Hatch Motor Blues
Old 04-28-2008, 02:59 AM
karl's-92'-z28's Avatar
Car: Too many cars
Hatch Motor Blues
Ok heres the low down, i put in a new motor, used hatch struts, used switch, new fuse. Everything works fine but when I hit the switch it goes up then back down.What could be the problem? Should I adjust the height of the motor? Any help willbe appreciated, Thanks in advance.
Karl
Old 04-28-2008, 07:30 AM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
Re: Hatch Motor Blues
I had a problem similar to this. I thought my hatch was not going down all the way so I tried adjusting the motor down. After the adjustment whenever I opened the hatch it would go up then down. I moved the motor up to where it was before and it work good. Make sure you are hearing the click when the hatch is closing or you might burn up your motor.
Old 04-29-2008, 01:26 AM
Car: Too many cars
Well I tried adjusting the motor height & its still doing the same thing I don't know what could be the problem. It makes the clicking noise when its shut all the way down. It just goes up then back down, it clicks when it wants to open, but it goes rite back down. HELP!!!!!
zayne0
08-24-2015 07:22 PM
Linson
08-21-2015 02:12 PM
madsv1000
08-20-2015 06:45 AM
stalkier
08-13-2015 12:59 PM
mustangman65_79
08-08-2015 01:18 AM
Quick Reply: Hatch Motor Blues
