Prep for new Decals on 84 TA
Old 05-15-2009, 08:38 PM
Jeffinsoco's Avatar
Looking to get any idea regarding removal of the stock decals and all residue prior to priming for paint.
Should I just sand them off???
Whats the best way to do this?
Thanks!!!
Old 05-15-2009, 09:24 PM
86sdubzzT/A's Avatar
Car: 1986 T/A
Axle/Gears: Stock
Re: Prep for new Decals on 84 TA
Use a blade. Some people use a razor blade. I only like using one by hand for smaller decals. The holders dont give you quite the feel. A sharpened 5" applicator blade. Sanding the blade will sharpen it. The key is to try not digging into the paint surface (Captain Obvious) I usually will try thinners and bondo dust to remove the glue. The thinners softens the glue and the dust helps to ***** it up. Test a small spot out of the way first.
Sanding isnt a great option imo
Hope this helps a bit.
Old 05-15-2009, 09:39 PM
chrissmith's Avatar
Car: 1991 camaro rs
Engine: edelbrock350performer crate motor
use a heat gun and razor
Old 05-15-2009, 09:53 PM
Stephen's Avatar
Car: 87 GTA
NONE OF THE ABOVE!!!!!!!!!!!!
You wanna do it with zero chance of damage to your paint?
Get you one of these..... Pinstrip Removal Wheel. Other types are available. Any paint & body store would have them, or worst case...A body shop might sell you one.
After peeling the side door moulding (I have a heat gun) from the side of a factory black 97 Tahoe in 2002 (so 5 yr old paint), the eraser (we called it) removed the left over adhesive & did ZERO damage to the paint or its finish. Just a good wash afterwards, not even a polishing!
They aren't the cheapest, but WELL worth it. You'll be SURE not to damage your paint with one of those!
Old 05-15-2009, 11:16 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Stephen is right about the stripe eraser wheels, they work great. But there is a chance it may damage the paint on an older car, depending on the type of paint thats on the car and wether it's been repainted or repaired and partially painted. The eraser wheels will ruin a lacquer paintjob and it can damage any air dried paint that doesn't have a hardner in it.
If your getting ready to paint anyway it's certainly possible to just sand them off. But peeling them off and cleaning up the goo with an adhesive cleaner or wax and grease remover would also work.
Old 05-16-2009, 10:00 AM
Jeffinsoco's Avatar
THanks for the quick replies... I was going to have at with a razor blade and some "Goo Gone" to get the adhesive off. I do like the idea of the wheel. I got this car for almost nothing and I just put in a 350/290 hp crate in it. Its still at the builders. I plan on removing decals, pulling the ground effects off fix VERY Minor dings and chips and have it repainted. I already have new Headliner, Visors and carpet ordered. The seats are flawless. Its a college graduation present for our "Boy Wonder".
Thanks for all of the great ideas!!! As soon as I get a chance, I'll post some before and after pics.
Have a great weekend!!!
Jeff in SO CO MO..
Old 05-16-2009, 11:05 AM
ClickClickVroom's Avatar
Car: 92 Z03 RS TBI
Engine: 5.0 L03
Why would you Spend the extra $30 when you're going to repaint it anyway?
Maybe stephen didn't read, or maybe you changed your mind, but you said "prior to priming"... If you're going to prime it why bother with the wheel?
Old 05-16-2009, 12:11 PM
Stephen's Avatar
Car: 87 GTA
I missed the "prior to priming for paint" part.
Still good info for those just wanting removal info & keeping the paint good.
Old 05-16-2009, 01:22 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Because that wheel will take it of in about 5 minutes, when you could spend a considerable amount of time with goo gone and a razor blade. Then sell the wheel on EBAY.
Old 05-16-2009, 08:42 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
If your taken off the hood bird none of the above is to easy if its as old as the car.They are right but it will not simply peel off.I used an eraser wheel on a cordless drill to remove as much as possible.Then get about 2 cans of decal remover and a set of plastic razor blades from a body supply shop.let that sit about ten minutes and use the plastiic blades and a bunch of rags to remove the remainder of the decal.If you try to sand it off that also sucks the decal clogs the paper fast.Good luck
Old 05-18-2009, 10:45 AM
Former Sponsor
1Aauto's Avatar
That decal eraser wheel works very good. I helped my dad in his body shop redecal 350 AMR ambulances (yes this took a while).
I know your painting the car anyway,but the wheel will zip them off and not knick the metal or paint like a metal razor blade will if you not very careful.
There are also special plastic razor blades for doing things like this,but quickest way is with that eraser.
T
3GZJerry
LSX and LTX Parts
10-14-2015 05:17 PM
Buggy Disaster
09-22-2015 01:15 PM
Drone358
09-21-2015 08:54 PM
WickedBowtie
Members Camaros
09-17-2015 09:13 AM
WickedBowtie
09-11-2015 11:24 PM
Quick Reply: Prep for new Decals on 84 TA
