only talking about the camaros... I didn't mention any other model... But that's why I included the link for additional info.
Old 11-15-2010, 03:19 PM
  #144
kd5bwp's Avatar
Mine is currently in the shop and they said it had a recall by just looking at the documents I provided to the dealership. Here is the copy of my service invoice now they have gotten the car fixed yet or approved an aftermarket tank. Only thing they said it does have one.
http://s55.photobucket.com/albums/g1...t=IMAG0255.jpg
Old 11-18-2010, 10:30 AM
  #145
kd5bwp's Avatar
***Update***
GM Approved to have the test done on the car!!! So everyone that has the same problem don't give up the recall is still valid!!! Only thing to note I forgot about my aftermarket exhaust that it was 100% welded and has to be cut off to replace the tank if it gets to that point.
Old 11-19-2010, 10:14 AM
  #146
kd5bwp's Avatar
***UPDATE***
Tank was found to be bad and they are now trying to find another tank for my car.
Old 12-29-2010, 07:39 PM
  #147
Guest
Guest
Posts: n/a
my vin is in that range the ending is ml199888 Should i go get a new tank i smell gas once and every while?
Old 12-29-2010, 08:26 PM
  #148
kd5bwp's Avatar
Yup they replaced the tank for free only thing I paid for was for a new pump since it was original and wasn't pumping its full amount that it should have been.
Old 01-19-2011, 09:34 AM
  #149
jer4251's Avatar
Car: They all sit.
Engine: LB9,LB9, LS1, LT4, LT4
Transmission: T5, T5, 4L60, T56, T56
my 1991 Z28 and my 1992 Z28 both fall into the vin breakdown for the recall. guess i'll be calling in to see what they can do.
Old 01-19-2011, 02:50 PM
  #150
KMK454's Avatar
Car: 1991 Camaro B4C
I recently purchased a 1991 B4C Camaro with 13k original miles; it falls right into the affected VIN range.
When I fill it up to max capacity (meaning there's probably some fuel in the filler neck), I noticed a faint smell of gas. It goes away after some brief driving and doesn't come back until I top it off at a gas station, so I never thought much of it until I read this thread. When I unscrew the gas cap, there's good fuel pressure and the sound of it being released, so if there are leaks they can't be big.
Is there any way I can visually check the leaks before bringing it to the dealership?
Our dealership is decent so I'll give them a note and see what they say. I'll be sure to include the full recall information/language. A print-out from the NHTSA wouldn't hurt. I'll update on what comes from it.
If it needs a replacement, does anybody know if you can still get a 1LE baffled fuel tank?
Quick Reply: Gas Tank Recall...Read if you have a 1991 Camaro RS.....
