Dynamat and other sound heat and vib mats: Compare
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
So who all is using Dynamat sound heat and vib mats???
Anyone using other brands???
Man are them things pricy.
$28 for 2 10"x10" pieces of Dynamat
http://www.dynamat.com/store/store-car.asp
Some roll on crap
http://www.quietcar.net/?gclid=CKvz9...FQIWFQodaVy9HQ
Stuff called 2nd skin that is pricy like dyna
http://www.secondskinaudio.com/
And I found smitty mats about 1/3 the pirce of them all.
http://SmittyMats.com/
Look like everyone sell the same basic crap, those that sponsor racing and have adds on TV just charge out the BLEEP for it............
Some roll on crap
Re: Dynamat and other sound heat and vib mats: Compare
i am putting on summit brand, its called "hushmat". i will have to report back with results when my car is running, another month or two.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
http://www.hushmat.com/new/Performance/index.htm
Starter Kit - 4 square feet
$40.00
Thats 4 12x12 squares for $10 each, man do you know how many it would take to do the inide of my car???
That $2sqft stuff looks better and better.
$40.00
Car: 92' firebird
Axle/Gears: 10 bolt POSI 3.73's
www.fatmat.com
I paid 130 for a 100sq foot roll. The stuff sticks really good and I did notice a difference..
I liked it
I liked it
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
I've used a few different mats over time and my favorite so far has been Raammat. Check it out at www.raamaudio.com
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Also used RAAMmat. Installed very easily. Yet to drive the car with it though
I used a product called R-Blox on my pickup - pretty cheap on ebay. I did the doors and the back of the cab. It went on real easy and things are quieter but I haven't used other products so I can't say how it compares.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I have Dynamat on my doors and trunk area. Works very well.
I'll be using second skin on my rear panels and hatch.
diymobileaudio.com did a head to head comparison (sound, heat, elasticity) on all types of sound deadener. Second skin came in 1st and Dynamat placed 2nd. Fatmat and maats placed further down.
Use the basic type of sound deadener. The xtreme/ultimate is not worth the extra $$.
Car: 1984 z-28
Engine: 305H.O. L69
Axle/Gears: 3.73 G80 GT4
i've used dynamat for car audio installations on decently loud systems and it seems to work well, it does block outside noises pretty good. not worth the money though
i always thought about finding thick aluminum foil and grabbing a bucket of roll-on line-x and going to town with them
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Its all nothing but rubber or closed cell foam with a foil backing, it should not cost any where near what it does. Don't care how well it works, its all a rip.
$28 for 2 10x10in pieces. total rip off.
And why 10x10 insted of 12x12???
They can sell you more.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I went shopping for tape and thought id check out foil tape prices.
Man that stuff does cost some loot.
But found walmart sells chrome duct tape for $3 a roll.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
who sponsored it and was it scantion by all companies???
But its often like when they use products on tv car shows, looks like a tv show but is one long commercial to push a product they are paid in cleaver ways that their opnion changes.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Did my roof and was impressed with the changes.
Never had a headlinner in it. Though I did use the chrome duct tape instead.
Just member foil and hot contacts don't go together. Thought id just push the prongs for the doam light through it. Spark spark fizzle and pop goes the fuse.
Also the area right behind the bulb filiment had to be trimmed, it was making the stuff smoke. But only the small area where the bulb filiment was.
Thought of this as I guess they found Ebay and are using a cleaver way to get traffic.
Sell $1 bills for 80cents shipped
Or could be for feedback, I know you need like 15-20 to be able to list more then auctions or something like that.
myworld.ebay.com/smittymats
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I used Smitty, was impressed with how it stuck to the roof. Expected it to be hanging down on first day in the sun. Only used tap to cover seams.
No more of that talking in a metal shead sound.
1 Post
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
if you arent doing a large area (whole trunk, whole interior), i would do what i did. i bought 1/2" by 1/2" hi-density foam weatherstripping from Lowe's (10 foot roll for $3) and put it at all of the intersecting panels on my mustang to prevent the ratteling. 30' for $9, and no more ratteling and clean bass (with 1,400 watts to a 15" L7 tuned to 32hz)
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
That stuff works good for cowl, hatch or door seals.
I have a new hatch seal now but my doors and cowl are sealed up tight with that peel n stick foam on a roll. Works good. Wipe old seal down with aolchol then just apply right on top.
1 Post
I used that on the intersection of all of the interior panels together on the inside. ie. top deck to rear interior panels... works great.
Second Skin Audio...
took 2 days, me and a friend to do from Rear Pillars to end...
Did the outer rear wells too, since they are a source of great noise...
Then used their brush on liquid deadener over that...
(Pic looks purple, but it's flat black...)
Haven't had the car out since doing all that, but just idiling in the driveway it seems much quieter inside... a bit of extra weight, but I got a super charger to install too
Raf
Raf
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yea weight isn't always good but not always bad.
That Smitty stuff was 2lb for the whole 12ft roll including the carbboard tube.
Though they don't measure well, I got a good 14-15ft on the roll I got. Shhhhhh
wtf lol, i think you went a bit over board sound deading the OUTSIDE of the wheel wells lol, doing the inside would have been good enough.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
May als scare someone else who end up with the car. Folks do thing like that to hide rust. Mine was like that, duct tape covered in roof tar to hide the rust I had to fix.
Though I want to do the back inside of mine like that and the a-pilers. To help with noise and heat as Im gonna be putting TA front hood louvers in my
a-pillers for a fresh air vent. 2 windows down just isn't enough. Like the hood install they won't grab air, air will just be sucked out of them on the move.
Friend suggesting getting a new window made for my notchback with a slider window like a truck. But that would be a bit hookey, though cool on some levels for getting air to flow through the car better.
Go to the roofing section of Lowe's, and buy yourself a few rolls of "Peel 'n Seal." It is much cheaper and just as good as Dynamat and all the others.
With those, all you are paying for is the name.
I'll check out the Lowes stuff.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
x2 on the peel and seal. i only did about half my hatch well and noticed a nice difference.
Car: 2002 Camaro
Engine: :(
I use second skin. I bought the Home depot stuff before and id not like it. Now that I have both it is no comparison, that hardware store brand stuff is JUNK!! It looks like foam, the seconskin is a tar like material, I could tell jsut by putting one pice by each other and knockking on the metal which one worked better.
I dont have the money to spend at all, but I dont want to put junk in my car. So for $323 I got 80sqft of damplifier, and 26sqft of damplifier pro.
You get what you pay for!!
Car: 2002 Camaro
Engine: :(
This is a site that did a comparison test of Many if not all sound deadners on the market including the hardware store brands.
http://www.sounddeadenershowdown.com/
Secondskin auto won by a long shot, but is the most expensive. I think RAAmat won the best cost/effectiveness award.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Hard to take test like that searious.
LIke test on who has the best oil. They all can prove how their works best.
And the best just happen to cost the most beyond my wallet.
But for my needs, regular old affordable dino oil n smitty mats works well for my need and wallet.
If youcafford $10sft for a mat material for your car, you probably can afford $70 a quart oil too. Good for you.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
When doing a door panel, I put back the factory plastic and stuff and I wasn't sure how I would cut n fit around everything easy so there is so much junk.
Bingo idea, don’t cover the door, cover the backside of the interior door panel.
It’s going to work near the same, but was easy to lay and cut where needed
[ allot more flat], I can also access the inside of the door later easy with out mat to remove. Laid it just on the inside of the plastic pins that hold it on. That way the edge sucks down and hides that its there.
using smittymats.com
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I think someone got wise, they raised their prices but a standard roll comes with 14ft not 12ft anymore.
As the 12ft roll I had gotten had a good 14-15ft on it.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
good for the next 30 days [already planned to order more after xmas.]
http://SmittyMats.com/sell/
10OFF $10 off order of $84 or more
20OFF $20 off orders of $185 or more
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Hey Smittys isn't just for cars, I used some left over on a busted water pipe I had to fix. Even in the bitter cold it stuck well.
