How to rustproof after drilling holes?
Old 12-14-2006, 11:09 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
I'll be buying a strut tower brace soon. It requires that I drill several holes in my engine bay. Obviously, there will be exposed metal due to the drilling.
What are my options for rustproofing these areas?
Thanks!
Bill
Old 12-15-2006, 07:04 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
I installed a strut brace in my 87. After drilling all the holes- and making sure that it fits right, pull the bolts back out. Use a small paint brush (hobby size) and touch up the metal with the right color paint. I say use the right color in case you spill some or make drips. If all you have is black enamel, then use that. if you really wanted to take your time with it, you could use primer first, then the color. if all you have is spray paint, then spray it into a top of a paint cap, then use the brush. it should work fine. The factory doesn't even take the time to do this. Pat
Pac J
05-17-2020 10:44 AM
Jorlain
Exterior Parts Wanted
06-29-2017 11:04 PM
Bohemian
Aftermarket Product Review
11-25-2015 09:38 PM
mcfastestZ28
10-01-2015 11:23 AM
drumstixer
09-29-2015 03:02 PM
Quick Reply: How to rustproof after drilling holes?
