How much does YOUR car weigh??
#101
Re: How much does YOUR car weigh??
Anybody with a V8 in street trim under 3200 is full of it or hasn't weighed their car.[/QUOTE]
I had an 84 Z28 that I bought stock very low option LG4 T5 car. manual shift, seats, windows, locks, no power hatch or antenna. No A/C, cruise, tilt, rear defog, absolutely no window tint (I know window tint dose not weigh anything) all this car had was a radio, console clock and 2 speed wipers. This car was factory stock in this configuration and in great condition. I modified the car before I weighed it. I swapped in a a 92 TPI 305 with exhaust manifolds not headers. I did not re install the emissions equipment, but added the extra wiring,fuel return line and swapped in a tank with a fuel pump and GTA wheels. After the mods I did weigh the car. I was just about out of gas when I weighed that car so now I weigh my cars without much gas for comparisons sake.With the above mentioned mods the car weighed 3120 lb. I have a few parts left from this car including the very rare glass, I have pics of the car,before and after the mods, I still have the spid and I still have the scale certificate and it is the same scale I used to weigh my current Z both before and after, My current car is a 91 Z that was pretty loaded when I got it and it weighed 3320 with almost no gas and 3040 now.Call me full of it and your ignoring the facts and if the factory put it out it is street trim no matter what level of plushness you personally prefer. My current car that weighs 3040 lb. yes the rear seats are gone so are the rear seat belts and mounting brackets, but it is carpeted and has interior panels and looks very nice not gutted. In my personal opinion it is cruel and unusual punishment to put a small adult back there much less a full sized one anyway.
#102
Car: 1984 Camaro Z28
Engine: 406
Transmission: TH400 3K stall
Axle/Gears: DTS 12 bolt 3.73 eaton posi
Damn so mine weighs a little less with aluminum heads and a aftermarket k member also I have no rear seats ,and man I feel the same way bout fitting someone back there, GO BREWERS
#104
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
ive weighed both my third gens on numerous occasions, they always about the same (depending on gas), ive tried different scales etc. both are under 3200
#109
1. 1985 Base Camaro
2. 3.4l L32, 700r4
3. t-tops, AC, non cruise control, non power locks and windows
4. complete AC delete, spare tire/jack delete, EGR and EVAP delete, headers fiberglass pin on hood, interior mostly gutted, retaining the front seats, center console, door panels and dash(no dashpad, its cracked so I removed it, going to get a fiberglass one piece unit eventually), rest is out and staying out. All hood hardware removed, ie. latch, cable, hinges, rear hatch shocks removed.
5. Stock its curbweight weighed in at 3153, I estimate that it should be about 3k with my weight reduction mods, but haven't had a chance to actually weigh it yet.(anyone have any suggestions where to go for such a thing?)
Also to clear things up for the guy that thinks his thirdgen weighs more than a new challenger, you were most likely looking at the GVWR sticker, aka gross vehicle weight rating, that is not the weight of the car, it is the maximum weight of the car, ie. the most it can weigh when loaded up with cargo and what not. The actual curbweight is found by subtracting the capacity, which will be listed on the same sticker or one nearby.
2. 3.4l L32, 700r4
Last edited by Project 3.4 Camaro; 09-15-2011 at 04:29 AM. Reason: Adding more to the list as I remember, lol.
#110
Engine: 2002 Ls1
Transmission: t-56
1. 1985 Base Camaro
2. 3.4l L32, 700r4
2. 3.4l L32, 700r4
#111
#112
Car: 1987 IROC Z28
Engine: LB9
Axle/Gears: 9 Bolt w/3.27's
1987 Iroc Z28
Completely bone stock except for flowmaster catback, 305 TPI, T5, 9 bolt rear, glass t-tops, full accessories/emissions, fully loaded, missing headliner, power everything, spare tire and jack removed, 1/4 tank of fuel. 3320 lbs. without driver. Certified Cat Scale. (Twice)
#114
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
1991 Z28
5.3l
4l60e
no spare tire
3/4 tank of gas
3390 at local recycling center
5.3l
4l60e
no spare tire
3/4 tank of gas
#115
1 Post
Car: Lots of 'em
I'm curious to see what mine weighs right now...
Even with it completely stripped right now, there's still more weight to be taken off. Tubular K member, lexan hatch, some skinnies up front, a fuel cell, lightweight battery.
One of these days I'm going to figure out if I could have a running third gen that's less than 2,500 pounds. Gonna have to ditch my turbo SBC/auto idea and find a wrecked LS1/T56 car in the future.
#116
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Mmmhmmmm I wonder how much weight I've added to my car....89 trams am gta 8 point toll bars 88mm turbo Hotside/coldside pipes intercooler 12x9 transmission cooler and fan th350 9 bolt rear 28" Mickey Thompson radial fiberglass wrap around wing heavier -8 fuel lines 3.5" downpipe ttops tubular xmember tubular aarms no front sway bars 15x4 summit star wheels urethane ram air hood all ac components have been removed all dash wires are removed 4th gen firebird dash and center console stock cloth driver and passenger seat power windows power door locks power mirrors full borla exhaust luckly I only weight 145 lol
#117
we just got a weight on this car , without driver in it ,and there is another racing seat and harness in at time of weighing and it came out at 1200 kg. or 2695 lbs .front end is all stock yet so we will be shaving more weight off it yet in the future. so it is possible to get the weight down a lot and still have a full cage.
#119
1 Post
Car: Lots of 'em
Every time I see an update on this thread, it makes me want to get to work on my car. Mine will eventually be ridiculously light. Not going to run a cage either. Only weight I'll be adding would be subframe connectors. Under 2,700 with a cage is just awesome.
#120
Car: 1990 T/A w/WS6
Engine: 5.7L V8 TPI
Axle/Gears: 3.23 w/ posi
1. Model/year; 1990 Trans Am
2.Engine and trans; 350 TPI/700R4
3.Options (ttops, ac, etc); no T-tops, but power windows and such.
4.mods; i still have the old spoiler
5.Weight; about 3400-3500 fully loaded.
#121
Just to give some perspective of how much more the 4th gens weigh than the 3rd gens, my 94 Z28 M6 with no interior, no front crash support, no AC or AIR, and only the 2 front seats, no dash, and the guages zip tied to the firewall the car weighs 3010lbs. My brothers 2000 WS6 trans am at full weight was 3560lbs.
#122
I heard power and manual door guts weight about the same. I wonder what mine weights, no heater ac of any kind, barely any wires, 350, t5, no jack or spare, and I have a set of plastic t tops. Also my seats I installed weigh easily half what my stock manual seats weigh. Also no radio, speakers, etc.
#123
Car: 1991 Formula 350
Engine: 350 TPI (L98)
Axle/Gears: 3.23 Posi
I'm curious to know how much a 1991 Formula 350 WS6 weighs? I can't find it anywhere! Under/about/over 3300lbs?
#124
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
my formula comes in at 3252,thats with ac delete,cat delete,cruise delete, but added fiber glass hood-spoiler,sub frames, tubular LCA-PHB... That had 1/4 tank of fuel
#125
any idea what it would be w/ A/C, cat, cruise and with all other stuff. i do have lighter heads though but how much it would weight as stock? 3300ish?
#126
Car: 89 Formula 350
Forgot that weight is with Aluminum heads and lighter cross lace rims....I would think the car from the factory would be around 3325-3350... Mine is not a good example being I have messed with it so much. You were also asking a 91 Formula, mines an 89 with a 91-92 Formula nose conversion.
#127
1. 1988 Trans AM GTA
2. 383TPI / Borg-Warner T56
3. Hardtop
4. Emmissions!, AC Delete!, transmission swap, gears, Custom CAI, bore/stroke, headers, exhaust, SLP Runners, intake, MSD ingnition parts, and Fiberglass hood
5. Stock weight: 4200-lbs and change. Modified weight: 3260-lbs.
3. Hardtop
I haven't weighed my car yet,when I get a chance I'll set up some platform scales and drive it up on and get a weight in 1 pound graduations.
#128
Car: 87' IROC
As stated before,gross vehicle registered weight,max it should be fully loaded
Any scale is only as accurate as the guy maintaining/calibrating it,I've been installing and calibrating scales from lab equipment to truck and train scales for almost 20 years,you would be surprised how many never get checked/adjusted after initial installation,especialy privately owned 4 corner type racecar scales.
Even if they are off by 2% that is 70lbs off right there.
#129
Exactly,I see stuff thats a lot more off than 2% sometimes,I wonder why people would buy a scale,not a cheap piece of equipment by any stretch,and never have it tested/adjusted for maximum accuracy.
#130
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
My '91 Z28 weighs 3380 with 56.2% over the front and 43.8% over the rear. I haven't really done any weight reduction yet besides headers. It has the stock LB9, T5, hard top, A/C.
#131
Car: CTSV
Engine: LS6
Necroing this!
I am about to pick up another one to compete in the Texas Mile.
I think the 3rd gen is the cheapest route to run 200 mph.
These cars are fairly slick, long and low. It should be a no brainer with a TT LS motor and a completely stripped out interior.
I am shooting for 2500 lbs before the cage and safety stuff.
It's been almost 15 years since I have been in one......off to search, but found this thread, so I thought I would share my madness....
#133
#134
Ok, you're responding to a 7 year old post. What's your point? My car empty weighs what I posted and has a max axle load of what I posted. If you look carefully, I specifically called out GAWR!
#136
1. 1992/RS
2. 3.1 v6/ 700r4
3. t-tops
4. 4th gen manual cloth seats, deleted cat, flowmaster muffler, spare tire/jack removed.
5. 3,200 (with almost empty tank of gas, with me in it)
2. 3.1 v6/ 700r4
3. t-tops
#137
Originally a 2.8 auto sport coupe
3395 lbs
5.3 Lm7
T-56 trans
UMI Subframe connectors
6 point jegs cage
Corbeau fixed back fiberglass racing seats with harnesses
No jack or spare
No washer bottle
No rear seat
92 Z28 GFX and spoiler swap
Ctsv Brembos
4th gen rear
18 inch c5 wheels with 275 rubber all around.
Car still has radio, power steering, full interior minus the rear seats. Working heat and A/C
3395 lbs
5.3 Lm7
T-56 trans
6 point jegs cage
No jack or spare
No washer bottle
No rear seat
Ctsv Brembos
4th gen rear
#138
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
My car got weighed at the scrapper many years ago (long story, I wasn't scrapping it). '86 IROC-Z with t-tops and all power options. Aluminum heads. At the time, it had a fiberglass hood, automatic, 1/2 tank of fuel, as well as a younger 140 lb me. It was 3680 lbs. I thought that was kinda hefty.
#139
Old thread but I have weights from 3 different 3rd gens.
1992 RS 305/700r4/10bolt, 18x11 with 315 tires square, Full tank of gas, T-Tops on. 2 sets of SFC
1985 Camaro Gutted interior, No T-Tops or any weather seals, Unknown 25 gallon fuel cell fill level, HUGE NASCAR style roll cage, 4.8L LS/T56, No hood and most of the front end was cut off, no bumper ex.
A 1991 Camaro V6/T5, Full tank of gas, Umi K-member and a-arms, No AC, Manual windows. Otherwise 100% stock
DynoDave43 (11-05-2021)
#140
Axle/Gears: 10 Bolt 2.73 Open
Just curious about other weight adding equipment that it may or may not have on it.
Arctic White 91 RS (11-05-2021)
#141
It has almost every option from the factory.
cruise controlPower windows and locks (power windows aren't much heavier than the manual ones)
LIght weight steering wheel(grant)No radio or speakersGlass T-Tops were removed, since I don't run them at the Autocross.
Has a Wilwood and BAER brake kits that added about 20lbs to the car.
Has a racing seat that's 10lbs less than stock.
No spare tire or jack.
2 sets of subframe connectors inner/outer
DynoDave43 (01-25-2022)
Robbie Duling
Aftermarket Product Review
09-25-2019 06:20 PM
JeremyNYR
06-26-2017 01:17 AM
mult68
South Central Region
12-04-2007 02:48 PM
