HIGH RISE WING GASKETS ???
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i am getting stuff lined up in prep. for new paint , window sweeps etc. . i have a 91r/s with the stock hi-rise wing . would like to replace the rubber mounting gaskets/pads where they mount to hatch . i have searched & searched to no avail . unable to find them or part # for them . i know some one on here has had the same problem . if anyone knows of a source or part # you would have my eternal thanks . pls. shoot me a P.M. if you can help . thanks guys & girls .
Re: HIGH RISE WING GASKETS ???
thanks i will check out wings west . any body know ??? thanks .
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
why do you want to replace it? If the ones I saw were factory correct, they're just a rubber sheet cut slightly smaller than the pedistal with holes in it. Why not reuse what you have? if not, you can buy a rubber sheet and make your own.
i will remove the wing for painting . O.K. , when i re-install it on the car i would like to have new rubber to mount it on . i would prefer not to use 20 yr. old rubber pads . if i have to i will , but i prefer not to . O.K. ? if i have to make them i will , i doubt they would look as good as the factory ones . thats why i am trying to find new ones . understand ? thanks for your comments .
1 Post
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Hawks has them saw them the other day when I was poking around on there sight. Here is the link good luck. Just got a new set of pedals from them wend.
http://www.hawksthirdgenparts.com/ca...sketspair.aspx
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
My A&A wing (when I had a high rise on my 'bird) didn't come with any gaskets. I just used closed foam camper seal tape.
Worked fine.
At the simplest, a rubber washer will work. You're just keeping water from getting through the bolt hole in the deck.
[quote=91RS5speed;4181254]Hawks has them saw them the other day when I was poking around on there sight. Here is the link good luck. Just got a new set of pedals from them wend.
thanks , i some how looked right over them . thanks again .
[quote=deadbird;4181560]Having new gaskets is fine but, if you don't know how to use a pair of scissors and a utility knife, maybe let someone who can handle sharp pointy objects do it for you.
thank you for your wonderful insight to my question . i do not have a problem with sharp pointy objects . it sounds to me like you have had some problems in this area . perhaps you would like to share them with all of us . thanks again .
Engine: TPI 305/ v6
[QUOTE=UNCLE TOM;4181730] Actually, my problem was your response to the person who offered you an alternative solution.
No one here is obligated to answer your questions. Be thankful someone offered help, even if it isn't the exact answer you wanted.
You've been a member long enough to realize at least that.
1 Post
Car: 1984 Trans Am
Uncle Tom,
Judging from your response, I think you saw something in my reply that wasn't there. I wasn't questioning your motives or implying you were doing anything wrong. The reason for my questions was to better understand your situation so that I could try to be more helpful. Receiving those kinds of responses make me not want to bother helping at all.
i did not intend to ruffle any feathers . that was not my intent , if i upset anyone i'm sorry . i have had to make do/improvise more times than i can count . i was just trying to find the factory correct part . once again , if i upset anyone i'm sorry . rest assured that was not my intent . i think this forum is great , and all the people who share information . once again i am sorry if i p****d anyone off . i did not mean to , thanks for your comments & help . good luck .
just an up-date , today i removed wing/spoiler . not without problems , had to grind away heads on front outbrd locations of wing hardware to remove wing . as i expected , the gaskets/pads fell into a crumbled mess when i removed wing . ( like an old/stale cookie ) anyway wing/spoiler is in good shape . thanks 91rs5speed , i ordered the new pads from hawks today . for the 2 center posts i still can't find them . if i can't find them i will just seal around bolt holes . anyway this project is a one step at a time to align rear hatch . i want to get a perfect alignment of my hatch/glass before new paint . thanks for your commens/ideas .
1 Post
Car: 1984 Trans Am
It's cool. I know that sometimes it's hard to judge someone's attitude when they post on a message board. I've been doing the same thing as you getting a hatch realigned before a paint job, only mine is a firebird with the pedistal spoiler. I've removed one of those high-rise wings before and they can be a real pain when there is rust involved.
tyeo098
11-30-2015 06:27 PM
