Would the T-tops from an 85' Bird fit into an 88'?
1 Post
Car: 1988 Firebird Formula
Engine: 5.0L 305 TBI
Just curious, I found some cheap 85' T-tops on ebay that I would buy for spares, and was wondering if they would fit into my car.
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Re: Would the T-tops from an 85' Bird fit into an 88'?
Ok but I thought there were different latches and pin sizes. Like the earlier ones have hooks and the later one have large pins holding the hatches in.
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
some have locks where you turn the key cylinder to open it and some just have a lever that's the only difference I've ever seen
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You need to make sure the tops aren't the older hook latch style. The pins on all pin-type tops will lock into the retainers on the body (larger "pins" on later tops are merely retractable plastic covers).
However, I had a set from an 85 I nabbed for use on my 87 (got a bunch of crap that day plus the tops for $30! Best day I've ever had at the yard).
1Aauto
Sponsored Vendors
04-09-2018 03:00 PM
ambainb
04-25-2016 09:21 PM
1Aauto
Sponsored Vendors
08-24-2015 03:40 PM
