clearcoat repair?
Old 02-13-2011, 10:03 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
clearcoat repair?
what is the most sensable way to fix a quarter panel that has clear coat coming off.It's the only place on the car doing it! it's a 91 maui blue rs
Old 02-13-2011, 10:06 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: clearcoat repair?
if the paint is showing you need to sand it down apply primer sealer and paint it
Old 02-14-2011, 12:02 AM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
I also heard that you could get sand down the surrounding clear coat and pick up a can and respray it and it will look like new. In my case I plan on repainting it but not for a while so I might go down that path and maybe you should too unless you are just going to repaint the whole thing anyway. I'm just saying having one freshly painted body panel would annoy the heck out of me.
Old 02-14-2011, 12:27 AM
juanillox8's Avatar
Car: TOO MANY
that will not really work because you will have a different thickness between what already peeled off and what you are going to sand, also, if the problem is on the clear, meaning a cheap clear was used, by using a spray can the chemicals will more likely react ant the paint will start to wrinkle.
but, like you said it will "annoy you to have a freshly painted section" it will basically depend on the condition of the rest of the car if its worth it to do it the right way or the "just for now" way.
Old 02-14-2011, 08:06 AM
That just about sums up what I was trying to say. So doing it the just for now way could make it worse? What if you were to sand that whole panel of its clearcoat? Would it still happen then?
Old 02-14-2011, 12:47 PM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
You could WET sand the peeling areas ! This will make the entire surface level.
Then re-spray the area with new clear coat.
You just have to be careful not to sand/burn thru the color base coat.
Old 02-14-2011, 04:44 PM
So you just have to sand what is peeling? Not the whole area? If so that would save alot of time because this area on my hood has gone to crap.
Old 02-14-2011, 04:52 PM
juanillox8's Avatar
Car: TOO MANY
Again, it dsnt work that way, wherever the clear came off there's no more clear just paint,if you water sand you will cut through the paint, and if you dont sand it down, the clear has nothing to grab to so it will come off again....
Old 02-14-2011, 05:02 PM
Alright I got it but (yes another question) would a light sanding (light enough to smooth the clear out but not enough to go through paint. I am just willing to listen to anything that will make it look better until I can get it painted. Right now I have this 6x6 chunk of clearcoat about to come off along with some other problem areas.
Old 02-14-2011, 05:17 PM
juanillox8's Avatar
Car: TOO MANY
If the clear came off already, theres no more clear to sand just color
Old 02-14-2011, 05:19 PM
juanillox8's Avatar
Car: TOO MANY
Tell u what, get a sheet of 2000 wet sand paper and sand just a lil bit where the clear peeled, and you will see what happens.
Old 02-14-2011, 06:10 PM
So there is no need to sand if there is no clear there? I could just spray it on? This is what I was asking from the beginning.
Old 02-14-2011, 06:13 PM
juanillox8's Avatar
Car: TOO MANY
Read post #8 again carefully
Old 02-14-2011, 06:45 PM
Oh, so I need to do sort of a quick swipe on the exposed paint so that it grips? Then sand off the about to chip clear coat? That makes much more sense.
Old 02-14-2011, 07:27 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
if your careful you can scrape with a hard spatula and sand (with 600-2000 grit) most/all of the peeling clear off. just be careful to not sand through the color. I had the same problem on my rear 1/4 and roof, i was able to sand 90% of the bad clear off, and waxed the hell out of it and it looked better than peeling clear. or after you sand off the bad clear you could hit it with some clear, then buff the edges down as much as possible before the clear is completely hardened.
before anyone say's not to do what i just described, I've done it, and it WORKS for a temporary fix. it is in no way a permanent solution and you can tell its a patch job, but it looks better than crappy old clear and the op is planning on repainting soon anyways so...
here are pics for the non believers:
before:
durring:
after:
Old 02-14-2011, 08:01 PM
Here I will post some pics of what I am working with:
Trunk:
Roof:
Hood:
This stuff on the hood happened right after the first snowfall and some of the stuff on the hood I found after I pulled the tarp off from which it was under this winter.
Old 02-14-2011, 08:13 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
its never gonna look great again, but if you have some skill with sandpaper you can make it look better. the only correct repair is a repaint though
Old 02-14-2011, 08:26 PM
I understand that but you think this it is do able? How will I know when it is perfect on the trunk? Or do I sand it until it has grip to it (just a little bit) and then adding the clearcoat will make it look normalish again?
Old 02-14-2011, 09:54 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
honestly, your clear is really bad, so your best bet is probably to chip/scrape as much off as you can without damaging the paint, sand down what you can until it starts taking the paint off then stop. then wax or zanio the hell out of it. i'm not a paint guy i just experimented and had some ok results. try a small, hard to see spot first before you go do and big areas.
is sucks, but your car needs a full repaint to ever look "right" again
Old 02-15-2011, 12:16 AM
I figured but I just want to do anything that can make it look better. What if I told you that when I pass my hand on the trunk a little tiny bit of paint ends up on my fingers? So when you did yours did you sand it until it was one color and then clear it? How long did it take you to do that? Could I just pick up clear at Autozone?
Old 02-15-2011, 12:21 AM
Does this look like something that I could use?
http://www.autozone.com/autozone/acc...fier=59654_0_0_
Old 02-15-2011, 01:23 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
i'd start with some scrapers (plastic), or plastic spatula and see how much you can chip/scrape off, then try to sand some. as soon as you start really getting into the color you need to stop. a little color coming of when you sand is ok but you have to be CAREFUL to not thin the paint to much of cut through it. it's really a trial and error thing. see what you can do getting the bad clear off before you look into new clear or anything. depending on your skill level and how bad your clear/paint is you may just make it worse.
Old 02-15-2011, 10:42 PM
I got a friend who says his dad has some work with this kind of stuff and says that once it warms up then we can work on fixing it. The only way I think I can make it look worse is if I sand so much that the primer shows. So yeah I will work with them on it maybe in a week or maybe in a month, Nebraska weather is completly unpredictable.
Old 02-17-2011, 09:07 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
alot has been said sence I first posted this question.The car got sold out from under me,but I got my 89 iroc that has some blistering trouble,why would the paint bubble up in a few spots? Big ones.Like silver dollar size. It only happened on the hood and just behind the t bar on the top.the rest of the paint looks great.Is it possible to sand down to the primer and tapper it out and repaint just the top of the car.I figure sanding down the hood and prime and repainting it would be the easyest way for that.what kind of clearcoat should I get to put on it?
Old 02-18-2011, 10:29 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Sounds like rust eating through!
Old 02-18-2011, 08:28 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
there wasn't much. must have been a chip spot first that rsted underneath and then bubbled up.because there isn't any damage to the metal,othere than minor surface.Very minor
Old 03-26-2011, 11:28 PM
david chambers's Avatar
Car: 1986 iroc Z-28
Engine: "LB-9" TPI 305
Transmission: 700-R-4
Axle/Gears: corporate 2:73-1
clear coat is garbage!!!!!! just TRY and make it work as intended i challenge anyone to
Old 03-26-2011, 11:32 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
You are killing me with your rants on clearcoat Mr. Chambers. This guy has a personal vendetta on clearcoat companies, I think he's a rep for Dupont Imron. As a sidenote, your rust bubble will spread, and become much more than surface rust. Save some money and get it fixed before next winter.
Old 03-28-2011, 08:47 PM
Albani's Avatar
Car: 87 GTA
Transmission: Automatic
Axle/Gears: 2:73
I had an 86 T/A with 50% of the clearcoat gone. I could not afford a paint job. I pressure washed all the clearcoat off without damaging the paint. I then buffed, polished, and waxed. Lots of wax (only thing that will now protect the paint). Pressure washer is 7 hp - 2800 psi.
It looked pretty damn good and cost next to nothing.
Old 03-29-2011, 03:04 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
:facepalm
Old 04-03-2011, 08:03 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
stripped it down to the metal and primered it back.For now a wax job will have to do.I plan on having the whole car painted by a pro in about 2 years anyhow.Just wanted to stop the rust.
Jorlain
Exterior Parts Wanted
06-29-2017 11:04 PM
SRKLEGIN
09-30-2015 07:19 PM
Aaronv808
Members Firebirds
09-30-2015 12:55 PM
HoosierinWA
Members Camaros
09-29-2015 12:43 PM
ironbmt
09-27-2015 06:00 AM
Quick Reply: clearcoat repair?
