SERVICES NEED HELP iNDIANA PPL!!
I'm about to install lambo door kit with automatic actuator and shaved door kits. I want to leave this up to someone that actually knows what their doing. its a bolt on kit but might need some welding done under need to remove and reattach rusted bolt connected to fender. I'll pay probably $100 - $150 for entire install and ill drive it to location. Text 1-317-250-3151
THanks
THanks
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: SERVICES NEED HELP iNDIANA PPL!!
no one will install a lambo kit for $150 that I can think of at all. Most shop rates that would be 2 hours labor, especially if you want welding done to, doubt it'll happen. Call around to local custom shops in the area and see what they quote you price wise.
Yea so called around to kustom shops, these people are crazy they want 700 and up for the labor, so not doing that. Let me know if someone can help me with some technical info. I'm just wondering I'm going to get the bolt on kit so im wondering do i have to cut out the old hinges or just take them out... and what tool do i use to take old hinges out... also if someone has a wiring diagram of the motors and solenoids in the doors so i don't take out the wrong wires that would be tremendous too... thanks alot guys
dbrochard
09-19-2015 08:13 PM
